Amundsen MIB2 Firmware Update
I'll go for  0480 as soon i can have all installation info
Regards🍻
  • Replies 4.7k
  • Views 899.2k
@varooomthanks for the download, all done and dusted!
Please send the link
Hi @varooom,
Could you please send me the latest update for this hardware:
Device part number: 5Q0035864C
Hardware: H41
Software: 0475
More details please, press and hold down your Menu/Setup button for 10 seconds to enter the engineering menu, look for Software Train
1 hour ago, KoRleone said:
Hi @varooom,
Hardware: H41
Software: 0475
Yes I can send you a link very soon to 0480
Hello. I need help please with my software. I have Skoda Octavia Combi III 1.6 TDI 116ch SCR Business DSG7 Euro6d-T 2019.
Thers my software train
Update sent by PM
@varooom
Can you please send me latest update for this 0359T version & instructions?
do I need to activate again carplay after update?
BTW What are benifits for going from 03xx to 04xx?
Also will 0369 update bring me option for wireless android auto connection?
Currently when I click smart link it says: connect your phone with USB, not sure how to connect with WiF if its possible??
Tnx
@Serialski If you have carplay activation by factory/dealer then it will be available after the update.
If you updated by other means, then you will need to apply patch again.
I think you will also be stuck using USB for phone link, and Wireless will not work.
And I recommend you stick with the 0369 update I will send you, forget about swapping to 04xx version.
Tnx I did update!!
not sure why I have this wlan option In media, I tried connecting to my phone & making hotspots but without luck to play some music :/
Hi there,
For those who performed firmware upgrade themself, is it safe to trust files from https://mibsolution.one ?
Thanks !
1 hour ago, Vasariah said:
Hi there,
Thanks !
They are OK AFAIK.
But the site is slow like ancient dialup Internet.
Hey,
I wonder if there's an update and what benefits there might be?
Skoda Octavia mk3 MY14
Device part number: 5E0035840A
Hardware: 040
Software: 0421
Media codec: N/A
37 minutes ago, Ruuppe said:
Hey,
Hardware: 040
Software: 0421
Media codec: N/A
Yes, and benefit it a bigger number, 0421 --> 0490
Normally they fix bugs you may or may not be aware of, like system speed and Bluetooth stability etc
Where can I get the update?
Thanks!
Thanks!
By Private Message system
Dear @varooom,
I have the following system. Is there a software update available? Does it matter that it is in Swedish? I would very much appreciate if you could help me.
Regards
1 hour ago, Joskodan said:
Dear @varooom,
Regards
It doesn't matter that it's in Swedish (other than me not being able to read it)
The firmware is EU, so has languages for Europe.
Only a small bump to 0480 is available, will send via PM.
Many thanks!
3 minutes ago, Joskodan said:
Many thanks!
You are welcome,
Optionally you can update the maps to newer version, even if you use phone, this makes for a good backup.
Hi is there any update for this unit? Thank you in advance .
Press and hold down the Menu or Setup button for 10 seconds to enter the Engineering menu, locate page where Software Train is found (hopefully!)
