Location of draining tap for radiator on 2.0tsi engine
There probably isn't one. You'll just have to disconnect one of the lowest points in the hose system.
- Can you access AC drain hose from inside the car by removing the glove box? Fabia Combi 2003 1.9 SDi LHD
Does the car still have its original condenser and radiator? Both may be rather blocked with airborne debris by now, 22-years on from build. I just changed both of mine last week. But if no leakage of refrigerant or engine coolant, probably a lot of effort for not much gain. Anyway, here are some photos.
I'll take some photos on my mk1 after breakfast. It is exactly as shown, but mine's RHD, so mirrored. Access from below may be best option if you can't reach from above. It almost certainly isn't the problem with your A/C though. There are many other more likely problems. Have you checked that the radiator fans work at both speeds?
- Å koda Roomster
Å koda Roomster
There's a challenge. Will possibly depend on engine code, which you may or may not know. I'll message you @Desborough so that you can let me know the reg number without posting it publicly. Actually, it might be part of a control module that lives on the cover of the fuel pump. Under rear seats and carpet. Photograph whatever you can see there.
See this thread for some manufacturer drawings of the position (item 8* in first image, item 5 in second), both show a LHD car; RHD has the drain on the other side of the matrix hose connections. AIR CON LEAK - Skoda Roomster (2006-2015) - BRISKODA Item 1 in the second image shows the flap of material that can be torn upwards to reveal the drain. There are perforations in the material, like on the edges of a postage stamp.
There is no hose, just a short plastic tube coming straight out of the bottom of the evaporator housing. It can be found under a flap of soundproofing, in the engine bay. You'll see that there's a lump in the sound insulation next to the two heater matrix hoses, tear or cut that material and you can see it. The lack of dripping condensation may simply be because the sound insulation which the pipe drips onto is providing a good evaporating surface in hot weather.
VW Caddy Pickup (Felicia) Fuel Gauge Always Full
Probably just some folks not spotting that the file has landed in their download folder, and that they need to open it from there; at a guess.
Fuel Gauge Problem
Typically mounted on the side of the fuel pump assembly, with the float arm coupled more or less directly onto the wiper. If it's a petrol engine, opening the tank is quite hazardous, and not usually very easy without the right tool to undo the locking ring.
Opened fine for me as it was.
Fuel Gauge Problem
Shown as a simple potentiometer on the wiring diagrams.
- Battery coding help needed
skoda fabia 2006 swinging arm bolt.
If you only have one console to change, just undo what's holding it on, and take it off. No need to move the subframe at all IIRC. I didn't send you any manual, I just showed you where to find it on this forum.
I think the fixing bolts they're referring to are actually special things that fit within the 17mm holes of the console. They are designed to maintain the position of the console relative to the chassis holes. I think they're only any use if you're dropping the whole assembly, both consoles and subframe, all as one unit. I guess you're not doing that, so forget those locating tools and just make sure the car isn't twisted, as I think I've already mentioned, and try very hard to fit the new console in the same position as the old one, despite the very big clearance of the bolts in these 17mm holes in the consoles. Do this by noting the clean/dirty paint areas that the original console will have made on the chassis. Maybe add some spray paint of your own to enhance the contrast.
How to remove the headlamp range adjuster switch...
I'll message you in a sec, but it looks like there are some retaining tabs each side which you have to get at from behind, via where the fuse box is fitted, then it goes 'out' inwards, towards front of the car (unless I'm reading it wrongly).
Replacing oil pressure switch(es)
Please supply reg or VIN to enable proper look-up of PNs.
Two questions for Roomster owners, please
Nice one John, thanks for the part number. Could be still available, at first glance. 😀 Edit: ^ Not according to Fish Bros in Swindon, tried to order yesterday. LLL parts are showing it at nearly £40 plus no doubt a good chunk of postage cos of the length of the thing. Will have to make something instead.
2006 Fabia 1.4 16v 6Y2 (75hp) problem..
IAT sensor is co-packaged with the MAP sensor. It's the little black bit that sticks out the front. Most people think they're cleaning the MAP sensor when they're actually cleaning the temp sensor. Pressure sensing bit is deeper behind that. Ringed in yellow here:
- Skoda Manuals - PDF's
- Window motor repair service
Power steering pipes part numbers.
According to partslink24, the 893E and 893F are both superseded by 893H, so I guess that makes all of those interchangeable. The -H was dropped in Feb '22, the others much earlier. The 891F was dropped in Sept '23. Not much help, sorry.
Match the final 8 characters of your VIN against the various ones quoted (after 6y-) against each of the pressure hose part numbers. If unsure, pop those characters here and I'll help.
Think it's this diagram actually, all UK systems are TRW, I believe. Obviously the ones labelled rhd, with part numbers starting 6Q2. All unavailable new AFAIK, sadly. https://www.lllparts.co.uk/catalogs/skoda/ALL/FAB/453/4/423/423050
- Just bought a new Fabia, questions regarding reverse lights and fog lights
