Not revving properly
"3 miles from home and just suddenly lost power" sounds an unlikely way for the timing chain to have slipped. An engine stall, cold start or start-up after the car has rolled a little in gear with engine off would seem much more likely scenarios for that IMO.
Another encouraging thing, they're a better engine than the 6-valve in my opinion. Scary thought.
There are 2 different 3-cylinder HTP engines one with single camshaft, 6 valves, narrow head and spark plugs that stick out forwards in front of the head. The other with twin cams 12 valves and central, vertical spark plugs. This sounds encouraging.
Either keep using it until one of the warning lights is triggered, or set yourself up with VCDS Lite and scan it now. Fault codes sometimes don't trigger a warning light until they've happened a few times. Is it a 6-valve 54bhp 1.2, or a 12-valve 64bhp? Last serviced when? Last MOT tested when?
Is 'eclipse' the same warning light as I described?
See if the emissions warning light (side view of engine outline) comes on when ignition is first turned on. It's not unheard of for people to mask these if they threaten a successful sale...
Do i simply put a new battery on. or does it have to be coded in after ?
No coding possible.
how do i trigger the washer fluid deflict light
If the car didn't previously have this function you will need to change the instrument cluster coding to enable it.
Smashed headlight
I think so, yes. Bear in mind that there is probably more than one type of light though. See if there's a part number sticker visible anywhere on the back end of it and try to match that.
A very odd running issue (VRS)
Could this be a transition from open-circuit to closed-circuit fuelling control? Might be worth trying a new coolant temperature sensor in case this is making the transition happen too early or too late or something?
Window Regulator?
Swapping the window motor over may be the only easy bit of the job...😆
Skoda fabia mkII 1.2 misifring problem
Look for air leaks such as brake servo hose splits or PCV pipe breakages. I think the latter are 'to be expected, sooner or later' on the 1.2 TSI.
Skoda Fabia MK2 5J 2011 Facelift 1.2 60HP Day time running lights
I may have made a false assumption that that white wire was going to a headlight bulb, haven't looked. Erwin Skoda is the official info source that anyone and everyone can access at very reasonable cost. Plenty of threads describing how on briskoda.
With it disconnected from the bulb? Resistance of a cold headlight bulb is remarkably low...
Tweeter issue.
Accidental turning right down of treble output on stereo??
Tweeter issue.
Perhaps not reconnected after lock missions?
skoda roomster tdi air con drain pipe location?
Have a look on the firewall at the back of the engine bay, just near where the heater matrix pipes go through. On mk1 Fabia there's a tell-tale bump in the sound insulation that has perforations around it that reveal the drain exit when torn. Not sure if Roomster is same but I wouldn't be surprised.
There are two grey/white cables that meet somewhere on the way to pin 17 of the white connector, one from pin 5 of each side of the car's a-pillar connectors. Both need to have connectivity to pin 17 and not be shorted to ground.
Might be shorting on its way to pin 5 of the other, nearside, a-pillar connector?
It's correct for pin 16 at the a-pillar connector (body side) to be connected/shorted to ground, that's what an earth wire should do. Pin 5 of same a-pillar connector (and nearside a-pillar connector) need to connect to pin 17 of the white BCM connector (and not to earth/chassis). Not completely clear to me whether your testing above is in agreement with the above or not?
oil pressure switch
Try looking here https://m.youtube.com/watch?v=eon7Ha-Eak0
01117 load signal for alternator terminal DF
Many people wrongly think the DFM wire is a control from ECU that tells the alternator what to do. It's not though, it's just a feedback signal telling the ECU how hard it's having to work.
Maybe a faulty voltage regulator module in the alternator then?
How to close the electric windows when the engine is off?
I wonder if there's something that could be changed in an adaptation channel of the BCM in Fabia mk3 with VCDS?
Yeah the blue wire going into cabin is the one that starts up the alt and loses the battery light when broken. Other brown or brown/red one that goes alt to ECU is the DFM wire. Have you got volts on that one at alternator connector when ignition is on?
