VCDS Options
What does teardrop wipe do?
When you use washers the wipers wipe, stop for a while and then perform another wipe to clear the dribbles.
Mine was MPH screen on the maxidot.
Edited by 4743hudsonj
Switch off the seat belt chime/bong,
Activate the cornering fog lights,
Replace the Xenons with the fogs for coming/leaving home lights
Activate the front fogs as DLR in addition to the standard DLR bulb
Show a large digital speedo in maxidot display.
Increase the indicator turn signal from 3 to 5 flashes,
Activate the needle sweep on dash(all the needles sweep from bottom all the way round to the max, then drop back again upon start up. Pointless, but still puts a smile on my face everytime).
No, FL only.
Thanks Mike. I hadn't seen any obvious way so not surprised. Shame though as would have been useful to protect the Xenon bulbs for what is a very helpful feature.
Adam
Not got maxidot on my FL se model but got kmh indicator when I start to move , can I change this mph or can it only be done if you have maxidot, looked around couldn't find option to make windows roll up from key fob,
You need maxidot for the large MPH display.
The comfort closing can be coded with VCDS.
No, FL only.
My list of VCDS tweaks (at least on preFL Octy)
Switch off teardrop wipe front and rear
Switch off comfort indicators
Switch off sychronised mirror adjusrtment
Switch off seat belt chime
Switch on rain closing windows
Switch on Scandinavian DRLs
Switch on anti-hijack
Switch on alarm chirps
Switch on CH/LH lights
Switch on twin rear fog lights
Switch on cornering fog lights
Alter weight of power steering (only on earlier cars)
Calibrate fuel computer
Calibrate speedometer (as much as possible)
Code for HID kit
Code for footwell lights
Mike
Can we have the bits and bytes on these:)
Edited by alberg
  • Like 2
Maybe a silly question as the post is VCDS options, but I am due to be getting a FL Oct VRS in the next couple of weeks and wondered which from these options are accessible and can be changed via MaxiDot or do they all require VCDS?
Edited by amh
I want the ch lh but can't get it to work. I was told I needed to have rain sensor or auto lights. Have tried lots of vcds options.
Anyone with fl 2010 with standard light and no rain sensor got the ch lh working.
  • 6 months later...
Can cornering fog lights be programmed to a 56 plate pre face lift Octy?
Most posts refer to post facelift, just wanted to check.
Maybe... maybe not...
It depends which controller you have as some of the earlier ones don't support it.
I have it on mine and it's a pre-FL MY08 car.
Phil
Thanks Phil, it were registered January 07 so I expect the build date was Nov/Dec 06.
Will see tonight what is on it as I'm getting the lights coded to accept the HIDs.
Also looking to do if it's reasonably straight forward:
Alarm Chrps
Both rear fogs on
Switch on Cornering fogs
Switch on tear drop
Alarm Chrps
Both rear fogs on
Switch on tear drop
You should have no problems with any of those but the cornering fogs may or may not be there.
Just go through all the bytes and see what's there.
Phil
Cornering fogs came in with 07 plate cars.
Not all it didn't. My '07 doesn't and I have tried to enable them.
As above, you need to check you have an appropriate controller fitted.
