Amundsen MIB2 Firmware Update
On 29/07/2024 at 23:49, Hanza said:
is there somewhere this update? I have this one right now.
Nope, you have the latest firmware.
  • Replies 4.6k
  • Views 811.6k
On 04/08/2024 at 00:19, fila_superb said:
can anyone point me to steps to upgrade from 253t to 480t?
amundsen, superb 3, 2016.
thank you
Unit must be patched first (swdownload) and MST2_EU_SK_ZR_P0480T version with modified metainfo2.txt file must be used. If you don;t have CANTON then after such upgrade right and left channels will be swapped.
On 09/08/2024 at 12:06, alex69 said:
Hallo
Gibt es ein Firmware-Update für meinen Amundsen?
Teilenummer Gerät: 565035864
Hardware: H41
Software: 0480
Navigationsdatenbank: V03959820BR
2010
First of all,pls use English on this website. You have thje latest avaliable firmware for your unit.
Pls check your PMs,no message in PM = you already have the latest available firmware.
Hello! Is there a newer version for mine and can someone share info how to get it or share the latest fw files?
Dont bother, I found in previous post that latest is MST2_EU_SK_ZR_P0480T. But what does this mean :"External amplifier (Bose, Bang&Olufsen) might need dataset after update."? Is there som guide available what needs to be done?
I have Canton sound system in my L&K 2018 Superb. Maybe this should not affect my case?
is there an update for my amundsen with canton sound system?
 Octavia RS TDI 2016
Edited by Maximus12
Hello everyone,
Does the 5q0035840 handle the mib2 columbus display?
Can't find anywhere any info with the pairings
Tnks a lot!
HEllo.
Is there an Update for my System?
Thanks for Support and help.
All check your PMs.
On 15/08/2024 at 19:44, Cristiantedd said:
Hello everyone,
Tnks a lot!
If by MIB2 Columbus display you mean 5E0919606 then the answer is yes, but two buttons (NAV and TRAFFIC) will not work as 5Q0035840 does not have oem sat nav built-in.
I managed to update to MST2_EU_SK_ZR_P0480T without issues.  Just needed to follow instructions from fw download site.
Edited by marelz2
When you unzipped the file and copied contents to SD card did you get some files saying they couldn’t copy properties over?
No, i just unarchived downloaded archive file, and copied all the files to sd card which I formated to fat32 and set allocation to lowest possible. ;)
7 hours ago, pab567 said:
All check your PMs.
Does the 5Q0035840 have the mirrorlink and Android car option coding?
Ah ok I just used 7zip to extract to card rather than windows ‘Extract All’ and it seems to have done it with no nonsense
Nope, 5Q0035840 (with no letter suffix) supports MirrorLink only - no Android Auto, no Apple CarPlay.
Good day. I have a problem. Car radio. When turned on, the logo and radio sound appear, then an endless reboot begins. I think that the update will help. Where can I get updates for MIB STD2 ZR+NAV 3Q0035824B SW0359 HW H30 Thanks in advance for your answer.
On 28/02/2024 at 17:30, Jamoon said:
🙄Well it seems mr-fix has released a video about above mentioned 0475 P0480T update (January 15th -24)
Hello,
can you share a link to the video, as I could not find it?
I am with Octavia 3, 2017, seems to be with Amundsen MIB2 - see attachments.
It seems to be with 0468 version, and I am wondering if I should upgrade to 0480. Where can I find what is new in the newer version?
Hi @pab567
Seems that you’re the godmaster of the Firmware 😃👍🏻
I have a 5Q0035840C / H41 with software 0468 (Amundsen without Navi).
Is there already a newer firmware available?
Best Regards
a SmallMen
Hello @pab567, please PM me when you can, it can be in your native language😉
looking for software and maps updates if available, thx tho.
my unit
5Q0035864C
HW: H41
SW: 0471
All check your PMs.
@Ashot I really doubt it will help, if you don't manage to have it solved pls contact me on PM.
I believe there should be something for my lovely Kodiaq :) Thanks in advance.
Hello @pab567. Hope you're well.
I've attached a photo of my system. I am seeking the ability for it to support Android Auto specifically. I have read that I need to be wary of what version my device is, I am currently Android 14 on a Pixel 7a.
Do you have any other information that may help me with enabling this on my unit?
For future searchability by others interested:
Train Version: MST2_EU_SK_ZR_P0245T
SW MU Version: 0245
Part Number: 500035874A
Software version: H25.14.78_STD2Nav_EU
Thank you
Edited by skodanewby315
@skodanewby315 I sent you link for the latest firmware for your unit. These units support Android Auto - see the screen when you select SmartLink from touch screen menu.
