Amundsen MIB2 Firmware Update
1 hour ago, pab567 said:
@bladerara you have the latest SW
@asavvyman check you PM for latest SW. I don't know if your unit has been reworked and with what solution but basically for having AU maps on SD without changing folder name you must recode byte 03 in 5F from 01 to 08. If this doesn't work then additionally license for AU maps shoudl be installed.
To have the colour folders instead of the monochrome carousel is not a piece of cake - it requires hacking of SW download and then updating with hacked 04xx SW.
Pab567 is there any way to fully reset the software or to reinstall it? As I have a few issues with the sound and the fact that is I press the power button to reset the infotainment, the system factory resets and have to go through the process again. The sound goes lower after a call or nav announcement but does not go to normal after and remains low even at full volume.
  • Replies 4.6k
  • Views 815k
You can turn developer mode on and then manually select to re-install all the files.
Do I need a copy of the firmware or will it use what is what it already has?
Firmware must be on SD
It's a retrofit and had no SD that came with it.
Firmware can be put on any SD. I sent you link on PM. What is unclear here?
Thanks. I understand form you reply that I should have this already. Thanks
I also have an Amundsen (as business package) with the following data:
Part number device 5Q0035874C
Hardware H41
software 0471
Is there also a newer firmware available for this?
Thanks in advance
Greetings
MST2_EU_SK_ZR_P0253T
Hi pab567, is there any update for this firmware? Thank you
Hi pab567
Having intermittent BT connection issues and as well when using android auto via USB for nav then android auto disconnects and mirror links starts up...
Header Unit should be a Bolero MKII
Appreciate if you could drop me a PM with the link to the latest FW version.
Many thanks in advance - Steen
Hello, is there an update to the bolero system on my octavia 2015 mk3?
Hey, I really appreciate the help here. For some reason my radio volumes are all over the place between different channels and other minor issues. Could I get new FW from someone?
5Q0035864C
HARDWARE: H41
SOFTWARE: 0475
Hello, this is my amundsen version
Is there any update ?
Thanks a lot :)
Jonathan
Question for everybody, especially @pab567, as this thread is becoming very active and popular:
- Unless there is any issue noted with my unit, does it make sense to update?
- What are the benefits for properly working units?
Thanks.
Edited by nidza
Thanks.
No sense to update if you don't have issues since updates do not bring any new features, they 99% fix existing issues. This answers both of your questions.
No. And don't shout please...
Thanks a lot :)
Jonathan
No
All others check you PMs.
PLEASE NOTE I AM NOT AVAILABLE FROM AUGUST 15th TILL SEPTEMBER 6th
Sorry.
Hi, could someone please help me where i can find the latest update (if any) for my stereo?
I'm sure that @pab567 will be along to assist soon.  Your maps are somewhat out of date too (2017) - maybe a maps update might be a good thing.
@Dannen check your PM
Thanks! :)
Are there any reports about updating causing the unit to be bricked or features disapearing?
Tried searching for it but only saw reports about MIB1.
There is always risk of bricking...
