Water leaking from winscreen scuttle drain into back of engine bay
Hi. It probably is normal in Fabias of this age, but it isn't a drain path that the designers intended, those are at either end of the so-called 'water box' and drain into the wheel arches either side of the car. The removable metal front panel has a foam rubber seal all along its edges, intended to seal the water in, and the wiring has rubber grommets where it comes downward into the engine bay each side. Both of these areas will tend to be leaky on mature Fabias, and can be sealed with the usual Plumber's Gold type sealants if desired. The leaked water probably doesn't present too much of a threat though, so probably not worth doing unless you have some other reason to be delving in that area. Some pics of the drains (horizontal slots through to the wheel arches both sides), general area and sealing efforts here:
What is this ?
Yeah, common failure, snapped off where it attaches to the cam cover? Folks more familiar with the 1.2 tsi will be along very soon.
Anyone making a new claim for the VW Emissions / Dieselgate?
? What if you've never owned a VW Group diesel but you once thought 'hmm, that might be handy'? Too late to claim for emotional distress that it might have been handy and NOxious?
How do I tighten this bolt/screw for the door?
You need what's called an XZN bit, probably in M8 size, but you could check the size by measuring: triplesquaretable.pdf
Diesel Monte's 2001 Skoda Fabia "Project vRSDI"
Be super-careful with your nut/bolt arrangement for the subframe end of the dogbone mount. The bit of bolt that comes through the captive/welded original nut comes very close to the steering rack tube. Steering racks are sometimes wrecked while doing gearbox/clutch work by people mixing up the bolts and putting a 65mm (gearbox to engine) one back in there instead of the 61mm long original. Those extra 4mm are enough to dent the rack tube when the bolt is tightened, destroying the rack.
Air Con Help
Yep.
Air Con Help
Fuse 9 or 11 in the group of blade fuses on the battery fuseholder, 5 Amp (red/violet wire coming off it). Changed position with build date some time in 2005 or 2006, can't remember exactly. It's one of the supplies to the fan control unit.
Air Con Help
There's one other fuse you could check (will look up in a sec), but if the refrigerant is very low you won't get the compressor being ramped up I think, or even if it is, the pressure rise won't be enough to trigger the fan. Shorting thermoswitch connector contacts can be a way of checking radiator fan function independent of the A/C triggering. https://www.briskoda.net/forums/topic/503932-radiator-fan-relay-switch-de-pin/?do=findComment&comment=5659700 If you happen to have a UV torch you can have a look round the engine bay in low ambient light levels and maybe see leak sources if any dye has ever been added when topping up. I have one you could borrow, probably wouldn't cost too much to post. O-rings in the high pressure side of the circuit are candidates if there's no obvious condenser damage etc.
Another key fob question
Check that the contacts that touch the battery are clean, they can corrode or get mucky enough to not make a good connection
Help - Red coolant light flashing, temperature gauge is fine
Unless there was pressurised gas above the coolant, depressing its level. Take cap off, release excess gas, level rises, warning no longer registers?
2006 1.9 OCTY VRS Cambelt
https://www.briskoda.net/forums/topic/497987-engine-code-and-why-its-useful-to-know/
Brake pad warning light
Certainly worth a look.
Front calipers don't need their pistons turning to retract. Big G-clamp or one of those trigger action woodwork clamps should do it rather than a dedicated tool? Even strong hands should do it on such a young car. Pretty sure NSF should have a wear sensor on the inner pad? Is there a connector for one nearby?
problem at low revs 1100-1200, 1.9 SDI ASY
Ah, I see.
SKODA FABIA EML LIGHT
I also remember having to cycle the ignition to clear a warning state, even after putting in a resistor that wouldn't trigger it.
I'm sure you're right, but I didn't want to suggest shorting the loom connector without having tried it myself on a similar car to the OP's without damaging anything.
It was just an idea. 🙂 Why do you post in such a big text size?
Maybe the compression of (one or more of) the cylinders is low, so it struggles to ignite the mixture when the engine metalwork is cold?
On the Mk1 Fabia/9N Polo platform, the level warning circuit can be tested by simulating the tank resistance to check the circuit and potentially see whether the problem is the tank or the measuring circuit. Working from memory, a 56k Ohm resistor plugged into the loom connector does not cause a warning state, a 62k Ohm resistor does. If something of the lower value or less still causes a warning, the problem is likely in the circuit (like a wire break), not the tank. Exact values may differ between models.
Skoda octavia 1999 1.9 66kw
I know the oil pressure warning system takes rpm info into account so this may be why that is complaining. ABS module may also have a use for it so I'd suggest fixing that and seeing what happens.
When did you last count the number of hoses going to an expansion tank chaps?
Quantum Platinum 5w 40 discontinued
VW group changed their classification not that long ago, so that oils for diesels and petrols are more segregated than previously Platinum 5W40 went from 502 00/ 505 00/ 505 01 to just 505 00/ 505 01. Don't know if what's in it changed at all though. I remember looking at the approved oil lists back when I first spotted this, znd there was just one oil left that was approved to all 3 of those specs. Not sure why the change, maybe just to further obfuscate and baffle potential DIYers about what oil they are actually supposed to use in their own cars.
- Quantum Platinum 5w 40 discontinued
