Grubby engine bay and gearbox
  • Replies 217
  • Views 36.5k
  • Sent from my iPad using Tapatalk
  • Cheers toxicvrs Cheers Matt Best all round car I've ever owned. Not the fastest,most powerful or best handling car I've owned but as a package for a fast daily driver that's good on fuel,cheap to
  • Winter wheels on now with Pirelli sotozero winter tyres   Pleased with how they look tbh.
10 years of crap washed off
Poorly piston :(
Poorly piston :(IMG-20150703-WA0010_zpsdrbqognl.jpeg
Fuk that's proper melted has that, not good you had the cylinder head tested yet or you just scrapped that as well?
Head is scrap,massive dip from cylinder two into coolant jacket,partially melted/dented,bent valve and all cylinders cracked from injector hole to valve seats :(
Wow proper good job then, must have been some mega heat or injector leak to cause such failure, I suppose you can just always 2nd guess what caused but never actually know why it's failed like it has
You sent your injectors away yet to get checked?
United Diesels is only 15 miles from me, so called in there to ask about testing and refurbing my injectors but they want £140 per injector, not much more to go to larger nozzles.
i *******s to that then just fit a set of DSSR90% for £630 and be done with
Well she's back on the road :)
Spent majority of my three weeks summer leave from work messing about with the bloody thing though :(
A big delay was the engine taking a week longer than it should to be delivered,ended up in Llandrindod Wells at a depot with only one lorry fitted with a tail lift that never gets sent on the Oswestry deliveries.
But while I waited for the engine I took the grinder to the front bumper and crash bar,a job I had planned to do this summer.Cut the ends off the crash bar and welded in some 40mm box section instead of the deep standard crash bar,to allow more air to get to the cooler and to make somewhere to mount my number plate to while retaining the strength of a crash bar.
Didn't want to go to a number plate mounted on the side but wanted to able to get max air to cooler on track/pod/RR days etc.
So now I've just got to undo the two bolts holding front plate on and I've got the full widemouth available,on road even with plate fitted I've still gained a lot of air flow to cooler.
Pleased with the finished job :)
Road going set-up:
Track/pod/RR day:
I like that, a great compromise as I don't like the widemouth but obviously know the benefits of having one. Great work.
Been also terracing you thread to get an idea on parts for an oil temperature & EGT gauges. Cheers for posting the links. B)
Wow Fairplay Kev. This is going to be an animal!
So the list is:
Head refurbed(decoke/skim/valves reseated/new stem seals)
Elring gaskets
Raceware stud and nut kit
New lifters
Cam bearings
Cambelt kit/water pump
Aux belt
Gtb2260
Tubular manifold
LUK XMan uprated clutch/DMF
DSSR +130% injectors
Cheers :)
Cheers Joe,any news? :peek:
So the list is:
Elring gaskets
New lifters
Cam bearings
Aux belt
Gtb2260
Tubular manifold
Cheers :)
Sounds erotic. Lol
Sent from my SM-G920F using Tapatalk
Oh yeah got my Pro-Race 3's fitted too,along with rear mudflaps :)
Nice to see it back in one piece! I was getting used to coming round and seeing it still half a car :D   Just like mine - which is currently 1/3 a car!!
Road going set-up:
Track/pod/RR day:
Kev, should've sent me a message mate, only 15 mins from there and could've thrown it in the van :)
Looked very good when I saw you yesterday. Not much smoke either
Sent from my Galaxy S5
New map already to suit the new turbo?
Sent from my GT-I9505 using Tapatalk
Glad to hear this beast is back on the road, how are you finding the 2260 compared to the 1756?
Any close up pics of the work carried out to the crash bar?
Also what was the proce of the nozzles?
Ah right cheers,didn't think really of forum help!
Where did you see me? :)
Base map yeah,standard boost atm due to clutch needing bedding in.
Cheers Adam :)
As above clutch needs running in,so can't really compare 1756 to 2260 yet as I'm running low boost!
Need to adjust actuator too,only 60% at 4000rpm currently.Although its spooling up lovely atm,have asked John if I can leave it at 60% with no ill effects. ;)
I had a extra set of injectors to part ex in against DSSR's,so they cost me just over £500 collected from United Diesels.
Was a car behind you from where you pulled out at Pentons onto the A483 upto the Whittington roundabout. Tried to get past the Polo but couldn't.
Ref the crash bar I haven't got detailed pics soz.
Can see the brackets for number plate after powdercoating:
Had slam panel done at same time ;)
Wow they look great Kev. Who did them?
