VCDS options on Superb III
1 hour ago, j caff said:
My camera doesn't turn on when approaching an obstacle a black section appears on the screen with a diagram of the car showing where the obstacle is.
I had that issue when i replaced my camera for another version of the highline camera because i wanted to retrofit the trailer assist, solved it with an updated gateway!
  • Replies 2.5k
  • Views 791.1k
  • if anyone is interested, below is a PDF I created of the various code changes I've made to my Superb (MY17) over the years. whilst some instructions r done with VCDS, and others with OBDEleven, t
  • I'm aware the mod for 30 colour pallet in the ambient lighting screen has been mentioned several times on the forum. TLDR: The RGB values used on available in the table at the bottom on my post.
  • Not sure how that would work, by your reconning they would have less need for rear DRL's as they have less daylight hours.   Brake lights are 4 times brighter than a sidelight / rear DRL, th
Why would you need the reversing camera on when the object being detected is in front of you?
Well i guess thats just the way it works, if the system detects and obstacle and turns on, then it shows the rear cam on the right, and the sensor graphics on the left of the screen!
I just checked mine while driving in my front gate which is quite tight, the radio stations stay on and the black panel overlays them from the left showing a graphic of the car etc. The camera doesn't activate. I've never tried pressing the P button I'll try that later.
Mine does that as well, but, it stays like that only if you dont go any closer to the obstacle, once the color of the bars change from orange to red it switches to the cam view!
Very good I'll try that later too.
Drove as close as I dared to the front pier but the camera never turned on.
ill take a video for you tomorrow morning or later this afternoon!
Hey VCDS experts, please help me,...
I have a Skoda Superb 2020 TDI 150 with matrix headlights.
The headlights go out late in the morning and likewise turn on in the early afternoon.
I have actually tried all the combinations proposed here in this forum but I'm not succeeding.
Is there anyone who can help me change the time for turn on and turn off (morning/evening)
I inserted a 00 scan
Language is Danish.
Søndag,20,Februar,2022,08:42:10:21211
VCDS -- Windows baseret VAG/VAS emulator - Kører på Windows 10 x64
VCDS version: NEZ 21.9.0.6  HEX-V2 CB: 0.4608.4
Dataversion: 20211214 DS330.0
www.vcds.dk
Forhandlernr.: 123 12345 023456
Stelnummer: TMBJH7NPXL7029111   Indreg.nr.:
Modeltype: NP-SK48 (3Q0)
Søgning: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 47 4B 52
          5F 69 6C 6D 75 A5 BB BC D6 D7
Stelnummer: TMBJH7NPXL7029111   Kørestrækning: 43363km
01-Motor -- Status: Ok 0000
02-Automatik -- Status: Ok 0000
03-ABS bremser -- Status: Ok 0000
05-Adg./Startkodning -- Status: Ok 0000
08-Klimaanlæg -- Status: Ok 0000
09-Centralelektr. BCM1 -- Status: Ok 0000
10-Park.assist. -- Status: Ok 0000
13-Afstandsreg. 1 -- Status: Ok 0000
15-Airbags -- Status: Ok 0000
17-Instrument -- Status: Ok 0000
19-CAN Gateway -- Status: Ok 0000
23-Bremseforstærker -- Status: Ok 0000
2B-Ratstammelås -- Status: Ok 0000
36-Sædeindst. V for -- Status: Ok 0000
3C-Kørebaneskiftass. -- Status: Ok 0000
42-Dørelektr. V for -- Status: Ok 0000
44-Servostyring -- Status: Ok 0000
47-Soundsystem -- Status: Ok 0000
4B-Multifunkt.modul -- Status: Ok 0000
52-Dørelektr. H for -- Status: Ok 0000
5F-Informationselek. -- Status: Ok 0000
69-Anhængertræk -- Status: Ok 0000
6C-Bak-kamera -- Status: Ok 0000
6D-Bagklapelektronik -- Status: Ok 0000
75-Nødopk. Kommun. -- Status: Ok 0000
A5-Frontkamera -- Status: Ok 0000
BB-Bagdør førerside -- Status: Ok 0000
BC-Bagdør passagerside -- Status: Ok 0000
D6-V. lysstyring 2 -- Status: Ok 0000
D7-H. lysstyring 2 -- Status: Ok 0000
Styreenhed  01: Motor (J623-DSRB)     Forklaringsfil:. NEZ\05L-907-309-V1.clb
   Styreenhedsnr: SW: 05L 906 022 BK    HW: 05L 907 309 B
   Komponent    : R4 2.0l TDI   H30 9971
   Revision    : E3H30---    CVN: 0CAFA393644B2C53FDCF42ED644B2C5343FB2DAA
   Kodning    : 012504320474050830000000000000000000000000000000
   Forhandler    : WSC 30815 005 1048576
   ASAM datasæt    : EV_ECM20TDI01105L906022BK 006007
   ROD: EV_ECM20TDI01105L906022BK_006.rod
   VCID: 71BFDA57112C373358B-8024
   VINID: 91D49A6077A0A1C1C0089041048AF7D62C
Ingen fejlkoder fundet.
Readiness: 0 0 0 0 1
Styreenhed  02: Automatik (J743)     Forklaringsfil:. NEZ\0BH-927-711.clb
   Styreenhedsnr: SW: 0GC 300 046 D    HW: 0GC 927 711 H
   Komponent    : GSG DQ381     H06 2402
   Revision    : 00H06V09    CVN: AC91F53A
   Kodning    : 0014
   Forhandler    : WSC 00000 000 00000
   ASAM datasæt    : EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061.rod
   VCID: 2B03083FF3801DE3227-807E
   Ingen subsystemer:
Styreenhed  03: ABS bremser (J104)     Forklaringsfil:. NEZ\5Q0-907-379-IPB-V1.clb
   Styreenhedsnr: SW: 5Q0 614 517 FA    HW: 5Q0 614 517 BR
   Komponent    : ESC           H82 0190
   Revision    : 00000000    Serienummer    : 62809000000757
   Kodning    : 1E077A9C31223B754778060160C449785E8CDCE2600692753861F078D2A24A0B0003000012121212B835351919323200
   Forhandler    : WSC 00033 790 00105
   ASAM datasæt    : EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 75B7EE4765441B13843-8020
Styreenhed  05: Adg./Startkodning (J518)     Forklaringsfil:| NEZ\5Q0-959-435.clb
   Styreenhedsnr: SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Komponent    : VWKESSYMQB    037 1307
   Revision    : 00037000    Serienummer    : 0529914807
   Kodning    : 0F20000723
   Forhandler    : WSC 131071 1023 2097151
   ASAM datasæt    : EV_KessyHellaMQBAB 004052
   ROD: EV_KessyHellaMQBAB_004_SK25.rod
   VCID: 45D75E877524CB93D43-8010
Styreenhed  08: Klimaanlæg (E87)     Forklaringsfil:| NEZ\5G0-907-044-CLI2.clb
   Styreenhedsnr: SW: 3V0 907 044 FA    HW: 3V0 907 044 FA
   Komponent    : AC Automat    H34 4803
   Revision    : 20K10000    Serienummer    : 00000B01508394
   Kodning    : 12010104002110011005104C00105026
   Forhandler    : WSC 12345 123 23456
   ASAM datasæt    : EV_ACClimaPrehVW37X 002027
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 78A9E7737256667B9F5-802C
   Luftkvalitetssensor:
   Undersystem 1 - Styreenhedsnr: SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Komponent    : G238 _AQS  H30 0119
   Serienummer    : 94210038
   Klimabetjeningspanel bagved:
   Undersystem 2 - Styreenhedsnr: SW: 3V0 907 049 D    HW: 3V0 907 049 D
   Komponent    : E265KlimaHeck  H02 0101
   Serienummer    :       06051501850797
   Kodning    : 000000
Styreenhed  09: Centralelektr. BCM1 (J519)     Forklaringsfil:. NEZ\5Q0-937-08X-V2.clb
   Styreenhedsnr: SW: 5Q0 937 086 CF    HW: 5Q0 937 086 BR
   Komponent    : BCM PQ37BOSCH 038 0303
   Revision    : --------    Serienummer    : J53F22091900WE
   Kodning    : 000000000000000000000000000000000000000000000000000000000000
   ASAM datasæt    : EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 00598F932A862EBBA75-8054
   Viskermotor:
   Undersystem 1 - Styreenhedsnr: SW: 3V1 955 119     HW: 3V1 955 119   Forklaringsfil: NEZ\5QX-955-119-V1.CLB
   Komponent    : 48x LL 190920  032  0121
   Serienummer    : 00000001909170305531
   Kodning    : 165DDD
   Regn- og lyssensor:
   Undersystem 2 - Styreenhedsnr: SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Forklaringsfil: NEZ\5Q0-955-547.CLB
   Komponent    : RLHS  051  0206
   Serienummer    : S2Y19M10D11H17M45S51
   Kodning    : 00084D
   Luftfugtighedsføler (indvendig):
   Ratstammekontakt:
   Undersystem 4 - Styreenhedsnr: SW: 5Q1 953 521 DH    HW: 5Q1 953 569 C
   Komponent    : Lenks.Modul  H33  0170
   Serienummer    : 0100011020190C202758
Styreenhed  10: Park.assist. (J791)     Forklaringsfil:| NEZ\5Q0-919-298.clb
   Styreenhedsnr: SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Komponent    : PLA 3.0 12K   H08 0061
   Serienummer    : 000150057319283
   Kodning    : 0271167951
   Forhandler    : WSC 63169 004 1048576
   ASAM datasæt    : EV_EPHVA2CAU3700000 009048
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 55F78EC785847B13A43-8000
Styreenhed  13: Afstandsreg. 1 (J428)     Forklaringsfil:| NEZ\5Q0-907-572-V2.clb
   Styreenhedsnr: SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
   Komponent    : ACC BOSCH MQB H01 0771
   Kodning    : 32057F5B5DFFC728949C812481400600000000000000000046
   Forhandler    : WSC 45946 004 1048576
   ASAM datasæt    : EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW48.rod
   VCID: 46D5598B4822C08BDD9-8012
Styreenhed  15: Airbags (J234)     Forklaringsfil:| NEZ\5Q0-959-655.clb
   Styreenhedsnr: SW: 5Q0 959 655 BS    HW: 5Q0 959 655 BS
   Komponent    : AirbagVW21    008 0403
   Serienummer    : 003FMR5SHBXW
   Kodning    : 98CCC0C0000000005C5400CF004800000065
   ASAM datasæt    : EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 127DB5DB74EAAC2B011-8046
   Crashsensor til sideairbag i førerside:
   Undersystem 1 - Styreenhedsnr: SW: -----------    HW: 480 001 110 19
   Komponent    : SideSensor_Df  001 0887
   Serienummer    : 35700000000199017F3H
   Kodning    : 2D2D2D
   Crashsensor til sideairbag i passagerside:
   Undersystem 2 - Styreenhedsnr: SW: -----------    HW: 480 001 110 19
   Komponent    : SideSensor_Pf  001 0887
   Serienummer    : 358000000004FC14714L
   Kodning    : 2D2D2D
   Crashsensor til sideairbag bagi i førerside:
   Undersystem 3 - Styreenhedsnr: SW: -----------    HW: 480 400 810 19
   Komponent    : SideSensor_Dr  005 6149
   Serienummer    : 35100019AF2FD202D70C
   Kodning    : 2D2D2D
   Crashsensor til sideairbag bagi i passagerside:
   Undersystem 4 - Styreenhedsnr: SW: -----------    HW: 480 400 810 19
   Komponent    : SideSensor_Pr  005 6149
   Serienummer    : 3520001AAF35B11198A9
   Kodning    : 2D2D2D
   Crashsensor til frontairbag i førerside:
   Undersystem 5 - Styreenhedsnr: SW: -----------    HW: 480 400 810 19
   Komponent    : FrontSensor_D  005 6149
   Serienummer    : 3550001A2F1F5755946C
   Kodning    : 2D2D2D
Styreenhed  17: Instrument (J285)     Forklaringsfil:| NEZ\5G0-920-XXX-17-A0.clb-SRI3
   Styreenhedsnr: SW: 3V0 920 790 D    HW: 3V0 920 790 D
   Komponent    : KOMBI         503 4193
   Kodning    : 05A5091A6F8C000C0A8C720B1001000880000000
   ASAM datasæt    : EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 3829277332D6A67B5F5-806C
Styreenhed  19: CAN Gateway (J533)     Forklaringsfil:| NEZ\3Q0-907-530-V1.clb
   Styreenhedsnr: SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Komponent    : GW MQB High   521 5388
   Serienummer    : 13101911602127
   Kodning    : 0B0100345F087300231002D2100F00010001070000000000000000000000
   GVL: 01463C0008000608C0DC80008002C80000000000000200000000000000000000
   ASAM datasæt    : EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B9DF531A263E3B575-8024
   Generator:
   Komponent    : 5-01-14-01-04
   Styreenhed til multifunktionsrat:
   Undersystem 2 - Styreenhedsnr: SW: 3V0 919 719 G    HW: 3V0 919 719 G
   Komponent    : E221__MFL-PR6  H03 0180
   Serienummer    : 000000000E1597051019
   Styreenhed til batteriovervågning:
   Undersystem 3 - Styreenhedsnr: SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Komponent    : J367-BDMHella  H10 9070
   Serienummer    : 5103672705
   Omformer til netstik:
   Undersystem 4 - Styreenhedsnr: SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Komponent    : U13DCAC  H27 0810
   Serienummer    : 2182979
Styreenhed  23: Bremseforstærker (J539)     Forklaringsfil: Ingen
   Styreenhedsnr: SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
   Komponent    : EBKV          H06 0069
   Serienummer    : BPA085140919013
   Kodning    : 0102C100340000C618638C31000049922449920400
   ASAM datasæt    : EV_BrakeBoostG2BoschVW48X 011019
   ROD: EV_BrakeBoostG2BoschVW48X_011_SK48.rod
   VCID: 3B23387F03E08D63B27-806E
Styreenhed  2B: Ratstammelås (J764)     Forklaringsfil:| NEZ\5Q0-905-861.clb
   Styreenhedsnr: SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Komponent    : ELV-MQBB      H05 0020
   Serienummer    : 19000277911005
   Kodning    : 0800000000000000
   ASAM datasæt    : EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3333105F2BB045236A7-8066
Styreenhed  36: Sædeindst. V for (J810)     Forklaringsfil:| NEZ\5Q0-959-760.clb
   Styreenhedsnr: SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
   Komponent    : Sitzmemory    H09 0026
   Serienummer    : Y0007SGJ28702
   Kodning    : 0010000000000500018480808080000000008181000000D400
   ASAM datasæt    : EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide.rod
   VCID: 3FDB4C6F17F891439EF-806A
Styreenhed  3C: Kørebaneskiftass. (J1086)     Forklaringsfil:| NEZ\2Q0-907-686-V2.clb
   Styreenhedsnr: SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Komponent    : HRE3_Kl15_Mst H06 0149
   Serienummer    : 00000527238308
   Kodning    : 62954640
   ASAM datasæt    : EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392F227709DCBF73A0B-806C
   Styreenhed 2 til vognbaneskiftassistent:
   Undersystem 1 - Styreenhedsnr: SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Komponent    : HRE3_Kl15_Slv  H06 0149
   Serienummer    : 00000527661006
Styreenhed  42: Dørelektr. V for (J386)     Forklaringsfil:| NEZ\5QX-959-X93-42.clb
   Styreenhedsnr: SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Komponent    : TSG FS        007 0485
   Serienummer    : 0000392386826
   Kodning    : 001D8920DE00020000001100
   ASAM datasæt    : EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 4DC766A7AD5433D31C3-8018
Styreenhed  44: Servostyring (J500)     Forklaringsfil:| NEZ\5Q0-909-144-V3.clb
   Styreenhedsnr: SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Komponent    : EPS_MQB_ZFLS  507 5082
   Kodning    : 13170000
   ASAM datasæt    : EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C213B6306EE8A5BBBD-8068
Styreenhed  47: Soundsystem (J525)     Forklaringsfil:| NEZ\81A-035-466.clb
   Styreenhedsnr: SW: 81A 035 223     HW: 81A 035 223
   Komponent    : MIB2_amp_P_SK H10 0410
   Revision    : 00000001    Serienummer    : SKZ8Z1KJE08LSP4
   Kodning    : 0384020000AA002FAA0000000000
   ASAM datasæt    : EV_AMPMst16C5Gen2ALPI 001001
   ROD: EV_AMPMst16C5Gen2ALPI.rod
   VCID: 59EF82F7E99C5F7380B-800C
Styreenhed  4B: Multifunkt.modul (J745)     Forklaringsfil:| NEZ\3Q0-907-338-V2.clb
   Styreenhedsnr: SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Komponent    : FCM MQB Low   003 0367
   Serienummer    : 11101910522181
   Kodning    : 00000007090008EA00003D13010000000000000000000000000000000000
   Forhandler    : WSC 23343 005 1048576
   ASAM datasæt    : EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372B244F3FC8A90356F-8062
Styreenhed  52: Dørelektr. H for (J387)     Forklaringsfil:| NEZ\5QX-959-X92-52.clb
   Styreenhedsnr: SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Komponent    : TSG BFS       007 0485
   Serienummer    : 0000392025424
   Kodning    : 001D8120DE00020000001100
   ASAM datasæt    : EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 4CC16BA3564E3ADB0BD-8018
Styreenhed  5F: Informationselek. (J794)     Forklaringsfil:| NEZ\3V0-035-MIB-STD2.clb
   Styreenhedsnr: SW: 565 035 874     HW: 565 035 874
   Komponent    : MU-S-ND-ER    H41 0478
   Serienummer    : SKZAZ2W1066364
   Kodning    : 03840201000000004111120200880A232F0208E4012004008E
   ASAM datasæt    : EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 5BE398FFE3A0AD63927-800E
   Visnings- og betjeningsenhed 1 til informationselektronik:
   Undersystem 1 - Styreenhedsnr: SW: 3V0 919 605 D    HW: 3V0 919 605 D
   Komponent    : ABT_Std-2_Nav  H53 8130
   Serienummer    : SKZ6ZHW2844064
   Medie:
   Undersystem 2 - Styreenhedsnr: SW: 5L0 051 236 CH    HW: -----------
   Komponent    : ECE AS 2022  --- 1720
   Serienummer    : --------------------
Styreenhed  69: Anhængertræk (J345)     Forklaringsfil:| NEZ\5Q0-907-383.clb
   Styreenhedsnr: SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Komponent    : Anhaenger     H27 0260
   Revision    : 8C001004    Serienummer    : 0519196154
   Kodning    : 0100000202000000
   ASAM datasæt    : EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_VW26.rod
   VCID: 40D94F936A06EEBBE75-8014
Styreenhed  6C: Bak-kamera (J772)     Forklaringsfil:| NEZ\5Q0-980-556.clb
   Styreenhedsnr: SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Komponent    : RVC Compact   H18 0231
   Kodning    : 04840201A700201F000040
   ASAM datasæt    : EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
Styreenhed  6D: Bagklapelektronik (J605)     Forklaringsfil:| NEZ\5Q0-959-107.clb
   Styreenhedsnr: SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Komponent    : HDSG-Modul    H13 0271
   Revision    : --------    Serienummer    : A2-C737-6291-8
   Kodning    : 0D88
   ASAM datasæt    : EV_DeckLidCONTIAU736 001017
   ROD: EV_DeckLidCONTIAU736_VW37.rod
   VCID: 48C957B34236D6FB2F5-801C
Styreenhed  75: Nødopk. Kommun. (J949)     Forklaringsfil:| NEZ\5NA-035-284.clb
   Styreenhedsnr: SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Komponent    : OCULowMQBLGE  H19 0825
   Revision    : --------
   Kodning    : 03840201EA421A0D3F1C9E000045400382E608
   ASAM datasæt    : EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3D2736671DF483538C3-8068
Styreenhed  A5: Frontkamera (R242)     Forklaringsfil:| NEZ\2Q0-980-653.clb
   Styreenhedsnr: SW: 2Q0 980 653     HW: 2Q0 980 653
   Komponent    : MQB MFK 3.0   H11 1030
   Serienummer    : E33417011192880
   Kodning    : 000208881178C028B09F10001030008001210000000000000000000000000000
   ASAM datasæt    : EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW27.rod
   VCID: 72BDD55B142A0C2BA11-8026
Styreenhed  BB: Bagdør førerside (J388)     Forklaringsfil:| NEZ\4MX-959-X9X.clb
   Styreenhedsnr: SW: 8W0 959 595 M    HW: 8W0 959 595 J
   Komponent    : TSG HFS       010 0384
   Serienummer    : 0000392321666
   Kodning    : 001881208000020000001100
   ASAM datasæt    : EV_DCU2RearDriveMAXHCONT 001005
   ROD: EV_DCU2RearDriveMAXHCONT_SK37.rod
   VCID: 56F589CB9882700BAD9-8002
Styreenhed  BC: Bagdør passagerside (J389)     Forklaringsfil:| NEZ\4MX-959-X9X.clb
   Komponent    : TSG HBFS      010 0384
   Serienummer    : 0000392344862
   ASAM datasæt    : EV_DCU2RearPasseMAXHCONT 001005
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Styreenhed  D6: V. lysstyring 2 (A31)     Forklaringsfil: NEZ\7PP-941-572.clb
   Styreenhedsnr: SW: 992 941 571 AA    HW: 992 941 571 A
   Komponent    : LED1L         H08 9002
   ASAM datasæt    : EV_LLPGen3LKEBODPO68X 001003
   ROD: EV_LLPGen3LKEBODPO68X_SK48.rod
   VCID: 619FAA17C1CC87B3C8B-8034
Styreenhed  D7: H. lysstyring 2 (A27)     Forklaringsfil: NEZ\7PP-941-572.clb
   Komponent    : LED1R         H08 9002
   ASAM datasæt    : EV_LLPGen3RKEBODPO68X 001003
Slutning-------(Forløbet tid: 09:11, VBat. start/slut: 14.7V/14.8V)--------
You cannot adjust the TIME.
Check in the light settings that you have Switch-on time set to LATE.
THIS ^^^
The lights come on and go off when the light sensor detects the light has dropped to the set limit, nothing is time based.
Is there any other way to adjust light settings ?
Adjust in what sense, you were given the answer, the lights are not TIME based, meaning they will not switch on or off at lets say 07:00 in the morning, and will not turn on at 18:00 at evening, they will turn on or off depending on the ambient light, if you look above your rearview mirror, from the outside, you will se a triangle, that is the sensor, if you cover that sensor in broad daylight your lights will turn on, so they are not time dependant, rather light dependant..
In the MIB settings, under lights you will find 3 options to adjust how fast they turn on or off when the sensor requests on or off, thats it, nothing more, nothing to be done via coding!
They will also come on if the wipers come on for more than 3 successive wipes.
Thank you all for your answers.
I did hope there was a way to be able to code my way out of it. I try different coding options on the RLHS sensor, without any lock.
It seems I just have to accept this. 🙄
What would you like to do? Have it more sensitive, less sensitive, why do you insist on codind, there are 3 option in the cars infotainment.. I just dont know what would you like to achieve?
If I remember well, I think @MartiniB made this mod. He modified the setting to turn on/off the lights earlier or later (I can't remeber) than the default setting...
I hope I don't make any confusion with someone else... 🤔🙃
yes, ur correct.
if i remember correctly - he altered the amount of lumens at which it reacts to.
the light sensor is triggered by the amount of lumens it picks up, to determine how much light is there, and hence when to turn the lights on/off.
in theory, if u reduce the trigger point of the amount of lumens, then it will wait till its much darker before turning on the lights.
however, the same settings in the morning, will turn off the lights much earlier.
Edited by JR RS
4 hours ago, Paikesejanku said:
So it is impossible to have 2-in-1 late DRL/Xenon switching and fast automatic High Beam on?
yes, without visit CAR -> Settings -> Light
most of time i have `Late`
but in the evening, for me very rarely, i have to switch to `Early`
in other case High beam can be activate only manually
175Mb video http://www.superfm.lv/m/Auto/Superb_2016/20190825_no_Automatic_Highbeam_02.mp4
~ 15 minutes later it started to work automatically also with parameter `Late`
Also, please if you are going to post a full vcds, try and put it inside code tags, takes up a huge amount less space :) just keeps things cleaner.
like this
Hello
Know somebody how set service intervals from 30000 to 15000km eith obd eleven?
superb 2016
tnx
6 hours ago, Skodilakrs1 said:
Hello
superb 2016
tnx
Chances are your inspection will already be on 30k and oil service will be at 15k if it’s on fixed servicing?
On oil service reset are both on 30k
I change oil at 15k.   So i like change service intervals from 30k to 15k on board computer.
Recently Browsing 1
