Amundsen MIB2 Firmware Update
hi, my multimedia shuts down sometimes and i find out there is an update on my system. can you please send me an update? my car is superb 2020 and my software is MST2_EU_SK_ZR_P0478T. i read there is an update called P480T and i hope it solves my problems.
  • Replies 4.6k
  • Views 815.7k
@pab567 can you please send me MST2_EU_SK_ZR_p480T please
Edited by JRJACKAL
I too am looking for this file. I unfortunately don't have the rights to send PM's since I need 20 content items on this forum. Would anyone would be able to send it to me?
MST2_EU_SK_ZR_P0480T
Thanks in advance
I'm looking for update to my system as in screenshot. Could someone share if there's an update?
Thanks in advance.
Hi @pab567. Can you please send me the MST2_EU_VW_PQ_P0245T firmware?
I have to try an emergency update because a boot loop
Thanks in advance for your help
I sent you link to MST2_EU_VW_PQ_P0254T, just use it.
All pls check your PMs.
Hi @
Hi @pab567,
Hope you're good?
Just purchased a 2018 Octavia VRS, after doing a bit of research it appears I need an update file for for my system.
Having checked on mibhelper it advises I need,
mst2_eu_sk_zr_p0480t
I would source from mibsolution.one but the site is down.
I would be grateful if you could help as the system has crashed twice and only had the car a week. Hoping the update from 0468 to 0480 will resolve the issues.
Hope you don't mind me reaching out as a newbie but you appear to be the oracle on this topic after reading the forums.
Thanks in advance.
Link sent in PM
HW:H24
SW:0253
current version MST2_EU_SK_ZR_P0253T
original version MST2_EU_SK_ZR_P0245T
i cant directly update to p0480t becuase the software updater app is too old i need something after my current version pm me and send the firmware please model:GuideModel_25.14.39
HMI software H25.14.89_STD2Plus_EU
software base H25.14.89-201607111419
the car is a 2015 november skoda octavia 3 combi i need it so then i could update to p0480t i have the p0480t and p0253t files if anyone wants
On 19/05/2025 at 00:03, pab567 said:
Link sent in PM
edit: it says cant read metadata and then it says that the software updater tool is too old
its a BOLERO model
i need the MST2_EU_SK_ZR_P0368T
by chatgpt
You CAN't upgrade BOLE|Ro from 02xx to 03xx or 04xx, unit must be patched first which requires it to be open and soldered.
i just wan to do it all without soldering or obd11 just updating system and if i would what would happen if i just updated it to 03xx and whats the latest 02xx version
@Ezerinos223 It's like Pab wrote above. You better not try it without knowledge because you will destroy your unit.
Hi all or more specifically the guru @pab567,
I've entered my software train into mib - helper. com MST2_EU_SK_ZR_P0456T - Skoda Bolero / Amundsen firmware
I can't download the software as mibsolutione site is not working. How can I download the required latest software? Also can I go straight from P0456T to P0480T or do I need to upgrade in stages? Sorry, new to this and don't want to brick my unit.
Go straight to 0480 - I sent you download link in PM
Top Man. Thanks
Hi there,
I have a skoda octavia (11/2015)
Is it possible to have android auto and apple carplay with this version?
Thanks a lot
Hi @pab567 ,
Where to find the dataset and how to apply that?( Based on info from mib-helper)
Thanks in advance.
External amplifier (Bose, Bang&Olufsen) might need dataset after update.
On 21/05/2025 at 17:40, Nunos said:
Hi there,
Thanks a lot
Yes, possible, either by Skoda dealer or patching the glove box unit which unfortunately in this case requires unit to be open and soldered.
10 minutes ago, RedBlueFireDragon said:
Hi @pab567 ,
Thanks in advance.
ODIS, VCTool, Vag Can Pro...
Sorry, I'm not quite sure I follow.
I have VCDS.
Confused about what dataset means, is that a patch file?
No, this is xml file that parametrizes different features. You can NOT load it with VCDS
Hello everyone, I am a new user. If possible, give me a link to the update MST2_EU_SK_ZR_P0245T,
I will be very grateful. Thank you for your attention.
Edited by Yaroslav
Hello. Can anyone help with the firmware MST2_EU_SK_ZR_PO480T? Thanks in advance.
Recently Browsing 2
