  2. Ah yes. Good spot. I think the process is the same but need to make sure you get the right update package. If you put your existing software train into MiB helper it will tell you the latest version. If there is more than one version between your existing and current one you may have to upgrade in stages https://mib-helper.com
  3. yes, u can fit the mufflers off a 280 on to ur 220, but u'll need to either cut out ur rear diffuser so the exhaust tip can stick out, or u need to change the rear diffuser to the 280 version. the centre exhaust pipe and rear pipes leading to the mufflers r different between the 280 and 220. the 280 having the AWD haldex routes different under the back half the car compared to the 220 without a haldex. the mufflers on the 220 point downwards. the mufflers on the 280 r straight out. BUT.....more importantly - u gain NOTHING by fitting the mufflers from a 280 on to a 220. ur better off getting sports mufflers, or resonator delete pipe and/or downpipe.
  4. mine originally came with LED lights for the interior. only the boot had halogen versions, which i replaced with LED ones from Kopacek. perhaps u can look at Kopacek for interior "OEM" versions?
  5. Today
  6. based on the hardware part number - u have a MIB2 Amundsen unit. the guide i created is for a MIB2 Columbus. hence i would refrain from using the how-to-guide i created. i don't know wat the firmware upgrade process is for Amundsen unit.
  7. It’s a hack of the MMI—specifically, the Audi MIB High system.
  8. Yesterday
  9. Hence, what I said the other day about the UK has zero plans, etc., and yet we allowed Grangemouth to close, Port Talbot steelworks, gas reserves, etc., to be sold. All our utilities are foreign-owned, leaving us completely vulnerable. The UK is in a very bad position because of a whole string of poorly thought-out decisions that were not in the best interests of the country or the majority of the population.
  10. I’ve got Clubsport reps holding up well. Online place called powerbrakes do SHW performance versions (I think SHW are OE supplier to BMW and Audi). Golf CS reps I made the mistake of DS2500 though which are made of more brake dust than every other brake pad put together.
  11. Ron joined the community
  12. More in mainstream uk news that UK has much less stock of oil and gas that other countries and as party conference on in Liverpool at the moment the chance to question ministers but we are not hearing strategies. There are sone plans out about what woukd happen if the powet goes, from stations cannot pump gas, what foods people should stick pile etc. Winter of discontent could rather be a winter of survival especially if the UK winter is unusually grim as increasingly predicted.
  13. Being an ex mechanic but not of greatest of health I bought my kamiq with a two year warrenty at 7000miles and 14 month old I changed the oil when I bought it because it was obvious it hadn't been changed I got the "free" service this year in July at 12000 miles the oil was changed but the service advisor said your brake fluid needs changing, I declined after showing the brake fluid tester showed 0 percent water the brake pads and disks were reported as needing changing, again absolute rubbish as disks where nor worn and pads less than 1 quarter worn front and rear the cabin filter had not been changed original build date on the filter when I replaced it myself It's a shame because I hoped the dealer would be good to use All I can advise is check as much as you can, especially when parts have dates on them and question everything
  14. satire111 commented on satire111's gallery image in Skoda Kamiq
  15. You seem to have gone through more bottom arms than anyone i know 😳 Glad to hear you are getting somewhere with it. I'm keeping an eye on my rear links being Whiteline and my fronts failed prematurely but so far they are holding up. Time will tell. Will replace my front rotors too next year thinking going Clubsport S discs unless i find something else😁 Next year I'll be getting the timing chain replaced with all the tensioners as well as new uprated water pump and thermostat housing. For now i need to save some cash as this year i spent far too much going stage 2 and installing Brembo 4 pots on front 😎 My subframes are still oem, no plans to replace them anytime soon 🙃unless car decides otherwise 😀
  16. We just about missed the Sunset this evening Love the ripples 😵‍💫
  17. Thanks for the info @imart143 i keep getting distracted / volunteered to do other jobs and keep forgetting to check the engine bay,, ive just put my keys in an envelope with a reminder to check tomorrow on the way out 🤪 Thank you for the link @D402 it says it also fits mine (DFGA engine) will see about adding it to the parts list in a week or so ,,,, if im allowed time to do some of my outstanding jobs... in the mean time,,, im goin to search / post Another question for a job that probibly wont get done until Nov 🤪
  18. Well moral as in whether you want to get rid of it or not and live with it. It was never an issue about emissions as it would still pass without it. Interesting read on MOT regs changes. Certainly looks to ramp up the MOT requirements and enforcement.
  19. @lol-lol That incident at RAF Fairford: the suspects have been released on bail and all come from London, and no explosives were found. The barrels in the vans were empty, and it would seem that they were attempting to steal diesel from farmers' fuel tanks and sell it because of the high London prices for diesel.
  20. The 2.34 tonnes if the Gross Vehicle Weight ie max weight allowed on the road and this is what the licence reading cameras work on to catch those who should be paying the extra parking charges in these cities applying these rules. My Scenic is roughly 1.75 tonnes sat by the kerb with washer fluid etc and can take almost 600 kgs of people and cargo and be legal classed as below the 2.4 tonne limit as it GVW as recorded on the V5 and DVLA as sub 2400 Kgs. Skoda bigger cars can be as low as 1560 Kgs kerb but also as high as about 1850 KGs kerb ie diesel, 4x4 and all the toys and the GVW nearly 2.4T, or close to 2.5 tonnes, which would seem to indicate that the payload, passengers and luggage allowed might be only about 500 Kgs which either sounds wrong or very poor as it is not difficult to hit 500 kgs with passengers and say luggage for a holiday. Check yours as the diesels look to have less headroom and you would not want a ticket for overloaded. Spent many a day on multi disciplinary exercises with the police, two departments of Dept of Transport, DWP and us as HMRC intercepting Bootleggers of Alcohol and getting them on overweight q was one of our best tools, as well as me seizing the cargo and the vehicle of course ! So cars have surprisingly small differences between their kerb weight and GVW. To me it should be at least a good 600 kgs in a C or D segment car but some are a bit less than that and the owner dies not realise it and is sometimes driving over the manufacturers weight limits and therefore illegally.
  21. Is it just moral? Potential new regulations on mot in 2027. Unless that’s just diesels. Recently discovered mine hasn’t done a regen in 50,000 miles or so. That might get interesting.
  22. Hi, a new battery did work, also the red light is now flashing which I forgot when the fob is near the car. Thanks, I should have tried that option first. Thanks again.
  23. Personally next choice would be downpipe. But if you have a GPF you have a moral dilemma about what you do with that…
  24. Potentially. I had a 2026 Audi A5 estate for a hire car over the summer and, aside from having 3 screens (digidash, normal screen and a third for the front passenger), it mirrored Google Maps in full. So perhaps this brings that software into our version…?
  25. 1 - not 4x4, but the 280 is the only one (it’s not the only 4x4 as there is a diesel one). 2 - do you mean can you cut the tailpipes off the 280 exhaust and fit it to a 220? Ummm no. The 220 will be a FWD variant of the ea888 design which routes differently because of the haldex. There will be better things to do. The thread I linked to had some chat - did you replace the resonator @tombee ?
  26. Well if your EV Scenic weighs in at 2340 Kgs, then it is heavy, my owners manual shows my Kodiaq, 4x4 TDI 110Kw Edition 5 seat and it has a large Ad Blu tank fitted, and comes in at just 1762 Kgs, 582 Kgs lighter . It is also 227 mm longer as well.
