S3 owners - electric tailgate / hatch closing from inside
Would you pay for the rear hatch / tailgate to close from the button inside the car? 129 members have voted
  1. 1. Would you pay for the rear hatch / tailgate to close from the button inside the car?
    • Yes, I live in Kent and would be happy to travel to Folkestone and pay for this to be enabled
      17%
    • I don’t live in Kent but would still be happy to travel to Folkestone and pay for this to be enabled
      72%
    • No, I live in Kent but this doesn’t interest me
      9%
  2. 2. How much would you be prepared to pay for this?
Please sign in or register to vote in this poll.
It would be nice to have the same options for the FL.
  • Replies 211
  • Views 102.3k
  • seriousness aside -  a number of supercars deploy rear wing spoilers at high speeds for increased downforce/stability. bugatti, amongst others also use the rear spoilers as air-brakes too.
  • I've done 450 miles this week so far with another 330 to do tomorrow. Happy to drive to you. Happy to pay for it. Will bring you a pork pie and a decent bottle of melton red ale as a cultural exchange
  • As a disabled driver, I would happily pay a reasonable amount for this.  The non availability drives me bloody mad.  Who in their right mind would design a facility to open the tailgate from inside, o
1 hour ago, defsix said:
Thought so. I don't believe this is available for the FL.
For the sake of £30 might be worth a try, or if there is someone with a FL close to Suffolk I would be happy to plug in and have a look!
HI, is this service still available and does it work on all superbs with electric tailgates? thanks in advance
Hi. Not sure of anyone offering it as a service but you can do it yourself with coding so long as it’s not a facelift version. Have a read through some of the recent posts on this thread. There’s som instruction. But equally it’s possible to mess up the coding and the buttons not work properly. Can be a bit hit and miss.
What age is your car?
hi, its a 2017, ive tried it with vcds lite and pro but the number 4 drop down doesnt appear on my drop down, does it have to be long coded? mine is not kessy system
hi, i think my module number is 5Q0959107L, am i right in thinking the L isnt do able?
It depends on the dataset. @tombee has version L and managed to do it using carscanner based on some screenshots shared by others.
See this post and others in the thread around the same time.
thanks ill give it a look :) my other thought was get a non J OR L module cheap then long code it on then try it again ?
I’m not sure. I haven’t used vcds. I think it depends more on the dataset than the version of the module. Mine is J and works. @tombee is L and it works.
Yup although sometimes I don’t think it is, it’s not straight away it opens you have to hold the button down a few seconds for it to do the beeping and then open, same for it in reverse
Sounds like it’s set to “press” for open rather than “tap” for open. I have no idea how to change it thogh!
I am not too fussed currently might look into changing it at some point
Hi, are you still Suffolk based, I'm in Ipswich and I'd be happy to pay if you can get my bootlid sorted with your carscanner set up.
I’ll message you
On 04/04/2017 at 03:18, Gizmo said:
I am considering buying now also own VCP (Vag Can Pro) which can enable the hatch / tailgate to be able to be closed via the button inside the car by the DSG lever / gear stick.
Please fill in the poll and reply here.
 HI @Gizmo im heading your way in november, is this something you can still do, mine is the L controller module , thanks in advance Al
Not sure if this is still something that you are doing. Mine is a 2019 and I was told the module couldnt be reprogrammed to enable close from inside. Mine is a 2019 and has the long press inside to open. Can mine be set to close from the inside as it is very annoying when you need to get out to close or use the keys.
Hi @Gizmo are you still able to do this, is there now an option for the L module? I do have a G module I can fit if that's able to open and close the electric tailgate on the fob and interior button, I'm heading your way in November on holiday and if you are about to message me and let me know that would be great, thank you.
No I sold my VCP a few years ago
Bugger 🤣, any idea if the L module is now do able? Also do you know if the module needs coding to the car to make it work properly?
To my knowledge nobody has written a file for later controllers.
If your spare controller is s/h then there is a slim chance it may be coded correctly, but basically yes they need coding to your car.
The spare one is a G 5q0959107G, is that one that can be sorted once it's coded to the car?
Part No SW: 5Q0 959 107 P
HW: 5Q0 959 107 J
Can anyone help to do it with carscanner
Kessy and virtual pedal, can open and close with key ( closing short range 2m I guess )
Edited by ile7
HW: 5Q0 959 107 J
Car scanner can be a bit hit and miss. I would advise that you go to the “use user defined bytes” at the bottom of the settings screen detailed below and take a screen shot or write them down so that you can revert to current settings if something goes wrong. I’m not certain that it will definitely get you back to where you are but hopefully so!
Select coding and service
Then luggage compartment
Then scroll to the bottom and choose tailgate dataset customisationIMG_0611.jpeg
Then click on choose other and select one of the superbliftback ones.
Then set the parameters you want and choose apply. (The open/close from remote should be selected and kick close for you)
You may need different settings if you have kessy or virtual pedal.
I have seen on another page that you have to hard reset through the long coding options for it to apply but it worked fine for me without this.
Easly done with carscanner, didn't had to choose other dataset version, just changed interior button option to allow open and close while ignition on and off. Closing with button pressed, opening tap button
