1.6 TDI FABIA 2011 PLATE PARASETIC BATTERY DRAIN FROM RADIO
@Dabber2024, from what you say about the dash display correctly showing door open/closed status I'd imagine there's nothing wrong with microswitch or its wiring. Rather, when you go to enter the car, the interior monitoring sensor is picking up your movements and triggering the alarm, assuming you have 'locked' the car and so set the alarm. Unfortunately, I don't expect VCDS lite will work on a mk2 Fabia built from March 2010 onwards. Can't remember exactly why not, but never heard of anyone trying and succeeding with a Fabia younger than this.
Probably moving to an Audi A4 (update 21/03/25 - or will it be a Roomster?...)
New genuine stat and temperature sensor ordered from a VW dealer, and a new stat pipe/housing bit from aftermarket/ebay seem to have finally put the cool running fiasco behind me a few weeks back. That was a ballache! In other good news, I took a punt on the cheapest of 3 MAFs GSF were suggesting for my reg (Hella branded), and it seems to have ended the driveability problems I was having. Smokeless and smooth now. Much more enjoyable drive.😎
For your car, the catalogue says 1K8951605B, [my emphasis on the 8] which has been superseded by 1K0951605F the latter retails at £207.50 + VAT currently in UK.
Thrower ring, end driveshaft orientation
- Thrower ring, end driveshaft orientation
- Is Carbon Petrol Filter included in Skoda Service Schedule?
I presume they were referring to the charcoal canister, a part of the evaporative emissions equipment. An unusual failure point and definitely not a service item. Liquid fuel does not go through it.- Oil Separator, 1.4TSI CHPA EA211
The part appears to be pretty cheap, but I can't quite tell from the photos here if there's a separate gasket, or it's integrated. Looks more like a groove for a gasket, or for sealant? Volkswagen / Audi / Seat / Skoda Oil Separator 04E103464AM - LLLParts Might just be able to remove, clean up and re-seal your one, if it is a sealant fit. Access may be awkward; dunno. It's on the front of the block.- New parts now steering super heavy
And have you checked that they are on the correct sides of the car, since I posted that photo showing how it looks like they might be possible to fit on the wrong sides? A photo from below with a phone camera at arms length might be enough to see.- New parts now steering super heavy
Did I understand correctly that you have changed the lower arm balljoints? That's what I understood from your statement below Not sure because just yesterday you quoted me but then showed a photo of the track rod end, not the lower arm balljoint? Did you change these: or not?- Front Left Suspension Damage VRS MK2
Yep, just the shaft, unless there are other bits on the whole leg that might come in useful?- Front Left Suspension Damage VRS MK2
Looks like left driveshaft part number is 6R0407763E currently. Secondhand via ebay may be best bet for a quickish result.- Front Left Suspension Damage VRS MK2
Can you message me with VIN or reg plate?- Struggle to start, ECU fault's ?
Unplug the loom connector from the coolant temperature sensor and have a close examination of the mating face. Look for signs of wetness or corrosion. Sometimes coolant temperature sensors fail in a way that makes them leak pressurised coolant into the connector and wiring.- Forgive me FABIA for I have sinned :(
Would be interesting to see what the torsion value is currently. VCDS measuring block 4, last field if I remember right. Just make sure you get the right locking tools and right info before starting the cambelt job.- Tech help on permanent live please
That Amazon item I linked above really does go to zero current when the red switch is off. 13mA when it's on and doing nothing other than displaying the voltage though. More current still as each pushbutton switch for the outlets is enabled (blue LED on each), even with nothing connected to them. I wouldn't leave it with voltage display left on, unless I was actively monitoring the voltage in the short term.- New parts now steering super heavy
Yeah, they probably don't fit the hole pattern if they're on the wrong sides, But worth a quick double-check, I think.- New parts now steering super heavy
Camber can often be equalised, rather than individually adjusted, by moving the whole subframe relative to the body. A delicate process if you don't want to have to iterate too many times though, I think. The caster is odd though, any chance the ball joints are handed, and fitted to the wrong sides?- Tech help on permanent live please
Citigo is the only Skoda model that has it ignition switched, as far as I am aware; all the others have it permanently live. I don't think there's an easy way to make it ignition switched on a mk3 Fabia, but hopefully some mk3 owners reading this will be able to help. I bought a switched multi-way adaptor recently that may do the job, but would require him to remember to switch it off. https://www.amazon.co.uk/dp/B0CSS7DVJF Haven't actually checked that current drawn goes to zero when the red rocker switch is off, I should do so. Thought I might be able to get into it and look at the wiring, but it's well sealed.- How to keep our Roomster on the road
Yes, I had a quick look at pictures of the 1.2TSI (CBZA or CBZB code?) on ebay, and there looks to be a bunch of turbo/exhaust stuff in the way of getting to the back of the alternator. It may well have to come out I should think, to access the regulator/brushpack. Have you got a multimeter with which you could measure some voltages before/after starting engine?- MOT Fail - PS Pipes & Stability Control Malfunction.
You're right about the MIL, shouldn't have been relevant because: "You need to inspect MIL fitted to diesel vehicles including hybrids with 4 or more wheels and first used on or after 1 July 2008." The 10 minute warning light is almost certainly either the replacement alternator wasn't compatible, the connector at the alt was not refitted, or was broken, or the DFM wire (the one that isn't blue) between alternator and ECU. If you let me know build date of car, or reg or VIN I can look up exact circuit info. Wheel arch liner removal will obviously be a good start in accessing the PAS pipes. Never got down and dirty with them myself though. Repair of what you have may be the best strategy, followed by trying to find some better condition ones from scrappies.- Stubborn O2 sensoe remove al
Cleaning the surface you can actually get at when it is removed will make no difference. You're wasting your time on a guess.- How to keep our Roomster on the road
Yes, I think that's a good idea. Not sure how easy access is.- How to keep our Roomster on the road
I don't think this can be the problem. In Fabias, when this wire that energises the alternator breaks, the red charge warning light stops working. I believe your experience prior to the breakdown was that it was working. Just turn on the ignition to the point where lots of warning lights self-test, and check that you see the red picture of a battery. If you do, that wire isn't broken.- Cluster repair, and clock spring replacement
Do you know what damage the cluster has?
