CitiGo-Go, a Citigo with more Go.
What brakes did you go for Richard?
I believe it's having these. Correct me if I'm wrong Richard.
  • Replies 2.2k
  • Views 743k
  • Update time.           Waiting on clutch and driveshafts for final assembly of mechanical bits to the drivetrain.
  • Actually my Yeti is done. Until we move to phase two this winter and fit a 2.0tsi.   While progress on the Citigo is slow it will be done one way or another by the end of the year, in time for meet
  • Yes.   One painted Citigo 4x4 shell and plans made for the next stage. Rebuild basics to allow for the loom to be made are being done over the next two weeks. Then a motorsport electrical speciali
Exhaust?
Exhaust?
Don't need that, more weight :giggle:
Exhaust?
Oh yes, that too! :D
In simplified terms...
Three weeks for driveshafts and clutch. Drivetrain then done.
Brakes on the way, brake lines to do.
Seats and steering wheel to sort.
Wiring from Stock Citigo for body/lights to make it road legal now in.
ABS sensors and fuel system in.
Engine loom and ECU to be finished/fitted.
Map and set up.
Scare myself fudging senseless still to do at the end of all this.
Think this is the understatement of the year!
After all this time are you still looking forward to driving it as much as your were at the start?
Or is it a case of the shine has been taken off the project but since you have been busy with other projects and this has come back on line it will be major excitement all of a sudden?
I'd love to be a spectator when you arrive at the track towing the citigo beast with the yeti vrs. And thrash all the other cars on the track. Speaking of which......Next on your shopping list must be your own race track :D
He has.......it's called Surrey :)
Why Surrey of all pothole riddled places??
Edited by vRS19TD
Just sounds posh :)
Just sounds posh :)
It's terrible here. Might be nice around parts of Surrey closer to London but the rest is horrible. It has Croydon in it, which says it all.
And put it this way, if you decided you weren't interested in it at all anymore, could always hand it down to your favourite other citigo driver *cough cough* :notme:
Or you if that other one doesn't want it. ;):D
Epic car... does deserve a bloody epic ball ache to bring to fruition I suppose, glad it's getting there Richard and looking forward to seeing this car too!
I to look forward to stealing seeing it :)
How much is Citigo projected to weigh in at?
I think he mentioned it somewhere, I'm probably way out but 1,200kg comes to mind
Yeti iirc
Yeti iirc
I thought the yeti was going to be the 1,400kg mark? :P
I lose track tbh
I lose track tbh
I don't blame you :D
Well you only have 64 pages to check :D
I used that thing called search ;) I was surprisingly close
'BossFox', on 29 Apr 2013 - 22:06, said:snapback.png
I'm looking at 16" rims.
Stock is 14 or 15 and the UP! and new Citigo Sport model have a 16" option.
I think for stealth 17 would be too big.
You can get some decent brake set ups under a 16" rim. Such as a 312mm kit with decent calipers, which should be fine if we can keep the weight under 1100kg. (even though the target was originally 1000 kg)
Ahh but that was almost two years ago and he's bound to have been thinking about more lightweight panels, glass all sourced by now...... :D
