Fabia III VCDS Adaptions
any idea to activate cruise control (tempomat) after change from speedlimiter to speedlimiter&cruise control?
these:
01-Engine - Byte 5, Bit 5
09-Cent. Elect. - Byte 18, Bit 0, Byte 21 Bit 2 i 7
are not working, speedlimiter is OK, but cruise control icon on maxidot is with exclamation mark. is required activation in Skoda servis online?
thanks and sorry for my english
  • Replies 107
  • Views 76.1k
  • Here is how you enter Drive Green menu - it's what you see upon pressing Car button and then "Wybór" (choice)   Drive Green menu when you enters it - score starts with 100 and it descreases when y
  • Yep that should be quick and easy. A YouTuber has put up quite a few videos of tweaks available on the Mk3 Fabia. Have a look! Skoda Fabia MK3 - VCDS tweaks - vključitev dodatnih funkcionalnosti
  • First bit of confirmed VCDS coding that works on the Fabia III. Once we get a few more we can add a definitive list into the VCDS forum, as they have done for other/previous models.   Please note th
I believe so- something to do with the component protection system? If you do find out how to do it though I'd be very interested in changing mine to have proper cruise!
for tempomat you need online activation code via Skoda service. or buy complete tempomat set. set up only wit VCDS not working
Can these codes only be activated by the dealer or if i had a code can i do it myself or.via vcds
probably the only vendor. did not get it to me
Hey,
I have a question, peehaps there is soleone who could help me. Formy wife her fabia i would like to install multi function steering wheel. I already have the buttons but still need the wirring. For the coding i wonder if i have to change anything. Now we have multifunction trough the knob for the windscreenwipers ( basic multifunction ). Do i need to change any coding ?
Thnx
On 3/9/2016 at 12:08, czpida said:
Hi there, I followed all above mentioned instructions, the rain sensor 5Q0 955 547 A  is working fine, but I don´t se the possibility in menu/car/ lights to change the sensitivity of the light sensor, I have only the possiblity to change them via VCDS/09/adaptation.
Can anybody help and let me know how to anable this function in my SWING ?  I have Fabia III. combi, 81KW, Style plus.
My current coding is  LONG 0C01085042150AFB43804000402703080800D900D30A3500000000000000 and 00185E for RLHS
Have followed this precisely with a 5Q 955 547 A sensor, but I get an error on the humidity part of the sensor (for the climate control), is there something wrong with the coding of the sensor: 00185E, can someone help me translate 00185E? My car is a Fabia III Ambition 1.2 TSI 110hp DSG 2017 model without light assist and rain sensor.
Here is my long coding: 0C 02 18 50 42 15 4A F3 43 80 40 00 40 35 03 08 00 00 55 00 D3 0A 35 00000000000000
It appears to me as 5Q 955 547 A is not supported, while 8U0 955 559C or 5Q 955 547 are?
Thank you
  • 6 years later...
After replacing the right headlight the DRL flicker when the ignition is off despite the position of the lights knob (auto ,side lights ,low beams) if the ignition is on or the car running the DRL is fine.Also when CH/LH is on it flickers
