Ufuk joined the community
WINDSCREEN
@travs any ideas? I know you can get products than fill in the surface after a polish, but not that much can be done, really.
SuperSkoda Shipping
Never had any issues. I've ordered from them a few times over the last few years - most recent was £200 worth of badges in April or so. Zero complaints. Communication can be a bit iffy sometimes (you'll speak to Magdalena) but they're a good company.
1.5 tsi coolant loss after change
Is there still pressure present if you open the header tank cap say a hour or two or longer after engine shut off?.
Johngerard started following 1.5 tsi coolant loss after change
Dog hair & Cowboys - new boot trims
At this point I’d be taking it back and getting a refund. That’s ridiculous.
Binx1310 started following Dog hair & Cowboys - new boot trims
New headlight cannot adjust the dipped up enough
The motor on the headlight moves up and down as I change the dash level setting to - or 3. Max to min. Yes the white 6mm hex/allen key fitting (is the only adjustment available for the dipped beam) The dipped beam was far too low and I just can not lift the beam up enough with the adjuster The headlamp is nicely seated back in the body and with even gaps around it to the body work and it looks to be the same as the other side so it is sat correctly Can’t see what I can do , I don’t want to force the adjuster as soon as I felt resistance I stopped But it’s far to low to start with Checked bulb seated correctly too bought it mail order from a skoda dealer I don’t see what I can do other than return it as defective
2015 skoda roomster brake lock up
Have you tried to release all the bleed nipples to relive any excess pressure? Thanks. AG Falco
AGFalco started following New headlight cannot adjust the dipped up enough , 2015 skoda roomster brake lock up and Rear DRLs?
Believe it or not When I got the car The backs of the seats where fine The reason the hair is showing Is because he’s used the tool And it’s bringing up the hair and paint It’s chewed through 3 of his tools It’s that thick with paint and dog hair 🙃
The last pic you can get pretty straightforward pet hair removal tools to get rid of. They’re basically very soft rubber that as you rub back and forth they collect the hair. It’s not easy as the stuff weaves itself into the carpet loops but it gets there eventually.
Rear DRLs?
You can program the car to have 'Scandinavian DRL' on. This will turn your front DRL, rear side and number plate lights on when the ignition is turned on. I did this to one of my cars using OBDEleven. HTH. Thanks. AG Falco
Is this the white 6mm hex/allen key fitting? What about the in car headlight aim adjustment wheel? Projector type headlamp assembly. Thanks. AG Falco
Front wiper blades on 2026 SEL
Changed mine to Bosch straight away, lovely! FP
FabiaPilot started following Front wiper blades on 2026 SEL
Crank but no start 2.0TDi
Issue has finally been resolved, Cylinder 3 injector had failed and was leaking fuel back to the pump. Now I probably need to replace the other 3 at a cost of nearly €300 an injector for the part alone.
Rear DRLs?
For safety’s sake, i would like to add rear DRLs - i think they should be standard, like on my previous car, a Volvo. There are suitable vertical surfaces on the rear bumper below the reflector to fit separate lamps, but i’m wondering about how best to do the wiring. Does anyone know if there’s an ignition controlled circuit in or near the boot to tap into? If there isn’t, where would be the best place? Thanks in advance
Baxlin started following Rear DRLs?
- Skoda Karoq Build Label Location(s)
Apparently common in the trade Even my detailer said that Just some people are worse than others
How did you do it? Which repo did you use?
Christ on bike! I've heard it all now! That's the height of cowboyism... I would be naming and shaming the sellers.
Hi. I'm looking at Karoqs around 3 years old and interested in seeing the PR codes before I choose. I'm pretty certain that a car around that age wil not have a service book with the build sticker attached, is there still a sticker under the boot floor cover? If so, could someone give me an idea where to look. I had a quick look in a car a few weeks ago and couldn't see one but didn't have much chance to search (it was pouring down). I'm looking for a car without SFD2 which I understand was introduced in builds late March 24 onwards. Cheers Andy
Thank you DerekU I will check it out. I’ve never had this on a new car before.
2nd year service coming up, what should I look out for? Not driven it much
I buy oil and filters then take my car to a nearby garage (5 minute stroll) to simply change the oil and reset the service light. Brake fluid, pads and discs when the time comes. Changing air and pollen filters takes 5 minutes. And online filters cost peanuts compared with a dealer. All products are the Real Deal. Saves a fortune.
What bulbs are fitted to the S3 & upgraded bulb recommendations
I’ll check the manuals see if there’s a list Edit. No list in the manual. It does go through each individual bulb and how to change it but it lists bulb type as part of that rather than one master list.
I did see What I started writing down Just lazy lol
Error: selector lever...
Hello. Same issue. Got it booked into Maidstone Skoda for 12 Nov. I just wanted to check that you have not had the error message again after the fix?
AndrewK started following Error: selector lever...
2016 Fabia with the dome lense over the dipped beam bulb
