Blind spot assist retrofit
Thanks I trying you are the best!!
  • Replies 244
  • Views 34.7k
  • I  am almost done with the materials.  Here the most important.      Left radar 2Q0907685H  Right radar 2Q0907686H (master) Bracket on the left 5E6907456A
  • I've had VCDS for well over 10 years and it's paid for itself many tmes over with £100 in garage fees saved everytime I (or friends) have needed a fault diagnosis.
  • Could you please open your topics in the karoq area and create a thread for each topic?
Where do you find coding for ABS module ?
From a Russian guy who did the same retrofit to his car.
link from drive2.ru.txt
Edited by Giannis20
I know it’s the Octavia section, but let me share this joy of mine! The retrofit works!!
Reason for which it didn’t before it’s because the first mechanic passed the harness on the LEFT side of the car instead of the RIGHT one (after reading so many posts/threads I never found such clue) and the second mechanic had to have to check the whole harness! Curiously, Lane Assist, Light Assist with Auto Hi-beam, Traffic Sign Recognition and Adaptive Cruise Control are not available and the become so only disconnecting proper the Blind Spot: I believe it’s matter of coding the front camera!
But the fact the retrofit works is even more of what I can imagine!
Edited by Benja77
The planning is finally over. Now all that's left is to calibration.
If anyone knows how it can be done, it would be nice to help me.
Did the codes they gave you work?
Calibrate Made the System self
Edited by Cairus
Yes but missing one from parking sensor.
Edited by alexandros_kolyvas
Ok thanks
Do you live in Greece?
If so, at which shop did you have the removal of CP and coding done?
Yes I live Greece. All shop with odis online can remove cp protection. Cp protection is simply, install from shop chassis number to module and unlocked. Programming and installation complete from me.
Thanks, another question, were the radars used or new when you bought them?
Used is simply for programming
Makes 0 difference, unless they're used & stolen then unusable
After complete all I have one problem. Now Install trailer control unit and must programming lane change assist bit security access is wrong. Have any idea;
Which Tool?
Obd11
IS a Bug. Use a Other Tool
Bug from programmer or control unit. Do you have any other tool to recommend?
OK,
2nd attempt for BSD installation
Used radars with index G
2nd-attempted-with-index-G-radars-(1).jp
The result (from the OBD11 perspective)
2nd-attempt-Screenshot-20251201-183543-O
2nd-attempt-Screenshot-20251201-183925-O2nd-attempt-Screenshot-20251201-183931-O
Because the radars are used, they are already encoded and can be seen here:
img%5D
Next step, removing Component Protection... the most crucial step.
Putting the B version I had no problem (they have NO protection), even if those I put were initially fitted on Kamiq (car 20cm circa shorter than those parametrized for Karoq).
I think that flashing the right dataset I should solve that "problem" (if we wanna consider a problem): however I noticed that the area covered by the radars is pretty wide, they see up to 50m (if not more on freeway)! Furhermore since I installed them, I noticed the exit alert ADAS funtion appeared on the ADAS list on virtual cockpit!
I also noticed that the area covered from the radars appeared on the car when OPS is engaged as well from the area view
Edited by Benja77
#2nd attempt
Today there was an attempt to remove the Component Protection on the BSD radars.
Error !!!!
It seems that this retrifit is never going to happen.
I'm disappointed.
Edited by Giannis20
It seems that you purchased parts that are registered as stolen in VW server☹️
1 hour ago, Giannis20 said:
#2nd attempt
Error !!!!
I'm disappointed.
That's true this part register to stolen.
Are you sure about that?
Faz4990E means that the unit is stolen ? Where i can find that information?
If it is so, i will ask my money back from the seller.
Edited by Giannis20
