Tested and working coding Octavia mk4
Thanks Giannis.
I was assuming that I would get OBDeleven to do the codings, but as I said, this is all new to me.
Will this work on Mk4 Facelift?
  • Replies 294
  • Views 125.5k
  • Self moderation is the key to happiness. The best reply is sometimes no reply at all.   we’re all free to do what we want to do with our stuff.   Why would someone buy a brand new
  • @SkOmk4, My answer in line: 1. All the Release Active DTCs will be present only on the SFD locked modules. The reason why the DTC is still present on that module is that you forgot cu SFD Lock the m
  • I think both sides of the argument have some validity.   Perhaps an addition to the first post by the OP stating that you should backup the configs before doing anything, you should understa
SK Mk4 FL is using SFD2 which might be new to OBD11. Better to check with Voltas Support Team.
SFD2 is a new "protection" scheme from VW, it makes it impossible to even scan modules for faults without a trick.
The latest release of VCDS has a workaround to be able to scan modules, but not yet to be able to change settings which are locked by SFD (they're working on it but VW moves at a glacial speed).
Maybe the answer is to scan using the latest VCDS, but then make changes using OBDeleven which does have an SFD unlock mechanism?
Thanks both.
Gulp, this all sounds a bit complicated for a novice like me...
I would so like to be able to pick normal Cruise Control though, Adaptive is just horrible. At the weekend I was doing 30mph with Cruise set, passing a parked car, and it hit the brakes bringing me to 15mph before I realised what was happening. It's just dangerous.  Luckily there was nobody behind me.
Sounds like the front radar could be out of alignment if it's detecting a vehicle effectively in the lane to your left as being in front.
I think I was moving across to pass the parked car, so there may have been a point at which the parked car came within the radar's scope.  I guess that if I had been indicating, it wouldn't have happened, but I was brought up to think (Police / ROSPA driving course many years ago) that if no other road user can benefit from you indicating, don't bother.
Same here.
Hello, anyone can provide me the longcoding for 3-times indicator blink?
somehow, after disable/enable the vrs theme, the comfort indicator blinks 2-times. Before the operation, it blinks 3-times.
Octavia NX 2021, Style, VC, Columbus.
obd11 PRO plan.
Thank you,
G.
Edited by geolik
Multiple savings
obd11 PRO plan.
Thank you,
G.
Hello @geolik,
The coding for the comfort turn signal is:
Unit 09->Adaptations->Light_control->Comfort flasher set point:3 (MAX VALUE)
Bear in mind that there is a restriction to max value of 3 for the MQB-Evo platform, compared to previous MQB platform.
Even so, I don't quite understand why this happened since you coded the vRS theme (unit 17(VC) and unit 5F(MIB3), both are handling the coding for vRS appearances) , BUT unit 09 - Central Electrics has been affected. Have you used any 1-click apps?
"Mult noroc!"(Good Luck!)
D
Edited by djmartzian
tagging username
1 hour ago, djmartzian said:
Hello @geolik,
D
Hi, thank you @djmartzian for info.
yes, I have used the One-Click app for vrs theme.
I’ve already tried the codding, but without success.
Trunk open, ignition on, parking brake on, saving with success!
MIB restart.
The value is 3 but the blink stay stick on 2 times.
Multumesc!
Thank you!
G.
In the MIB have you tried the menu option to reset lighting values? This makes the MIB software re-read the user values.
Edited by PetrolDave
I cannot find that option, can u be more specific?
i only have Reset all car, loosing all the configuration (which I don’t want anymore ;) ), cannot find the reset for the lights module, I got your point!
I have a MIB2 so I'm assuming that option still exists on the MIB3, maybe that's a bad assumption? Hopefully other IV owners will chime in..
Quote
The problem with the One-Click app is you never know what it's done, and if it's not correct for the versions of software in your car then all bets are off. IMHO the One-Click app is a very dangerous thing.
Hello new coding : Disable rear window wiper in automatic mode :  because turn off the wiping of the rear wiper in the auto mode for the front wipers, because the rear window is often dry
: central electronic 09 : Adaptations -> rear window wiper ->Automatisches Heckwischen set to not active ...
Hello,
Just received OBDeleven ultimate pack and tried to activate a few things on my Skoda O4 2020, unfortunately without result:
  1. CarPlay activation without cable is not working; it is working with cable but via WIFI, not... I have activated thru OBD, can you please give me some support?
  2. Cornering I have turned on but when I try to see if is working, without moving the car, nothing happens. :-( I have also activated fog with high beams. Does this impact somehow cornerring?
    I have attached few pictures.
    IMG_6375.JPEGIMG_6376.JPEGIMG_6377.JPEGIMG_6378.JPEGIMG_6380.PNGIMG_6381.PNGIMG_6382.JPEGIMG_6383.PNGIMG_6384.PNG
49 minutes ago, cristianvelicu said:
  1. Cornering I have turned on but when I try to see if is working, without moving the car, nothing happens.
Cornering fog lights only works when moving.
Thank you.
@cristianvelicu ,
Often, after 09-CU coding you need to perform a bus rest. This means you lock the car and take the key far away so that the CAN bus network enters a rest state and at the end the communication resets.
Good luck!
39 minutes ago, djmartzian said:
@cristianvelicu ,
Good luck!
this is for Carplay or cornering?
16 hours ago, cristianvelicu said:
Hello,
it works for you?
Do you have a Swing radio?
1 hour ago, manuelin said:
it works for you?
Does not work, I have Swing radio as you can see in the pictures.
I saw in your pictures the part number, and I was looking your swing radio have BT and WIFI, so is 100% compatible... in my case, my swing radio just have BT.
Actually, you show a picture (last radio menu) with wifi connection to CarPlay, so I guess is working
unfortunately, it is not working; when try to connect, the phone does not see the wifi of the unit and when try to activate the wifi on it ... the tick box does not work :-(
This option helped to activate wifi for android car wirelessly
Hi, I'm bringing up the old thread again. Does anyone happen to know if it's possible to activate the Canton equalizer interface with the presets (like Speech, etc.)?
