Amundsen MIB2 Firmware Update
Does anyone have any updates for my 2016 Octavia 3 Amundsen MIB2.
Having random reboots especially if trying to use my Android phone (LG-V30).
Thanks,
John
  • Replies 4.6k
  • Views 815.6k
Can I play video file ?
565035864
HW: H41
SW: 0478
Hi @pab567
is there an update for that system available?
Thanks in advance.
all check your PMs
@jaydoo only via SmartLink
On 23/09/2020 at 21:36, weehappypixie said:
Thanks,
John
Thank you pab567 for the PM.
And How? I'm using Android Auto with OnePlus phone. Can't play video..
Hi, @pab567, also please link to the firmware update of my car radio (Kodiaq My 2018.)
Thank you.
Search different forums... there are multiple solutions, typically you have to root your phone and install some software.
Hi, I can't update!
1. Format a SD card to FAT32.
2. Extract the contents of the file that I have to the SD card.
3. Remove ALLcards from the controller in the glovebox
4. Insert the card containing the firmware update into Slot 1
5. Go to Service menu, find and activate the update function...
What am I doing wrong?! (see attached files)
2 minutes ago, moorhuhn said:
Hi, I can't update!
Do a long press to the menu button.
Thanks, it's okay.
Hello,
my unit is:  5NA 035 020 A
MHI2_ER_VWG13_P4174
SW: 1121
Is there any new firmware update available?  Will update leave component potection untuouched ?
thank you very much.
2 hours ago, Aladar said:
Hello,
MHI2_ER_VWG13_P4174
SW: 1121
Updating the firmware doesn't affect component protection, but it does set a fault code that the firmware has been changed - which is easily cleared following instructions widely available online.
Thank you.  And is firmware for this unit somehow bind to VIN code of the car or not ?
For many years now VAG infotainment systems have remembered the VIN of the vehicle they are first installed into, and on startup check the VIN of the vehicle they are fitted to.
thank you.
My MIB2.5 was mounted additionaly (original MIB1 was replaced), component protection is deactivated.  So I propose that it should not be problem to update firmware.
I would suggest you check with whoever removed component protection to save an expensive mistake...
Device part number: 5Q0035864B
Hardware: H30
Software: 0367
Many thanks B)
DEfinetely! I beleive SW update will kill patch, the rul eis if you patched the unit then do NOT make any SW updates!
Hardware: H30
Software: 0367
Many thanks B)
This is the latest version I know.
Hello,
Can someone send me please an update for my Amundsen Octavia III....
Is there also a changeling available?
Teilenummer Gerät: 5Q0035874A Hardware: H25
Software: 0245
Navigationsdatenbank: 5L0051236H 0521
ECE 2016
Thanks in advance
Hi there,
Do you have VW firmware too?
I have this system:
Thanks!
@pab567 I have sent you a PM with HU system information. Please let me know if any update is available.
Warm Regards,
Sreehari
Check your PMs
Just to add to this for anyone who is running a Columbus MIB2.5 system like me, I sent screenshots of my software versions to Pab567 last night and he sent me an update link straight away, went from version 1163 to version 1440 successfully this morning in about 20 minutes from a class 10 micro sd card. Hasn’t fixed the issue I had (continuous playback of mp3 files for mix albums etc) but good to know it’s at least up to date so many thanks to him for this. :thumbup:
Recently Browsing 1
