superbdreams
Everything posted by superbdreams
  1. That sounds like the dreaded emissions fix (sic)
  2. I dont know what you mean by that, i stream music from my s20 over bluetooth and still have full control of my phone, perhaps you have allowed the wrong type of connection, i use hands free protocol (hfc) not sim direct (premium) on a C revision bluetooth module.
  3. I do not believe that they do. you also need a different shark fin aerial and to program the head unit.
  4. no. that is an earlier one, the letter at the end is a revision number and you need D or E or later
  5. been covered so many times. use the search. this is the most comprehensive result
  6. Should this be moved to octavia forum not superb 2 ?
  7. There is a manual adjustment for headlamp height, there was a post many years back showing where and what to do. in that case it was because they were set too low which was echoed by others who replied to the thread. the search should reveal the post.
  8. use the search, then select this forum. i put the word sounder into it and got many hits. this is teh first
  9. auto dimming mirror L&K spec
  10. I believe there are two. one front behind the instrument cluster and one behind the rear piller. there are threads on here showing where and how to replace and i think part numbers so use the search.
  11. did you post that in the wrong thread. he is asking about seats?
  12. Model: Skoda Fabia 1.4?? or superb mk2? alarm horn batteries fail. suggested replacement art 7 years.
  13. A thread from many many years back suggested the only way of achieving this would be by adding a relay. (i think in the drivers door-i do not recall any further details but it is here somewhere)
  14. I am glad you said that, i found the site linked to be somewhat suspicious.. spelling issues, download link hidden so can not be checked with virus total. I will be staying with the last official release.
  15. i could only find the team heko ones when i searched and refused to buy as i wiol not have "team heko" etched into them.
  16. something rings a bell about a new bosch sensor that had been manufactured with reversed polarity. symptoms pointed to a faulty sensor, replacement did not fix until after weeks of investigation the wires were cut and reversed, they had discovered using an oscilloscope the wave form produced was backward. trouble is i can not be sure it was the crankshaft sensor now but it rings a bell.
  17. not so much when you want to clean them and they are full of squished bugs..
  18. saloon or estate / twin door. if twin door it is the wiring loom. if not the bulbs may have gone high resistance, take one out and look, it may be glossy grey instead of clear.
  19. Because they could charge an extra £500 to enable it.
  20. search the forum for dsg thermostat. assuming yours is a DSG (auto gearbox) that is your answer .
  21. I have eventually found a repair kit for the superb drivers door loom that has (should have) enough wires for the sound system L&K superb. Cost is £30 from the auction site and comes from France. Cable length [mm]: 400.0mm Number of conductors: 28 conductors Number of threads: 28 Cable section [mm²]: 0.50 to 2.50 mm2 flexible silicon cables with the socket end connectors pre crimped. Bag of different sized crimps for the repair ends. ebay link rarely work after time so as well as the page i will include search terms. https://www.ebay.co.uk/itm/334424640004 Repair Kit Beam Of Door for Citigo Fabia Rapid Roomster Superb Yeti 28 wires skoda loom repair kit
  22. i AM BEING INFORMED THAT i AM WRONG AND WITH THE SOUND SYSTEM IT IS SUFFIX CN not DF sorry for the caps. 3T2971120CN
