Breezy_Pete
Sponsor
  1. Is there maybe a washer left behind stuck to the gearbox from the old switch, which is making the distance wrong for the new switch? If that isn't the probIem, I would get a genuine new switch, personally.
  2. Yes, measure for volts on blue wire contact of alt plug with ignition on.
  3. Can you see markings next to the two way connector on the Bosch alt? Should say L and DF, I think, if it's the correct type.
  4. No, it's just a (very) little air filter.
  5. Yes, it should latch on and generate its own field current once it starts charging. Yes, probably normal for revs to be limited out of gear, not moving.
  6. It's known as DFM, Digital Field Monitor. It informs the engine ECU how hard the alternator is being worked, as a percentage of its maximum capability at any given engine revs. It being broken would not have the same effect on the warning light. That other wire changes colour at the 4-way connector from brown/red to violet/green before heading onward to ECU. The blue wire goes onward, still blue into the cabin, to the BCM (Onboard supply control unit).
  7. There's an intermediate connector pair between the two-way connector at the alternator and the final destination of the two wires. It's a 4-pin plug/socket pair 'front left in engine compartment'. That's left as experienced sitting in the car facing forward, so on the right side of the engine bay if you are standing in front of the car looking in. I would try to locate and inspect that connector pair before necessarily blaming the alternator connector, you may find a broken blue wire there instead.
  8. Latch was probably broken when removing from old alt. Not a warning light bulb, it's an LED; but the wire that excites the alt, the blue one in that two-way connector, helps the alternator 'boot up' when engine is starting. It indirectly results in the warning light coming on, or not doing. Yes, if the blue wire is not connecting to the alt, either at the plug or somewhere on route to it, the warning light will not work. Generally, a burst of revs (2500, say) will start the alternator charging, even without the blue wire being intact, so try that as evidence that the replacement alternator is itself OK.
  9. @JonLongstaff are you selling or scrapping?
  10. I'm seeing belt. A difference as significant as a change of timing mechanicals would surely result in a different engine code, I'd imagine.
  11. Did the immobiliser chip get moved across from the old key? That's not on the circuitboard, nor in the key blade. Small glass tube a few mm long. Needs gentle removal.
  12. Undo item 28 bolts: Car Parts Catalog - LLLParts
  13. Can you unbolt the bracket that attaches it all to the side of the head, so you can work on the bench/in the vice?
  14. Is it the metal pipe that won't come off, or the EGR itself? If metal pipe is off, is the outer metal gasket off too? Remembering now that I moved that outer gasket along threads to the end, but left it on to hold studs parallel while freeing the valve body.
  15. A decade since I did the one on our Fabia, but I seem to remember that the studs had become a bit non-parallel over time. Think I somehow squeezed them together, or pushed them apart at the ends to square them up, then prize the thing off. Might be corroded on with white aluminium oxide jamming everything up too. Heat will probably help.
  16. Hi Bill, yes I can sort that for you. I'll send you a message with phone/whatsapp number in a sec. 👍
  17. Hello @langhede , that's a good question, but the answer depends on which 6Q1959801 you mean. The crucial information is contained in the letter after the core 9-character part number. Older Mk1 Fabias (pre-facelift) used 6Q1959801A in LHD cars, 6Q2959802A in RHD. Mk2 Fabias, from around 2008, went back to a 6Q... part number, but this time the end letter is F/G/H/J. The 6Q1959801A and 6Q2959802A have three connectors, in contrast to the two on a 6Y... motor. They are involved in mirror control, the reason for the third connector. They also use two-wire CAN for communication connected to the convenience bus. The 6Y...motors use LIN, single-wire comms with (only) their passenger side counterpart (and rear motors if fitted). No involvement in mirror control. The later ones (2008> approx), 6Q....F, etc, use a single 16-way connector. Also LIN-connected only to other window motors. No involvement in mirror control. I will try to add some photos later today, when I have some more time. Edit: see below. Note: the character sequences I've written in brackets relate the last line of the part number labels to the model that they are from/for. If you mismatch these, despite having matched the main VW group part number, correct function isn't guaranteed. Numbers in orange are the number of ways in each loom connector, not all will have wires in. I also have some advice on pitfalls to avoid if trying to purchase on the secondhand market, which I will do as a separate post later. Executive summary: beware of sellers who over-generalise applicability, and especially any that seem to have scratched out characters on the part number label.
  18. I would look what prices I could find for 2nd hand genuine too though.
  19. This is probably your cheapest route to new genuine- https://www.lllparts.co.uk/product/1K0906627B/vag-pressure-converter-1k0906627b
  20. That depends which calipers you have. FSII calipers (239mm discs) have an M8 thread. 6mm hexagon bit to unscrew bolts. FSIII calipers (256mm discs) are an M9 thread I believe. 7mm hexagon bit to unscrew pins.
  21. Hiya Poopy, welcome to Briskoda. Please do contribute to this post at some point. 😁 https://www.briskoda.net/forums/topic/220601-what-made-you-choose-your-username/page/17/#comment-5925982
  22. A tool that you may need, and may not have, is a 9mm 12-sided socket. This is for the M7 screws that hold the clutch pressure plate to the flywheel. I can lend you one if you want to get in touch (and I can find the one I bought!).
  23. @ords's part number is correct for your VIN - 06K109121B. £24.80 + VAT at Skoda.
