VCDS options on Superb III
4 hours ago, Jakec said:
is there a way to turn off "hold the steering wheel" warning and keep line assist?
I hold the steering wheel, but on long straights it just makes no sense to turn left or right, in order to keep the beeping off... and 10s is also way to low of a setting for warning... you have to nudge the wheel all the time :(
Most definitely no.
It's embedded in the car's safety systems.
It's not just a Skoda thing.
  • Replies 2.5k
  • Views 824.8k
  • if anyone is interested, below is a PDF I created of the various code changes I've made to my Superb (MY17) over the years. whilst some instructions r done with VCDS, and others with OBDEleven, t
  • I'm aware the mod for 30 colour pallet in the ambient lighting screen has been mentioned several times on the forum. TLDR: The RGB values used on available in the table at the bottom on my post.
  • Not sure how that would work, by your reconning they would have less need for rear DRL's as they have less daylight hours.   Brake lights are 4 times brighter than a sidelight / rear DRL, th
It's linked to the system technology. The Lane Assist system measures the resistive torque thru the electric motor actuation system in the steering wheel. Thus, if you hold the steering wheel very gently, it's hard for the system to detect any resistive torque. Then it bips.
VW Passat is fitted with proximity sensors in th steering wheel. Thus, even if you're very smooth with the steering wheel, your hands will be detected and it shouldn't bip.
Hang something heavy on the bottom of the wheel...
Not that I'd condone such actions.....just sayin'....
That would be stupid in case of emergency... you can also stick a bottle into the steering wheel, but same stupidity in case of emergency.... 12s is low... i would say 30 would be less annoying... at least in Europe...
On 01/07/2020 at 14:45, dimp said:
In 2q0 A5 camera you can get sign assist only using swap activation( Without it you get only events in the control modules
I’m new to all of this. And not yet understanding it sll
can this be done with obdeleven? I have the A5 camera and adaptive cruise control plus lane change assist on my 2020 SEL
before I buy an obdeleven, I wanted to see if it woukd be worth it
thanks
thanks
No, you can not.
Ok, thanks. So I have speed limits showing on the nav screen, as well as ACC, Lane assist and Kane cgangecassist.
as I understand ut, it needs a SWaP file to enable traffic sign recognition on the instrument binnacle (not digital screen, analogue dials)
woukd my Skida dealer enable ut for a fee, or is there another way? Non Skida dealer?
thanks
Hello,
I have an activated sign recognition option on my superb 2016 with amundsen mib 2 unit. After updating the newest maps for my region i noticed that the database doesn't have a data file for street signs. As a result it doesn't show street signs info from database, but only from the front camera, !!!when the maps sim card is out!!! My country is on the list of supported countries for this option. Is there a way to provide this files  within maps database, to avoid turning off the sinhronization (btw. camera and database) option  using VCDS?
Thanks,
Dan
Hey all. Can anyone with 21MY share vcds dump with all adaptions?
What to compare with my Kodiaq MIB3 (21MY, H22 027)
Hi does anyone know how to recalibrate display number five in vc? I'm talking about the exact power quoted there. ( my target is 140KW) but because I have more of them now I want to have the real power there
I believe the max figure is provided by the ECU.
Your tuner may need to increase it in the ECU software for you :)
On 2.02.2021 at 23:24, langers2k said:
Uważam, że maksymalna wartość jest podawana przez ECU.
Twój tuner może wymagać zwiększenia go w oprogramowaniu ECU :)
Interesting, so for now I won't do it because I use an external box, thanks B)
On 22/01/2021 at 08:58, Danijel2207 said:
Hello,
Thanks,
Dan
I  have an MY2016, which I recently upgraded to 2021 maps, and I don't think I have a front camera. The speed limits show up on my nav, so must be coming from the maps db?
If u don't have the front camera, than that's  the case. In my case somehow the maps database sim when in, excludes the camera from showing signs... The option in VCDS is called "fusion mode", and for some reason doesn't work in my country - Montenegro (which is on the list of enabled countries for this option)....
Was anyone able to adjust the speed when high beams turn on automatically with VCDS? As standard it's 60 km/h.
No one has been able to crack this one yet.
It's not just a Skoda thing - same deal with VW and Audi.
It's embedded in the parameter file, somewhere.
Most definitely cannot b accessed or altered via VCDS or OBDEleven.
Having said that, my SLA function activates at 40 km/h, not the usual 60 km/h for HBA.
Prior to retrofitting the SLA headlights, my HBA used to activate at 60 km/h.
Edited by JR RS
On 10/02/2019 at 11:01, Gizmo said:
You need VCP to enable VIM
I've done it today without VCP, just a combination of VCDS and M.I.B. Toolbox  which is software you can put on the SD card. for those like me who have MIB2 or 2.5 HIGH (Columbus). VCDS to enable developer mode on module 5F , then patch ifs root using MIB toolbox, then into the GEM greenscreen developer menu, and it has VIM options to set the speed that the VIM lock kicks in
Hi all .
I am new here . And I wanted to ask a few things. I bought OBDELEVEN PRO.I already have it coded.
START STOP -OFF
CH/LF as Foglights
 Enabling rear lights with DRLs
Enabling fan (blower) speed display in AUTO mode
unfolding the mirrors after starting
 And I would like
cooding any interesting things (opening 5 doors from the interior?) and more?
Sorry for my Englis. I am from Czech Republik
My car is Superb 2017 DSG 4*4 LaK
Thank you very much
On 20/06/2020 at 15:31, fergard said:
I've activated Lane Assist on the 2020 Superb with new camera!
Could you say how you did it?
Anyone knows what could be wrong there? Hopefully not the high pressure fuel pump... :(
Fuel pump
ELM bluetooth adapter + android app.
https://www.drive2.ru/l/562924115971802149/ use google chrome built-in translator if you need english text.
Can You please let me know if the prcedure enables traffic jam assist as well? I mean, below 60 km/h (with ACC active), the lane assist remains active?
Edited by Enriquez
No, I don't have this feature.
Let me know if you find a way to enable it on M.Y. 2020+.
Hey all,
I have read here, on the forum, that it is possible to disable (or make quieter) the super annoying noise generator, but sadly I have not been able to find any explanation how to do it... or which software/tools are able to change it. Does it have to be done via VCDS or maybe VCP will be OK as well? I have currently access to VCP only, that's why I am asking. But.... if VCDS would be the only option, I think I will be buying one just for that :)
I would really appreciate your help on this.
Many thanks,
Kuba
18 minutes ago, james888 said:
Hey all,
Many thanks,
Kuba
The Superb doesn't have the sound generator.
