Front wiper blades on 2026 SEL
Changed mine to Bosch straight away, lovely! FP
FabiaPilot started following Front wiper blades on 2026 SEL
Crank but no start 2.0TDi
Issue has finally been resolved, Cylinder 3 injector had failed and was leaking fuel back to the pump. Now I probably need to replace the other 3 at a cost of nearly €300 an injector for the part alone.
Rear DRLs?
For safety’s sake, i would like to add rear DRLs - i think they should be standard, like on my previous car, a Volvo. There are suitable vertical surfaces on the rear bumper below the reflector to fit separate lamps, but i’m wondering about how best to do the wiring. Does anyone know if there’s an ignition controlled circuit in or near the boot to tap into? If there isn’t, where would be the best place? Thanks in advance
Baxlin started following Rear DRLs?
- Skoda Karoq Build Label Location(s)
Dog hair & Cowboys - new boot trims
Apparently common in the trade Even my detailer said that Just some people are worse than others
How did you do it? Which repo did you use?
Christ on bike! I've heard it all now! That's the height of cowboyism... I would be naming and shaming the sellers.
Hi. I'm looking at Karoqs around 3 years old and interested in seeing the PR codes before I choose. I'm pretty certain that a car around that age wil not have a service book with the build sticker attached, is there still a sticker under the boot floor cover? If so, could someone give me an idea where to look. I had a quick look in a car a few weeks ago and couldn't see one but didn't have much chance to search (it was pouring down). I'm looking for a car without SFD2 which I understand was introduced in builds late March 24 onwards. Cheers Andy
Thank you DerekU I will check it out. I’ve never had this on a new car before.
2nd year service coming up, what should I look out for? Not driven it much
I buy oil and filters then take my car to a nearby garage (5 minute stroll) to simply change the oil and reset the service light. Brake fluid, pads and discs when the time comes. Changing air and pollen filters takes 5 minutes. And online filters cost peanuts compared with a dealer. All products are the Real Deal. Saves a fortune.
What bulbs are fitted to the S3 & upgraded bulb recommendations
I’ll check the manuals see if there’s a list Edit. No list in the manual. It does go through each individual bulb and how to change it but it lists bulb type as part of that rather than one master list.
I did see What I started writing down Just lazy lol
Error: selector lever...
Hello. Same issue. Got it booked into Maidstone Skoda for 12 Nov. I just wanted to check that you have not had the error message again after the fix?
AndrewK started following Error: selector lever...
New headlight cannot adjust the dipped up enough
2016 Fabia with the dome lense over the dipped beam bulb
2tite started following New headlight cannot adjust the dipped up enough
Help needed The led DRL on my right drivers side head light failed as the headlight sprung a leak at the seam between lense and plastic case next to the wing Bought new skoda headlight from skoda dealer and fitted it but the dipped beam is just far to low Odd but the nylon adjuster looked as though some tool had already been on it so I was suspicious The main beam was ok with a tweak to its adjuster which was in perfect order I have rotated the dipped adjuster until i feel resistance. ( anti clockwise was lifting beam seemed odd direction as main was clockwise to lift ?) but it dipped beam still pointing down onto road and far lower than than it should be
Oil pressure regulation valve P164E00
Hi I am about to do the same with my one as I have the very same code on my car now . Ordered the plug with wiring just in case my ones are broken to replace them as I am there and now looking for the valve itself. Can you still get them oem valves ? Really appreciate your time here sharing all the info you have and experience 😀 Thank you!
myxailcho started following Oil pressure regulation valve P164E00
This 1-year-old topic may be of interest https://www.briskoda.net/forums/topic/536354-wipers-very-noisy/#comment-5981475
the first few posts on this thread lists nearly all of them
Mostly... 😐
zzeelljjkkoo started following Front wiper blades on 2026 SEL
octavia mild hybrid generator belt sound
Hello, I’d like to bring up an old thread of mine again. Does anyone have any ideas regarding my issue? It seems that the authorized service center doesn't even know what to do or suggest—according to them, everything is fine. The sound in the link occurs almost every morning, or during the day after the car has been sitting for a while. Lately, it has also been happening after long drives. The sound appears when the car is rolling in 'D' (Drive) gear, or when starting to move in 'D' without pressing the accelerator pedal. As soon as the car comes to a stop, the sound disappears. They replaced the belt tensioner this week, but it didn't help. Also, besides this sound, there is some jerking when accelerating. Thanks for your thoughts. https://youtube.com/shorts/4iBDhxFsDdc?feature=shared
Crikey are the OE front wiper blades this noisy on all Fabia’s?
DaveP61 started following Front wiper blades on 2026 SEL
Skoda News
Skoda 3D printable accessories https://www.skoda-storyboard.com/en/skoda-world/printly-clever-custom-accessories-you-can-3d-print-yourselves/ 'The world beneath the upholstery' https://www.skoda-storyboard.com/en/skoda-world/the-world-beneath-the-upholstery/
Firmware Request MST2_EU_SK_ZR_P0480T
Should I perform an update for the software, or should I continue using it as is?
Is there an explanatory video?
