I AM DESPERATE!! PLEASE HELP. ERRORCODE P0571 - Brakelight switch
I have no further ideas then, except to recheck all connections using the diagram that varooom kindly supplied to you.
This problem may be caused by corrosion of connections, I think. I may have read about this somewhere on this forum, but not 100% sure This page shows the brake switch as item 10, described as a 'repair kit'. brake fluid - Octavia(OCT) [EUROPA 2012 year] (7zap.com) If you poke that part number into oemwolf.com, it shows as superseded to 5G0698459, which on this page helpfully has a list of kit contents.,VAG 5G0698459 repair set for brakelight sensor Audi, Seat, Škoda, Volkswagen genuine OEM part kit (oemwolf.com) Note there is a four-pin connector included. Is there any sign of corrosion on the pins of the original switch, if you still have it?
! Need help with an issue on an Octavia 2012 CAYC
There are more than this, and most of those will only be powered under certain conditions. The only one that you should always see 12V at is pin 92. This feed should also be found at the connection '85' for relay no. 1 in the e-box. All the other feeds are dependent on ignition switch position and other factors. The feed from cabin fuse 1 to pin 87 of engine ECU should only be powered when ignition is on. The connection between ECU pin 69 and terminal '86' of the relay no. 1 must be pulled to ground/0V by the ECU to energise the main relay (no.1) which then feeds power to pins 3, 5 and 6 via fuse 13, which I expect are the ones you have probed?
Double check cabin fusebox fuse 1 (10A), and under-bonnet fuses 10 (5A) and 13 (30A). Which pin/pins at the ECU connector did you find lack of power at?
AnnoyingPentium's 2006 Fabia 1.2 12v Ambiente-ish
I'm confident enough to say that test isn't worth doing, actually. The car can't tell the difference between an unconnected trailer light board and a blown indicator bulb unless you tell it there may be a trailer connected via that coding change.
I don't think it would do that double speed thing, but try it by taking out one bulb from trailer board.
Engine ECU pin number 21 in the info I'm looking at, not sure why the disagreement with your diagram.
Driver’s door wiring harness
PM me if you'd like to consider a repair by post. I'd replace the original wiring in the 'flex zone' with extra-flexible ones of appropriate gauge, solder joined and sleeved beyond, in the door area. In terms of part number, there are usually enough variants to make scrutiny of the part number label on your existing loom preferable.
It's the other (white/green) wire you need to check, the one to the engine ECU from pin 1 of the brake switch connector, I think. If you can confirm your engine code I can tell you which engine ECU pin it goes to.
It's a requirement in theory, either an auditory or visual confirmation, so you can tell if one's failed. In practice, I don't think they test towing electrics of the 7-pin variety at MOT IIRC. Won't work if it's an LED lightboard btw, unless you add some resistors in parallel to make them look to the control unit like proper bulbs.
Perfect. If you look in the owners manual you'll see there's a second warning light that should work when you have a tow connected, giving a visual confirmation that the trailer indicators are working (when they are). Should be a dead easy VCDS recode of the onboard supply control unit to enable it. You just add 1 to the existing coding.
Which ECU pin number did you follow to the brake switch connector? Wire colour?
How did the towbar get wired in? Have you got the towing indicator light confirmation on the dash going?
MKIII Fabia battery type: only EFB?
Factory fit battery part numbers, and descriptions, for 2015 mk3s here: LLLParts
'09 Fabia BXW engine stalling while idling caused by electronics..?
The ignition switched (Kl15) supply to the pump module is from a 5 amp fuse (cabin fuse 16) so I think that would blow if there was a short inside. The Kl30 fuse is the strip fuse in the battery fuseholder, but a problem with that wouldn't interfere with any other systems, like the engine as far as I can see. See if you can increase the frequency of failure by adding a Kl15 load, say by switching on the rear wiper. Edit, no, that won't do, it seems to be fed from the 75x rail, not Kl15. Does the car have heated seats? That looks to be fed from Kl15.
Please let us know when you find/solve the problem.
I'd whack another on there if it were me just to rule it in/out, only a few quid. Whereabouts are you?
Not sure it'll be relevant, but as far as I can see these are the various power feeds to the circuitboard that aren't just straight in and out of a relay dedicated to that item, e.g. wipers: a permanent 12V power feed from cabin fuse 22 via the red-yellow wire at XP2/1, a 'key in ignition' (T86s) switched feed from fuse 19, into XS4/2, an ignition on (T75) feed into XS4/11, an ignition on (T15) straight from ignition switch to XS4/12 and another permanent 12V feed from engine bay fuse 11 into XS4/5. It almost looks like a more global electrical problem to me, like an ignition switch 'iffyness'.
11111 1111.1 The Show Us Your Odo Thread! (now 12345 678.9) + Brisky Tree odo fun
Error p2452 after replacing diff press switches
Maybe this set-up doesn't require any such adaptation? Are they not pressure sensors, rather than pressure switches? i.e. they actually output numbers
Is there a way to look-up which option came factory-installed with the car?
Cos it's generally only a small fraction of the full list, maybe a fifth, or even a tenth Ken.
Recent pics of your fabia for no reason, just stick em up!
So? Who's forcing you to click and read?
Stop clicking on the thread, duh.
I just tried Nige's link out of curiosity, and at a glance the only difference to what a Skoda dealer emailed me is that this has a production date where the dealer version only had a delivery date. Quite a significant difference in this case, made on 16/11/04, delivered 01/03/05. PDF link was sent within half an hour of purchase.
No backlight on instrument cluster and all nobs and switches in cockpit.
Where does the wiring diagram you are looking at show as the origin of the 58b power rail? I guess the light switch? If so see if it is is present there when the switch is on, then keep following it to wherever it goes next. The number-plate lights on the rear of the car may be powered from the same fuse, so see if they work or not.
