  2. Hi all. I am about to tackle this subject again now that I am well enough. I have an 'oil leak' from the rear of the block midwayish but sump plug end. This appears to come from the oil seperator / diverter and one way valve area but as with a lot of leaks difficult to pin down. I am going to change the one way valve myself and would like to do the diverter myself too. Has anyone on here either done this on their car or if not has had it done by a mechanic and if so how much. Any tips/info on doing either job will be very welcome.Pic shows the diverter I am talking about. Thanks in advance. Graham
  3. Today
  4. Just wanted to share more widely something which @Cedwing found and posted on this thread: you can now download PDF versions of owners manuals for recent Skodas. This used to be true for older Skodas, but for more recent ones they started using HTML manuals which you couldn't download as PDFs... until recently. Just go to https://www.skoda.co.uk/apps/manuals , pick the car model/ production period etc that you want, then use the download link to the right of where the text starts: Or you can apparently use the My Skoda app (not tried this myself)
  5. There's an Audi service bulletin for this exact code and symptom number, B107B with 13959168. It says the newer ultrasonic sensors flag dirt, ice or other outside interference with that code. If it only comes and goes, it says to leave it, and that changing the module or sensors without a clear finding won't fix it. If it's there all the time, like yours, it points at one of the sensors, its mounting or the wiring. The checks it lists are dirt, ice, stickers or anything stuck on the bumper, the number plate being fitted properly, any knock damage to the bumper or underside, stone chips on the sensor faces, and whether the sensors and the trim around them are seated properly. If all of that looks fine, look at the measured values in the parking aid module. There's a settling time value for each rear sender. Watch them while someone walks up to the back of the car. The good ones should change as they get closer, and one that stays stuck or behaves differently from the rest is your suspect. Unplugging each one only proves the wiring to it, not that the sensor itself is reading properly.
  6. Yes - the instruction manual probably trumps my 'pre-2020' memories of fitting it. Though I remember spraying it up in matt black IN my flat at the time, within a makeshift 'paint booth' I setup in the hallway using hanging plastic sheeting... whilst my other half was away for a girls' weekend - and managing to get away with it, minus the lingering (but delicious) smell of solvents 😅. It was initially a bit fiddly to fit, but been fine ever since. Even the DIY paint job is still mint, probs due to many layers of primer, black, and clearcoat in my frenzied painting weekend... 😉. Yes, give us a shout if any Qs.
  7. lagerzok joined the community
  8. Plenty have made the same comments over the years on this forum as the op but usually in the Karoq section. And the questions @Warrior193 asked are the common ones to ask.
  9. Jonboy984 changed their profile photo
  10. I am still missing the "headlight range adjustment" adaptation in control unit 09, the BCM.
  11. Hi, My wife and I have experienced similar issues with driver profiles and personalised settings on our Elroq RS MY2027 running software 6.0.1. As many owners across Europe are reporting various software issues, I've launched an international petition asking Škoda to provide timely fixes, a reliable update schedule and better customer communication. There is also a separate owner survey to document the issues statistically. Petition: https://www.petitions.com/koda_elroq_my27_owners_for_reliable_software Owner survey: https://forms.cloud.microsoft/r/x6T3xR3yJb The survey results will be submitted to Škoda together with the petition. Please feel free to participate and share the links with other MY2027 Elroq owners. Thank you! Erik
  12. Loupblanc joined the community
  13. Due to some reduced power issues I am having, my garage, says they have done a smoke test and there is a leak in the metal turbo intake pipe. The garage says it's not a standard pipe but I disagree. I've got the 2007, vRS SE, 1.9PD TDi BLT engine fitted with a GTB2260 turbo. I fitted the turbo and FMIC some 10 years ago and on the inlet, the only additional part I got was an intake pipe coupler, for the larger diameter inlet on the turbo. Does anyone have a part number for the standard/OEM vRS turbo inlet pipe. (Like the one in the picture). Any help appreciated.
  14. Don't get that on my 1.5DSG. It is a powerful FWD though so if you are expecting to simply stamp on the throttle you will get some wheelspin, just like in any FWD car.
  15. @TerryGP When you say yours cannot be switched off how are you trying to do so? Should be able to tap the button on the steering wheel to bring up the various options and untick the Lane Assist option. Can still do that on our Karoq bought new in March.
  16. Yesterday
  17. I don't think you need the app - I just went (on my laptop) to: https://www.skoda.co.uk/apps/manuals ...and picked a Skoda model, and the PDF download link is there too.
  18. Your ABS Wheel speed sensors could be dirty and or broken. Your tires made of harder rubber depending on make and type. Tyres over inflated for the weight of the car. Driving skills? And I don't mean this rudely. If you know the car is powerful enough to spin off the line. Learn to get off the line and immediately short shift to second. Or get accustomed to pulling away cautiously. Does the car do it in the dry, or the wet? Do you have the habit of stamping on the throttle. The car can't change what it does. But the driver can adapt to make sure the car behaves. Its all about experience.
  19. Yes, I have a rear camera and it is clean and working normally.
  20. Graemed15 joined the community
  21. Hello, this is my first post :) I write question about pre-facelift fabia. Is it possible to fit original monte carlo parts to stock fabia? I saw that diffuser fit, but I can't find any information about rest of parts.
  22. Park Distance Control: please clean rear sensors - 2022 Octavia 1.4TSI iV Hi, I am getting this message on the display and NONE of my rear parking sensors are now working. The front sensors are working fine. The scanner fault code is B107B or 13959168 rear parking sensor ice, dirt or environmental influence. It does not appear to be an issue with an individual sensor, if I disconnect any one of the rear sensors the scanner will identify that sensor as being disconnected. I have disconnected and reconnected the battery in the hope it might reset it but no joy. Any idea what my issue is or how I might go about further fault finding it.
  23. Welcome to the forum. What tyres does it have on? Are the tyre pressures correct?
  24. Does vnci 6154 work the same? They’re much cheaper than vas https://www.obd2shop.co.uk/wholesale/vnci-6154a-vag-diagnostic-tool.html?gad_source=1&gad_campaignid=22158049574&gbraid=0AAAAA-tYH4gLXtC0uR2X3OZAFbsqtiakj&gclid=CjwKCAiAlKrYBhBuEiwA4o3xo5msqzdEwPAsN_ww26PdRsjXXdyX_6CI-9_YfBl8LcpqZZGR-IcBlBoCpWwQAvD_BwE
  25. Ok, understandt… regret being so far away from Austria…
  26. Thank you. Does that mean it would work in another car if it had a similar spec or it needs the data from VCDS(?) and sending back to you for it recoding?
