Belt squeaking/some pulley noise/ coolant temperature
3 hours ago, D.FYLAKTOS said:
You can hear the noise of the belt which has problem. Open your hood, do you hear the same?
Thank for the reply
The noise of the belt is the one in the video but the other bad sound is more likely some ballbearing or similar
There is difference between noises if the car is static and the ones that when it's on the road.
I think you have to go step by step, it's very difficult to have many problems simultaneously and solve them with one move changing many parts the same time.
The cost would be enormous !
Thanks for reply as always .
Belt squeaks when it rains. In sunny days it doesent.
The bearings noise is always present when revving, but at idle is not audible.
So they are 2 differnt problems:
-one is seceondary belt (much probably)
-second is to be solved....
But when i will have time to chenge service belt i will try to spin all the pulley i will be able to trying to sort out
If after a rain you hear a loud squealing sound, the belt may need to be replaced or tightened.
My friend you should have change the belt after so many weeks
after the change you can searching for the next problem so one-by-one you will finish all tasks.
I have shuold have to but i didn't have the time to. Due to this lack of time , i need to addres the problems and then ( in the night of course) i will to do all the jobs in one time...
