New Croatian VRS 236hp 19inches
Global green HPC 20 window tinting
Edited by davojuri
  • Replies 1.2k
  • Views 180.6k
  • Tom from sem motorsport decided to make some more  of his big port passenger side (LHD) intakes for me after seen my build thread. At first he rejected me,and after few days me being desperate and con
  • Pay attention to fine precission tools and protein drink
I was in Sparco EVO3 -to wide for me.
Haven't got chance to sit in EVO2.
Might be also good one.
Narrov and taller.
  • 3 months later...
Updates in blue
JBS K03 cast upgrade manifold double ceramic coated from inside and outside
42DraftDesign 3" modular race (decat) ceramic coated downpipe
OE EGT probe from 225hp
Miltek cat back resonated 2.5 inch system
Denso Iridium IK 24 pregapped to 0,024"
Hyperboost adj. DV
Ecotek Emissions Control Valve CB26-P Blue
Piperross Chrome Valve for CB26-P
ECS Tuning Adjustable FPR
034 fuel pressure gauge
034motorsport Vortex breather kit
ECS Silver Lightweight/Under Drive Pulley Set For 1.8T/2.0
Fluidampr Crank Pulley for Late 1.8T Engine
Gates racing timing belt blue T306RB
ARP crank bolt
Air intake VDT www.modshack.com
MAF Audi TT 225HP
Air diffusor and 90mm air duct to air box
HKS turbo timer
www.rsrmotorsport.com new custom remap on MAHA LPS 3000
K04-001 turbo,
Siemens Deka 440cc injectors
Large port intake manifold 06A 133 223P
034motorsport Phenolic spacer with transition from large to small port head
New South Performance large on the intake side and small port on the cylinder head side
AGN smooth valve cover-polished
Forge FMIC- FMSKOFMIC
Forge TIP FMGOLFIND
Forge Silicon Turbo Hose Kit 1.8T 180 FMKT005
Forge DV relocation kit 150/180hp 1.8T
Forge Quickshifter 5spd FMVAG5QS
Mishimoto Radiator Hose Kit MMHOSE-GLF-99BL
Verdict Motorsport Shift Bracket Bushings 42DraftDesign Mk4 & Mk5 Shifter Cable Bushings Fitment Guide
SFS performance custom TIP
LCR (or Lamborghini Galardo) 4bar fuel pump sender unit 8L0919051H (thanks to your site I found perfect match without starvation problems that I had with 044),
Neuspeed 1.8T 180 Degree Thermostat
Neuspeed 180 Degree 3 Pole Fan Switch
Neuspeed Connector Conversion Kit for 3 pole fan switch
Neuspeed Front Anti-Roll Bar 25mm
Neuspeed Rear Anti-Roll Bar 28mm
Neuspeed Lower Strut Brace Billet
APR carbon strut bar
SPEC SV363F Skoda Octavia 1U 97-05 1.8T STAGE 3+ clutch
SPEC SV21S Skoda Octavia 1U 97-05 1.8T STEEL FLYWHEEL
D2racing Track racing coilovers
Ground Control camber caster kit
SPC Performance Camber and Toe Shims 71520 and 71530.
Audi TT Sport Spindle Audi A4 75mm front bearings with two meqssure for inner diameter- can sustain greater axial pressure than OE 74mm ones-required custom work to be done
LSD QUAIFE QDF10R
02J 6 speed custom made powder coated gearbox with Quaife LSD
1. 3.7; 2. 2.2; 3. 1.6; 4. 1.25; 5. 1.04; 6. 0.87; Final Drive 3.64
Audi TT bigger tier rods and tie rod ends (16mm thread)
R32 cast control arms with bigger front bushing (OE upgrade)
Powerflex front control arms bushings
Superpro Front Control Arm Lower - Rear Bush SPF3397K-castor increasing
POWERFLEX BUSH PFF85-505
R32 steering rack
Powerflex bushing all around
Zimmermann Formula 312mm drilled front discs,
Zimmermann Formula 256mm drilled rear discs
EBC yellow stuf front and rear pads-track tested by myself-great ones
BHP (Brake Hose Production) braided brake hoses front and rear
Mintex racing brake fluid,
Castrol EDGE Sport 10W60 engie oil,
Castrol TAF-X transmission oil,
Setrab oil cooler 913 - 13 row
Setrab mounting bracket for oil cooler - P/N 23-9002
Setrab 90 and 45 degree and straight one swivel hose 10AN fittings
Mocal oil cooler mounting bobbins
Mocal oil cooler sandwich plate+thermostat SP1T-POLISHED
Black Sandwich Plate Adaptor For Oil Temp / Pressure Sensor 3/4 Filter rspec.co.uk
Starlite nomex/kevlar oil lines AN10 blue FSB1000
Ina engineering Baffled Oil Sump:
http://s537.photobuc...A Baffled Sump/
TWS 8x19 ET35
Falken 225/35/19 F452
Wheelspacers 5x100 6mm 12mm
Painted in red and covered with clear lack rear lights,
Dark grey perforated leather seats and door panel inserts,
Qstarz BT818X 5Hz GPS reciever
Devil eyes headlights-installed BiXenon projector lamps in existzingprojector position
http://s537.photobuc...ith Ring Bulbs/
Bimarco Futura FIA approved bucket seat full leather
BUCKET SEAT FITTING KIT. RACE, RALLY FIA SEAT. BOLTS
Recaro seat subframe with rails-car specific
RING H7 XENON ULTIMA 120% BRIGHTER HEADLIGHTS BULBS
RING H7 XENON ULTIMA 120% BRIGHTER HEADLIGHTS BULBS RW127.
LED repeaterts smoke Skoda Octavia (1U)
Speedhut Revolution SST RED Shift Light Brand
Custom paint work done:
http://s537.photobuc...tom paint work/
Polished INA baffled sump, valve cover, boost pipe, catch tank, alternator, intake manifold and TB polished
3M NIMOC High Glossy Carbon black film-door handle, centre console inserts, air vents
Global HPC green 20 window film
NEW Throttle DV hose blue
ALU straight 63mm joiner
76 to 63 straight adapter for
S4 70mm Throttle body
INA TB adapter plate 70m through
Intake manifold port matched to 70mm
Edited by davojuri
VERY NICE :)
attention to detail is very good mate well done
im mounting my oil cooler the same as you ;-)
as same as clive, im mounting one there as well when i get some more pennies to get some more fittings. perfect place for the octy really.
love this build mate.
being surgeon meens being detailed in anything ;-)
Edited by davojuri
That would be why it's so nice buddy
you must change the coolant tank,ruins the looks.Buy a new one ,my oppinion.
Love the car!
Can't find any. Help appreciated.
Maybe a link or picture
I see. Tought he means some kind of upgrade. But This one looks Nice And Clean compared To My Okd,yellow one. Will take it Now cause I Have to Install 9 silicone Mishimoto Coolant Hoses.
Tnx!
Edited by davojuri
Will it fit my 2001 octy?
Forgot to mention
USP Motorsport stainless steel Clutch 02J line for OE plastic slave cylunder, they also have it for metal VR6 slave cylinder
http://uspmotorsports.com/product_info.php?products_id=466
Edited by davojuri
yeh the golf expantion tank will fit. :)
Shoping already. Thanks for info-nicer, ckeaner look
Finally got my polished fuel rail from liquidmetalrefinements.co.uk Matt did a great job:
http://s537.beta.photobucket.com/user/davojuri/media/Polished%20underhood/IMAG0730.jpg.html?sort=3&o=0
and had to pair it with this adapters:
http://www.ebay.com/itm/160710867143?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
but they can't be installed on to the ends before that nipple is cut and then they are to short have to cut both ends before turn, than you have to sahorten straight parts even more to remove pressed dirrection arrows if you won't water fesdt installation:
http://s537.beta.photobucket.com/user/davojuri/media/Fuel%20line%20adaptors/IMAG0849.jpg.html
http://s537.beta.photobucket.com/user/davojuri/media/Fuel%20line%20adaptors/IMAG0852.jpg.html
http://s537.beta.photobucket.com/user/davojuri/media/Fuel%20line%20adaptors/IMAG0854.jpg.html
I will connect them to AN6 90degree Setrab ones and at the other end the same Setrab
http://s537.beta.photobucket.com/user/davojuri/media/Fuel%20line%20adaptors/IMAG0606.jpg.html?sort=3&o=23
to this adapters:
http://www.ebay.com/itm/170764095775?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
and this one below strut bar because of lack of space.
http://www.ebay.com/itm/160503904926?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
http://s537.beta.photobucket.com/user/davojuri/media/Fuel%20line%20adaptors/IMAG0609.jpg.html?sort=3&o=20
http://s537.beta.photobucket.com/user/davojuri/media/Fuel%20line%20adaptors/IMAG0608.jpg.html?sort=3&o=21
That is all before I run those lines to the oil filter in the back in future.
