VCDS options on Superb III.FL
7 hours ago, Cairus said:
Why mib?
13 hours ago, Cairus said:
The TSR can be unlocked in every MIB 3. You can also basically remove your 2Q0 camera and install a 3Q0.
The SwaP Protection is on the unit A5 not on the MIB3
So how do I go about changing the camera or getting someone to help me install the right files without paying f £550? 😂
  • Replies 264
  • Views 101.6k
  • Why would you want them off? Auto lights are notorious for people driving around in poor visibility and no rear side lights.   Personally I always code them to be on.
  • https://github.com/olli991/mib-std2-pq-zr-toolbox Here you can find out whether it is suitable for MIB or not
  • Paikesejanku
    Paikesejanku
    Yes, you have to change two values: 09 – Central Electrics - Adaptions Search 'scheinwerferreinigung' (headlight cleaning) Select 'SRA Verzoegerungszeit' and set value to '2000' (don't wor
I have two cameras 2Q0 where I installed a patch to activate all SWAP functions - including TRAFFIC SING RECOGNITION.
So all You have to do is replace the camera and remove CP (eventually do some basic codings).
2Q0 980 653 H:11 SW:1027
2Q0 980 653 D H:16 SW:1401
If You are interested - contact me 😁
Why Change Camera? Firmware Update?
You can change to mine camera or I can update it remotely if You have ODIS interface.
But from my point of view it will be easier a lot just to "patch" camera on bench and then change it.
Misunderstood, poor translation on my part. I meant that I think replacing the camera is unnecessary.
Yeah - it can be done without replacing the camera.
But You need ODIS Online and a knowledge how to do it.
But still - if You want replace 3Q/5Q cameras to 2Q0 is a perfect solution.
And for most of people it will be just easier to change the camera instead of "patching" unit.
Hello, I also have a Superb FL 2019 with Matrix headlights. I’m not sure if I’m writing this correctly, but these are the adaptations for 09-Central Electrics. What do you have in the parameter Aussenlicht_Front (0A58) - Abblendlicht_Leuchtentyp (0/0/2)?
I have H7 there, and I don’t know why, since I don’t have halogen bulbs but LED Matrix headlights.
I have taken a screen shot of my STG09 section in ODIS that you are looking at.
It is a 2023 SIII.
Do you have any problems with the light?
Edited by 26DIPP
My DRLs were not working in the AUTO position, but now they are. I’m only interested in the Abblendlicht_Leuchtentyp parameter – it is set to H7 (halogen headlights), even though I have Matrix headlights. So it should probably be set to GDL_mit_Zusatzscheinwerfer. But if you also have it set to H7, then it’s probably correct.
Hello,
any way to remember last used drive mode please? Like individual?
Edited by brsk
Yes, you have To Change the Dataset for the driving Profils in the Gateway
any guide please?
@zacko_O
that's not about FL ☹️
22 minutes ago, MartiniB said:
@zacko_O
I did same for FL, no worries )
The difference is:
preFL only DSG mode returns to Normal
FL mode entirely returns to Normal
For FL need a little bit more edits as described above
Edited by zacko_O
Does anyone coded to switch on interior light after ignition off instead of after opening the doors?
It annoys me a lot.
Hello,
I retrofitted heating steering wheel to my Skoda Superb MY2020.
It's a face lift model, but it came from factory with "old" steering wheel - as many of early lift models.
From factory the steering wheel was heated.
But now I changed the steering wheel to the "new" one with capacity sensor.
I coded everything properly, but from the button on steering wheel I can only turn ON/OFF heating. I know there is a possibility to turn on the 3 level of heating option.
I'm starting assuming that it might be because of low FW version in my HVAC panel.
I think it will work with 3V5 module, but I want to try code it in this panel.
Do You have idea what else I can do?
Or maybe someone has access to the 3V0907044 firmware higher than 4XXX?
Wednesday,24,December,2025,11:40:04:16626
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250822 DS365.0
www.Ross-Tech.com
Dealer/Shop Name: Diagnostyk.pl
Workshop Code: 777 12345 089765
VIN: TMBCJ7NP9L7011843   License Plate: MOJE
Mileage: 170288km-105812mi   Repair Order:
Chassis Type: NP-SK48 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 15 17 19 22 23 2B 36 3C 42 44 47
          4B 52 5F 6C 6D 75 A5 BB BC CA D6 D7
VIN: TMBCJ7NP9L7011843   Mileage: 170288km-105812miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
23-Brake Booster -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 0100
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 027 P    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H26 9497
   Revision: B4H26---    CVN: 6E79B040DAF1CE2E5D3F3C3E
   Coding: 01250412036605083000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906027P 005003
   ROD: EV_ECM20TDI01104L906027P.rod
   VCID: 38292DCD52D784EA763-806C
   VINID: 91D4936877A025C1C00412040C95878E45
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0GC 300 013 K    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2405
   Revision: 00H06V09    CVN: 705A9222
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061.rod
   VCID: 2C01019D968F384A02B-8078
   No subsystems:
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 FA    HW: 5Q0 614 517 BR
   Component: ESC           H82 0190
   Revision: 00000000    Serial number: 62089000001821
   Coding: 1D077A9C31213B6D477F070460C649B85E8CDCE2E006927538615078D2894A0B0002000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 75B7E4F905453982AD5-8020
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0522954008 Dataset Number: V03935290ED 0001
   Coding: 0F20000723
   Shop #: WSC 00033 790 00105
   ASAM Dataset: EV_KessyHellaMQBAB 004052
   ROD: EV_KessyHellaMQBAB_004_VW37.rod
   VCID: 45D754391525E902FD5-8010
Address 06: Seat Mem. Pass (J521)       Labels:* None
   Part No SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
   Component: Sitzmemory    H09 0026
   Serial number: Y0007SG922574
   Coding: 001000020000150001C280808080000000008181000000D400
   Shop #: WSC 12345 777 89765
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide_VW37.rod
   VCID: 3FDB46D177F9B3D2B79-806A
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 3V0 907 044 FM    HW: 3V0 907 044 FM
   Component: AC Automat    H34 4803
   Revision: 20K10000    Serial number: 00000B01427151
   Coding: 11010104002410011004004100105032
   ASAM Dataset: EV_ACClimaPrehVW37X 002027
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 0451893D5E9F100AAAB-8050
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 CF    HW: 5Q0 937 086 BR
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: J53F08071900K0 Dataset Number: V03935307JU 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020_VW27.rod
   VCID: 0059852D4A870C2A8E3-8054
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 190617  032  0121
   Serial number: 00000001906130308371
   Coding: 165DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: SBY19M07D10H22M03S39
   Coding: 0088DF
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY191800HT8
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004  0007
   Serial number: 00000000000000509315
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 521 DH    HW: 5Q1 953 569 C
   Component: Lenks.Modul  H33  0170
   Serial number: 0100080420200C103093
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058619193 Dataset Number: V03935302KA 0001
   Coding: 0471155851
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_009_AU37.rod
   VCID: 50F9756DDA673CAA5E3-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
   Component: ACC BOSCH MQB H01 0771
   Dataset Number: V12345678AA V305
   Coding: 32055FF159FFCF28949F812581400680000000000099400076
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW41.rod
   VCID: 46D553352823E21AF4F-8012
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BS    HW: 5Q0 959 655 BS
   Component: AirbagVW21    007 0403
   Serial number: 003FMR5JZMCV Dataset Number: V03935308KP 0001
   Coding: 98CCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 127DBF6514EB8EBA287-8046
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 002 607 19
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000E455CED3%
   Coding: 2D2D2D
   Crash sensor for side airbag: passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 480 002 907 19
   Component: SideSensor_Pf  001 0887
   Serial number: 3580000000095B6D7E3+
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 480 401 307 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001A6F03BAE61729
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 480 402 607 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001B0F08AF8617FL
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 402 607 19
   Component: FrontSensor_D  003 6149
   Serial number: 3550001AB2BD5E53216B
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3V0 920 790 D    HW: 3V0 920 790 D
   Component: KOMBI         502 4191
   Coding: 09AD001AEF8C0008018D770B0001000880000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5502
   Serial number: 15071911600851 Dataset Number: SET_FPA_MOD 0001
   Coding: 0B0100045F0873008B1002DA180F00010001070000000000000000000000
   GVL: 01C63C000900060840FC80008082C80010000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5B06D1377973D2F79-802A
   Generator:
   Component: 4-00-05-00-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5E3 919 719 N    HW: 5E3 919 719 N  Labels: 3C8-959-537.CLB
   Component: t.ly/hSCQu  H50 0500
   Serial number: PR6-0440062344212368
   Coding: A70000
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 7608581905
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: U13DCAC  H27 0810
   Serial number: 2137219
4 Faults Found:
131616 - No Communications with Undefined Control Module
          U1126 00 [00001001] - -
          [Timeout Knoten 0x20]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:30:11
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
131695 - Digital sound System control module
          U106A 00 [00001001] - No Communication
          [Timeout Knoten 0x6F / 47 - Steuergerät für digitales Soundpaket]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:10
                    Terminal 30 power supply: 11.9 V
                    Terminal 15: On
67072 - Local Databus
          U1125 00 [00001001] - Additional Installations Detected
          [Subsystem Mehrverbau erkannt]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:10
                    Terminal 15: On
15360512 - Component Protection
          U1101 00 [00001001] - Active
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:10
                    Terminal 15: On
Address 22: AWD (J492)       Labels:| 0CQ-907-554-V1.clb
   Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00004.07.19 Dataset Number: v1260x015G0 0000
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004_VW37.rod
   VCID: 4CC1611D364F184A22B-8018
Address 23: Brake Booster (J539)       Labels:. 5QE-909-059.clb
   Part No SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
   Component: EBKV          H06 0069
   Serial number: BPA085190619013
   Coding: 0102C500340000C618638C31000049922449920400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
   ROD: EV_BrakeBoostG2BoschVW48X_011_SK48.rod
   VCID: 3B2332C163E1AFF29B1-806E
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 19000199603003
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_SK48.rod
   VCID: 33331AE14BB167B2431-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Serial number: Y0007SG921992
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
Address 3C: Lane Change (J1086)       Labels:| 2Qx-907-686-V2.clb
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0149
   Serial number: 00000522863366  Dataset Number: V03935306BB 0001
   Coding: 52954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   VCID: 392F28C969DD9DE289D-806C
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0149
   Serial number: 00000522999983
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0480
   Serial number: 0000382776037  Dataset Number: V03935303TQ 0001
   Coding: 001D8820DE00020000001100
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 4DC76C19CD551142355-8018
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5082
   Dataset Number: V03935289T  0001
   Coding: 91970000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C2131DD66EFA8CA92B-8068
Address 47: Sound System (J525)       Labels:| 81A-035-466.clb
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1KJE0805WA Dataset Number: V03935263JW 0001
   Coding: 0384010001AA002FAA0000000000
   ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
   ROD: EV_AMPMst16C5Gen2ALPI.rod
   VCID: 59EF8849899D7DE2A9D-800C
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 11071910803020 Dataset Number: V03935308TC 0001
   Coding: 00000007090008F200003D13010000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372B2EF15FC98B927F9-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0480
   Serial number: 0000382848586  Dataset Number: V03935303TR 0001
   Coding: 001D8020DE00020000001100
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 565 035 021 E    HW: 565 035 021
   Component: MU-H-LND-EU   H55 1440
   Serial number: A853J0JB077087 Dataset Number: V03935314JG 0001
   Coding: 03840101000000004111000200080A002F020DE401208400DF
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   VCID: 1079B56D1AE77CAA1E3-8044
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 3V0 919 606 D    HW: 3V0 919 606 D
   Component: ABT_High-2  H52 9130
   Serial number: SKZ6ZHW1322758
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 823 HL    HW: -----------
   Component: ECE 2026  --- 0430
   Serial number: --------------------
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1017
3 Faults Found:
1543 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:14
                    Voltage terminal 30: 12.1 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
1555 - Check Software Version Management
          B201A 00 [00001001] - -
          [Check software version management]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:19
                    Status_Software_Version_Management-module_name: MDUK619/Main
          [Anti-theft protection - component protection active (0xEA6200)]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:14
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Dataset Number: 83A909460A  0006
   Coding: 0484060122002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
1 Fault Found:
10489856 - No Basic Setting
          B2010 00 [00001001] - -
          [RearView system not calibrated]
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:09
                    passive
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C737-6291-8 Dataset Number: V03935272KG 0001
   Coding: 1008
   ASAM Dataset: EV_DeckLidCONTIAU736 001017
   ROD: EV_DeckLidCONTIAU736_VW37.rod
   VCID: 48C95D0D2237F46A063-801C
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------    Dataset Number: V03935303EX 0001
   Coding: 03840101EA423A0D3F1C9E020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3D273CD97DF5A1C2A55-8068
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H11 1031
   Serial number: E33417008192120 Dataset Number: V03935317SN 0001
   Coding: 00020898216C402810DF14001030008001430000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW48.rod
   VCID: 72BDDFE5742B2EBA887-8026
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 8W0 959 595 M    HW: 8W0 959 595 J
   Component: TSG HFS       010 0384
   Serial number: 0000384856674  Dataset Number: V03935299VS 0001
   Coding: 001880208000020000001100
   ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 56F58375F883529A84F-8002
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      010 0384
   Serial number: 0000384822745  Dataset Number: V03935299VR 0001
   ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Component: SAD_STG_1     006 0002
   Dataset Number: V03935282YQ 0001
   Coding: 408000648101
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_SK48.rod
   VCID: 76B5E3F51843329AA4F-8022
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 992 941 571 AA    HW: 992 941 571 A
   Component: LED1L         H08 9002
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
   ROD: EV_LLPGen3LKEBODPO68X_001_SK48.rod
   VCID: 619FA0A9A1CDA522E1D-8034
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H08 9002
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
End----(Elapsed Time: 02:15, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
------------------------------8 Faults Found-------------------------------
5 hours ago, Szogun said:
Hallo,
ich habe in meinen Skoda Superb (Modelljahr 2020) eine Lenkradheizung nachgerüstet.
Es handelt sich um ein Facelift-Modell, aber ab Werk war – wie bei vielen frühen Facelift-Modellen – das „alte“ Lenkrad verbaut.
Das Lenkrad war ab Werk beheizt.
Ich habe es nun gegen das „neue“ mit Kapazitätssensor ausgetauscht.
Die Codierung habe ich korrekt durchgeführt, aber über den Knopf am Lenkrad kann ich die Heizung nur ein- und ausschalten. Ich weiß, dass man die drei Heizstufen aktivieren kann.
Ich vermute, es liegt an einer zu niedrigen Firmware- Version meines Klimabedienteils .
Ich denke, es würde mit dem 3V5-Modul funktionieren, möchte die Codierung aber erst einmal in diesem Bedienteil ausprobieren.
Haben Sie vielleicht eine Idee, was ich noch tun könnte?
Oder hat vielleicht jemand Zugriff auf die Firmware 3V0907044, die höher als 4XXX ist?
www.Ross-Tech.com
   Coding: 0014
   No subsystems:
   Coding: 0F20000723
   Coding: 165DDD
   Coding: 0088DF
   Alarm horn:
   Coding: 0471155851
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: A70000
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:30:11
                    Terminal 15: On
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:10
                    Terminal 15: On
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:10
                    Terminal 15: On
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:10
                    Terminal 15: On
   Coding: 0301
   Coding: 52954640
   Coding: 91970000
   Data carrier:
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:14
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:19
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:14
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 170288 km
                    Date: 2025.12.24
                    Time: 11:26:09
                    passive
   Coding: 1008
Unit 08:
Heated_steering_wheel_version ---> LRH_Gen_2_mod_with_longpush
On 24/12/2025 at 22:22, Cairus said:
Unit 08:
I tried with every combination in that byte:
LRH_Gen_2_mod
That didn't work for me
Have the cables been laid? The heated steering wheel has its own cable to the fuse box
The heating itself is working.
But I cannot activate a 3 levels of heating turning on via steering wheel button.
On the pre fl steering wheel - it can be done vie MIB unit.
But on the fl version - the activation is moved to the button on steering wheel.
Which Gateway you have?
I flashed it to the highest possible version:
SW:3Q0-907-530-AR HW:3Q0-907-530-C
Which Dataset?
In our kodiaq i have Button steering wheel and mib. You have Code the Button in the Gateway?
