New FL Skoda Superb 2020 tail lights - retrofit?
nice work @AlVal :)
  • Replies 239
  • Views 82.9k
  • Go and buy a FL and stop imitate it... (facepalm)
  • thread update.   thanks to Mo, we've got part numbers for the Sedan. unfortunately there is only one supplier identified thus far, and its too bloody expensive - https://www.skodaautote
  • silver1011
    silver1011
    I disagree, I think the new rear lights freshen the car up quite nicely...
Done!
https://youtu.be/ybRPBTotKMw
Well some coding to do to get the taillights to their proper brightness (something called dimmwert needs to be changed from 100 to 127), but I'll do that once the rain stops
Edited by AlVal
Hi Guys, I'm from Germany and did the FL rear light conversion in 2019. Everything works except for this light animation. When opening it is only not possible when closing. And as soon as the PWM signal is present, the indicator no longer works dynamically. Does anyone have the coding to do this? What else do I have to code in the central electrics?
I suspect that it probably requires a replacement controller module with a newer version to program the coming home animation, but I'm not sure. You did this wire up to the front of the car for the pwm signal also? I prepared it at all 4 lights but didn't connect it to the front yet because its working fine without, and I want to understand what exactly the pwm signal does first, and what controllers might be needed for it to work right.
The PWM signal is applied to the BCM, as described in the circuit diagram. With the xenon, it cannot be connected to the front lights, but only with the matrix, as there is a light module there. Hence the assumption that it will not work as it should without this module. Animation when opening works, but the blinker is no longer dynamic.
So far, the animation only works when I open the car. When locking, the light just goes out. The blinker is dynamic while driving and also acts as a hazard warning light. So for now a partial success.
On 28/03/2021 at 19:01, AlVal said:
Je soupçonne que cela nécessite probablement un module de contrôleur de remplacement avec une version plus récente pour programmer l'animation à venir, mais je ne suis pas sûr. Vous avez également fait ce câble à l'avant de la voiture pour le signal PWM? Je l'ai préparé aux 4 lumières mais je ne l'ai pas encore connecté à l'avant car il fonctionne bien sans, et je veux comprendre exactement ce que fait exactement le signal pwm en premier, et quels contrôleurs pourraient être nécessaires pour que cela fonctionne correctement.
hello Mr Alain please can i get you contact ?? email or whatsup please i have problem with skoda superb 3v
Welcome!
It might be worth asking your question here as you'll get more eyes on it. If it's not related to swapping tail lights, you should start a new thread.
You can also send @AlVala PM (private message) by pressing 'message' on their profile: https://www.briskoda.net/forums/profile/102097-alval/
On 26/03/2021 at 11:53, AlVal said:
Done!
Fantastic! Seems you don't have there the strip. How you managed to remove the strip? Is it easy to do? It does not leaves any ugly marks/holes etc?
the chrome/black strip r a separate piece, and is part of the boot handle/RVC/number-plate lights trim.
looks like this.....
@JR RS I know, but the outer lights have the strip separated and mounted directly on them, look at the photo of it:
http://www.maxildily.cz/fotky39848/fotos/_vyr_14163IMG-20201124-WA0000.jpg
Can the strip be removed from this outer light?
The outer stripes r a seperate item again to the outer light.
So if u don't want the stripe, get the light cluster on its own.
If u buy a used one with it already, it shouldn't b too difficult to remove as it's just adhesive.
Is there any animation news here?
Has anyone ever flashed the BCM?
For me it is only possible to open it so far, otherwise all functions are fully available. The dynamic indicator also works correctly.
Only the animation when locking is not available and the light simply goes out.
Edited by Lutz_91
what is the part number of the camera?
On 20/08/2020 at 17:00, ssavi said:
hey mate, have u successfully retrofitted the new tail lamps?  im very keen in converting to the new lamps, but based in this thread seems it isnt such a plug & play method. cld u share if u managed to complete this retrofit?
On 04/08/2020 at 12:27, JR RS said:
oh no, that is bad news @ssavi 😞
sorry to hear that.
in ur pics, which one is old & which one is new?
hope u can sort out the wiring+connectors.
i ended up abandoning the idea of the sourcing the face-lift lights, for now, given its cost & availability in Oz.
so for the time being, I improvised with the chrome strip across the rear.
IMG_01082020_103933_(1080_x_680_pixel).thumb.jpg.f5602232a1ced6a1da27314570b49936.jpg
IMG_01082020_103959_(1080_x_723_pixel).thumb.jpg.10027859fb7f35034ef602ec8fc88842.jpg
IMG_01082020_104016_(1080_x_736_pixel).thumb.jpg.1a85940c90ccf0695bbce4913833bd05.jpg
@JR RS beautiful rear end of yr car mate.
Superb from Russia
Vor 3 Stunden sagte Maksimilli:
Super aus Russland
Is the light animation functional?
So that is dimmed when opening and closing!
15 hours ago, Maksimilli said:
Superb from Russia
So beautiful mate !
how did u sort out all the wirings?
could you do a short tutorial on how affix the facelifted tail lights ?
2 hours ago, mByson said:
Такой красивый друг!
как ты разобрал всю проводку?
не могли бы вы сделать краткое руководство о том, как прикрепить обновленные задние фонари?
Unfortunately, I have no data, the work was done in the service
14 hours ago, Lutz_91 said:
works only when opened
Okay, so it's the same as mine.
So far only works when opening the animation.
So front and rear conversion are nothing new anymore. It's all older.
If you have the right STG and adapt the cabling, this can also be done at the front.
Of course, a few more parts are then required, which makes them significantly more expensive.
Whether the animation then runs 100% at the front and rear is also questionable.
  • 3 months later...
Does anyone else here have any new insights into animation?
I wrote to the company from CZ but of course they don't give out any information. Costs 200€ and only there. Doing it yourself is not.
I still suspect it is due to the BCM. Has anyone already flashed it?
On 20.03.2022 at 18:43, Lutz_91 said:
You need to understand the version of BCM and its hardware
