Blind spot assist retrofit
6 minutes ago, Vincent_83 said:
Ho no, after somes kilometers, I have a error
Correct brackets?
Correctly installed?
Correct dataset?
Correct brackets?
Correct dataset?
  • Replies 244
  • Views 24.5k
  • I  am almost done with the materials.  Here the most important.      Left radar 2Q0907685H  Right radar 2Q0907686H (master) Bracket on the left 5E6907456A
  • I've had VCDS for well over 10 years and it's paid for itself many tmes over with £100 in garage fees saved everytime I (or friends) have needed a fault diagnosis.
  • Could you please open your topics in the karoq area and create a thread for each topic?
Did you download the proper data set file to your radars;
14 minutes ago, East_Yorkshire_Retrofits said:
Correct brackets?
Correct dataset?
Correct brackets?
Correct dataset?
Correct brackets :
I have installed 658907455 / 658907456 brackets and with the information I have, it's for Kamiq (not for Scala) : OK
Correctly installed :
I think but I see the fault is on Master side (right) and this unit come with a physical default on one of attach. --> to be investigated
Correct dataset :
I have installed dataset V03935363XP which is for Troc --> Maybe I have to installed for Kamiq but I don't find this (on VCTool) --> to be investigated
t Roc dataset works without problems on the Kamiq where I made the parameterization
So, I think the issue is due to the default on Master unit (on right side).
For the left side (slave unit), the fault code is different.
I have to check my fitting
I have rework my assembly and put a shim under the radar.
Dynamic angle reduce to 8° to 1.5° so it's good. With these changes, all work perfectly.
Did You put:
685 on RIGHT
686 on LEFT
Isn't it?
Can You put a pic of the shim?
3 minutes ago, Benja77 said:
Did You put:
685 on RIGHT
686 on LEFT
Isn't it?
Yes of course 🙃
It was just an installation issuie I think. Support are "flexible" with only 2 attachements points.
I haven't photo of shim but for now, it's just a piece of hard foam and I'm modelling a real shim according to this in order to print a definitive shim.
1 minute ago, Vincent_83 said:
Yes of course 🙃
I'll get one from You if You'll print them in the future! D
The master control unit is normally on the right side in a left-hand drive vehicle, and the connections face outwards.
That might explain why it doesn't work without a base.
Edited by Cairus
I don't find any retrofit of blind spot on Kamiq but according to ETKA reference, I have installed 658907456 bracket on the right side and 2Q0907686B radar on this.
And it's not possible to invert
J769 & J770 do not switch sides for LHD RHD, they're always mounted on the same side. (T Roc for example)
The brackets sometimes change between LHD/RHD depending on the model, due to the blind spots being in different places.
Edited by East_Yorkshire_Retrofits
Feedback from my Skoda Partner
Wrong Installation
My brains (686 and 685, both with final B) come from a Kamiq, so I should just replace the datset with that oine specific for Karoq
1 hour ago, Vincent_83 said:
Yes of course 🙃
SOrry, I have mis reading your text.
685 LEFT and 686 RIGHT.
You write the invert and I'm conform to ETKA installation
Wrong Installation
What is the good installation for a Kamiq ?
On ETKA, Scala and Kamiq reference are on the same page, it's not easy
There are also two options per side for the vehicle's production date.
On ETKA, there is
Date de production
31.01.2023
Correct, but Edeka have one holder Date 2021 - 2024.
The Other 2 Part Number from 2021 - No end
Yes, 1 réf for Scala, other for Kamiq. I'm sure about brackets, it's the good one.
Bracket with 657 are for Scala and 658 for kamiq
No, Skoda have 2 Option
For each side, I have 2 reference :
RIGHT (master) with 2Q0 907 686 B radar :
657 907 456 --> I don't have this attachements points on my Kamiq (I think it's for Scala only)
658 907 456 --> Identified for Kamiq on somes shipping site and I have attachments points
LEFT (slave) with 2Q0 907 685 B radar :
657 907 455 --> I don't have this attachements points on my Kamiq (I think it's for Scala only)
658 907 455 --> Identified for Kamiq on somes shipping site and I have attachments points
I have installed 658 907 456 / 455 on my Kamiq
On the official documentation, we see clearly the connector are inside the center of the vehicule (not than all other VAG car ☹️ )
Finally code 3c module. How can find code for other module ? Any idea ?
I did some notes for my retrofit, i didn't check them so far.
Maybe you can try them to your car.
CP removal needs to be done with ODIS
1) GATEWAY: 19      -Register 3C modules-
Adaptations:
[LN]_Rear_cross_traffic_alert:RTA  [VN]_not_activated --à activated
2) Control unit: 03 Brakes (ABS)
Long coding:
Byte 18 activate bit 3 (already ON in my car)
Byte 30 activate bit 4 (already ON in my car)
Adaptations:
-Delay management:
Rear cross traffic assistant: Not activated --> Activated
3) Control unit: 17 Dashboard
Long coding:
Lane change assistance: No --> Yes
Lane change assistant, BAP distance: No --> YES
Lane retention assistant, BAP distance: No --> YES
Lane_change_assistent: no —> yes
Blind_spot_detection: no —> yes
4) Control unit: 5F Multimedia
Adaptations:
-Vehicle function list BAP:
SWA_0x1A: Not activated --> Activated
SWA_0x1A_msg_bus: Not activated --> Terminal 15
-Vehicle menu operation:
menu_display_lane_assistant: Not activated --> Activated
menu_display_lane_assistant_over_threshold_high: Not activated --> Activated
5) Control unit: A5 Driver Assistance
Long coding:
SWA: Not_coded --> Coded
blind_spot_detection: Not_coded --> Coded
HC_Mob_line: Not_coded —> Coded (this is for automatic lane change)
HC_var(this is for automatic lane change)
6) Control unit: 19 Gateway
Long coding:
PaCo_Rear_Cross_Traffic_Alest: not installed --> installed
7) Control unit: 75 Telematics
Adaptations:
Lane change assistance: Not activated --> Activated
SWA_0x1A: Not activated —> Activated
8) Control Unit: 44 steering assistance
Adaptions:
Qfk_ma_function: Not_active —> Active (this is for automatic lane change)
9) Control Unit: 13 ACC
Long Coding:
Lane_change_support: not activated —> activated
Control_module_for_lane_assistance: not installed ---> installed
