Amundsen MIB2 Firmware Update
5 minutes ago, Durky said:
Hello, now have SW MST2_EU_SK_ZR_P0361T, as far as I understand, the update is officially only for MST2_EU_SK_ZR_P0369T. I would be interested in the possibility of updating to MST2_EU_SK_ZR_P0478T
Does anyone have any advice or instructions on how to do this? Škoda Octavia 3 FL 2017.  Thanks
You are correct the official update is to 0369, but to change to 04xx version there's a chance to break things, personally I would stick to the official update path.
  • Replies 4.6k
  • Views 771.2k
Hi all, anyone knows if there is an update available and if I can enable navigation?
Spoiler
AFAIK there's no update to firmware, and not sure about navigation sadly.
19 hours ago, sykora said:
Hi @pab567Thank you for response
    3, I see
    5. Let's say main requirements is to stay with current screen. I would like to avoid replacing it. Are there any other OE numbers that will work with this screen ?
    7. No idea how much dealer will wish for this adaptation. But anyway do you have any step by step tutorials how to adopt such device to the car ?
Ad. 5. Bolero 5Q0035840x / 5Q0035842x / 565035840 / 565035842, Amundsen 5Q0035864x / 5Q0035874x / 565035864 / 565035874, Columbus MIB2 3V0035020x, 3V0035021x, 3V0035043x, 3V0035044x (x - any letter, for Bolero and Amundsen B or C).
Ad. 7. For official way you need VAS interface, ODIS and online account in SKODA systems.
@pab567
5. Thank you for the this list
7. I know that dealer can do this. But I'm rather asking if you know any step by step tutorials how to do this in unofficial way  ?
8. Are you able to activate such device maybe you are not so far away from me in Poland 😉
Edited by sykora
This is not a kind of knowledge to be shared, especially here.
@pab567
Edited by sykora
Yes, if you are interested pls contact me on PM.
Hi pab, wondering if you can help me out with the firmware on my 2017 vrs TDI. It’s currently as follows
5Q003587AC
H41
0456
NAV : 5L0051236T
0820
ece1 2017/2018.
is there a new update file you can be kind enough to send to me please pal? Many thanks
Noman
Hi friends...Im currently updating my infotainment in my car...and it showed me this warning...error: device...error code: detail: 0...device:MMX1:0...detail information
I choose repeat...but without succes...so I tried skip...and it is continuing next...but there is NOK:1 🤔😬. What I should do next with it? Please advice friends.
Now this😱😱😱. Help me please. I did all by instructions.
5Q003587AC
H41
0456
NAV : 5L0051236T
0820
ece1 2017/2018.
Noman
Remember to use the @pab567 tag format as he will not see the post always.
@pab567 This is a hardware fault question by looks of it?  Or they need to try different media perhaps.
now what next😟
8 minutes ago, Maisner said:
now what next😟
You need to check the media for any bad sectors, or use another media if you have a spare.  Then try to put the data on there again from the download.
Yes I have original Skoda SD 8gb card I try to format it to FAT 32 and then copy there all files from this SD Kingston 32gb card.
Don't copy from Kingston, as you may just copy corruption, did you keep original file I sent?
Yes I have it at home in laptop...I can turn off engine on my car and lock it...or rather no?
It's already "crashed" to emergency mode, so yes engine off and head inside
2 hours ago, Noman9Vrs said:
Hi @pab567, wondering if you can help me out with the firmware on my 2017 vrs TDI. It’s currently as follows
5Q003587AC
H41
0456
NAV : 5L0051236T
0820
ece1 2017/2018.
Noman
Now all is looking like in right😃. Thanks for some advices my friend👍...problem was mine probably with SD card or extracted files from your zip file in my laptop. All junks of MMX1 on sd0 were completely processed sucessfully😏.
Wow, we can breath oxygen once more!
Glad it got it working in the end for you 🤝
5Q003587AC
H41
0456
NAV : 5L0051236T
0820
ece1 2017/2018.
Noman
Check your PM for download link. BTW: Your unit must be 5Q0035874C, not 5Q003587AC
😄 Yes sorry pal..thanks. I will download it today.
