1.6 TDi Greenline glow plug replacement
This is my original thread. There are some pictures but not of the extraction but some helpful videos and general discussion... https://www.briskoda.net/forums/topic/528615-spare-parts-where-to-buy-from
Am I mad to think about buying a 24 year old Skoda Fabia?
Those failures are common failures. Moving parts on cars wear out so its expected at some point although I'm surprised at the very low mileage and several failures for the bushes and arms. It is very poor road conditions in the area of the car? Country lanes poorly maintained etc?
Actiondefence started following Am I mad to think about buying a 24 year old Skoda Fabia?
I've changed 2 glow plugs on my Octavia 2L TDi in the last year. I have a bike torque wrench which goes up to 20Nm. The removal torque is around 25Nm/30Nm depending on the manufacturer. Tightening torque was 12-15Nm which is basically nothing. Both glow plugs came out easily with just a little bit over 20Nm. I sprayed them with WD-40 the night before, drove it during the day and the replaced the glow plug a few hours after I came home. The electrical connector is easy to remove if you have the access to grip the plastic body lightly and pull up. In the Octavia forum there was a very helpful technician who said that, most problems removing the plugs occur when they have been changed by someone before who has overtightened them. From the factory they usually come out easily. He recommended not to overtighten when you refit them. There are some videos on YouTube that even say to only hand tighten them. I chose to tighten to the minimum and haven't had problems since. I used ceramic grease on mine, but I was surprised that, apart from the heating tip, the rest of the glow plug was pretty clean for 225k km and 12 years use. My advise, is don't worry too much, be gentle and slow applying pressure & if in doubt, stop. Spray some more and try again, leaving it to the next day if necessary. Gabbo
Gabbo started following 1.6 TDi Greenline glow plug replacement
Kodiaq steering wheel vibration
Hello guys, is the problem witaj vibrations solved? I havevthe same problem with my new skoda. Skoda warianty servicd said that it is normal. I couldnt find solution on polish forums. That the reason i’m here
Akodiaq started following Kodiaq steering wheel vibration
Brochure download
Good evening, I am trying to find the brochure for a 2025 VRS, but can’t find a UK one at all. I think there’s a Jan 25 and July 25 but I am not sure. Does anyone know where I could got it from please. Thanks
VW group recalls ~4M vehicles for steering bolt which can corrode - any Skoda news yet?
Just posted in the past day or so: https://www.autoevolution.com/news/skoda-issues-massive-recall-17-million-vehicles-feature-tiny-steering-bolt-that-can-snap-276674.html I searched for "48LS", which the article says is Skoda's tracking number for the recall, but I only find that in a small number of news articles. Anyone have an inside scoop on which Skoda (Octavia wagon) vehicles are included in this recall?
- Exhaust warning light
Evolution13 started following Exhaust warning light
Akodiaq joined the community
Jaguar, will it survive?
Type 01 https://www.jaguar.com/en-gb/index.html
Good evening I have a 2019 Skoda Superb. The exhaust warning light came on a week or so ago. I ran my OBD Eleven and I can clear the warning light. However it does keep coming on. Having had a similar issue with my previous Superb my partner suggested driving it at high revs for 15/20 minutes which we did. I cleared the light, but the next time I went out in the car it was back on. Any suggestions or advice will be gratefully received.
Tresco started following Exhaust warning light
Emission warning on. 240 mile m'way trip tomorrow?
Only just seen this. How did you get on?
Hopefully I dodged a bullet. My Octavia was registered in about week 9 of 2015, so would have been manufactured a bit earlier.
Rear washer and heated rear window
For the rear demister, check the loop of wiring between body and hatch for broken connections - for the washers, is there any sign of water ingress in the trunk?
Warrior193 started following EPC Light On During Drive Home From Purchase Of Car and Rear washer and heated rear window
seano94 joined the community
- EPC Light On During Drive Home From Purchase Of Car
Elroq spare wheel options
An 18" space saver wheel (145/85R18 4Jx18 ET28) from the Kodiaq MK1/MK2 might fit, but you would need to check for clearance. The outside diameter of a 145/85R18 tyre is about 5% smaller than the standard Elroq tyres, so that's another possible problem. The Elroq's traction control might need to be turned off (if that's possible) for the car to even move. Skoda did use a 205/55R16 spare wheel for the Superb MK3, and that is also about 5% smaller than the car's standard tyre sizes...so it has been done before. The load index of a 145/85R18 space saver tyre is 103(875kg), so it can support the weight of an Elroq. 145/85R18 4Jx18 ET28 5/112 57.1 space saver wheel (Kodiaq MK1/MK2) https://www.skoda-parts.com/spare-part/565601011k-spare-wheel-skoda-50288.html
Any tips and advice for my build
Hi all, Just putting this out on the forum to see what everyone thinks and what things I can do to make my build better. I am aiming to buy a 2003-2004 fabia VRs pd130 and even though I’m a truck mechanic. This is my first time ever doing something with a diesel engine to make it into a performance engine. I’m hoping to push my build to high 200s low 300s. Any feedback at all is greatly appreciated and I will keep you posted on the build status.
N_Don628 started following Any tips and advice for my build
N_Don628 joined the community
Which winter wheels?
All very good points. Totally agree.
I've just got my Jag back from its service and MOT everything is good, although the rear tyres are apparently quite worn But as is typical of a Jag dealership, the actual service is a bit patchy. I wonder if some of Jaguar's woes are because of this rather than their cars. I've had a couple of problems before with Jaguar and my car being in their hands and this time was not totally smooth either. The F Type is by far the most expensive car I've had and I did think I might get the same sort of excellent service I've had from BMW, but as usual....no. I dropped the car off and made a big point that I didn't want my car washed (the last time I did this they started to wash the car before I could stop them!!) anyhoo they put a big lable in the car saying not to touch it with a soggy sponge. No, my trouble this time was I asked them to let me know the moment the car was ready, as I was walking to the dealership and it was a couple of miles, which by the time I'd crossed a few roads probably means nearly 40 mins to get there. Sooo when it got to 17:00hrs I figured I'd better set off even though they hadn't bothered to ring me. On arrival, the service department seemed to be in the process of going home, at least I guessed this by their absence. Reception had certainly gone and it was thanks to the nice lady who makes tea, that she was able to find the service chap to sort my car out. Then came the bill, it was very big! Personally, if I worked in the service dept I'd have stayed all night if a customer was going to pay such a large invoice, but that's just me perhaps? I did query the bill however, when I was told that my AdBlue had been topped up, so they had to charge for it. I think you can guess what happened next..... 🤬 I realise in hindsight that it is possible, if unlikely, that it might not be obvious that I have a (very) petrol powered car, not a diesel
covsmiler joined the community
Kumula joined the community
Fabia Automatic
thank you
What SERVICE HISTORY do you have? What indication would you get that a vRS had a remap. CINCH never reset to Factory Settings. Has the VAQ Diff been serviced? Steering assist or brake assist might not be at Factory setting. This is what happens when buying used cars from Private sellers, Dealerships or car supermarkets. You do not know what you get until you can check everything out.
Hi, thanks for the response! Say it was the spark plugs, given the car failed straight after purchase, should I still be walking away, or are spark plugs a common issue? Regarding the E10, I actually filled it up form 1/4 empty to full with E10 myself on the way home. I’ve got no indication that it’s been remapped, so would assume it should run fine on E10. Could I get the garage to check the ECU for any previous tinkering when they take it away to code read it? Thanks 😊
The Arctic is really not like UK or Scottish cambered roads where they might be ploughed or gritted or not and thawing snow on ice is pretty much a common thing and what you might want Winter tyres for be them Snow or All season. During Covid the rather well known tyre tester took a Golf to The Ski Roads to do tyre tests. The Ski Road to Cairngorm Ski Centre was closed and The Lecht & Glenshee roads had no snow and if they had and were open they would have been plough and gritted. What i want to know is if the roads are open can i get up the roads and more important down safely. descending being the scary part as far as i am concerned. Driving roads that Posties, home deliveries and even the Police are on without Snow Tyres is hardly much of a trial.
A standard 19" Elroq front wheel could be used as a spare, ie. 235/55R19 101T 8Jx19 ET45 5/112 57.1 The wheel bolts for both the alloy and steel rims are the same. Alcar 9393 8Jx19 ET45 5/112 57.1 steel rim (14.0kg) (Elroq) https://www.mytyres.co.uk/rims/details?vehicleId=1313955427855111280&rimCode=ALCAR9393 Continental AllSeasonContact 2 235/55R19 101T (Euro label A B 70dB) https://www.camskill.co.uk/m142b0s12770p221942/Continental_Tyres_All_Season_Car_Continental_Conti_All_Season_Contact_2_235_55_R19_101T_TL_Fuel_Eff_%3A_A_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB Elroq wheels 235/55R19 8Jx19 ET45 front, 255/50R19 8Jx19 ET45 rear 235/50R20 8Jx20 ET45 front, 255/45R20 9Jx20 ET42 rear 235/45R21 8.5Jx21 ET40 front, 255/40R21 9Jx21 ET42 rear
Funny that, YouTube offered me his 2026 winter tyre review just last night. The review was cut short because of rising temperatures on his Arctic test track but it was still really interesting and I see the video link is available from your own link to his front page. Importantly, our Goodyear Ultragrip 3's were the winner 😘
Hi all! Very new to the family (less than 24hours!), and it might be a flying visit… Yesterday I picked up my new car from Cinch, a 2018 ŠKODA Octavia VRS Petrol Manual, 230ps. I was all very excited, having come from a 31yo Volvo 850, to experience ‘modern reliabilty’. On my drive home from collection however, the EPC light came on, accompanied by a system error for the start/stop function. I pulled over to do some googling, and considered that it might be a low battery health causing it, but my symptoms were also as follows: [No EPC light on] I accelerated hard in third, the engine got up to high RPM before jerking, and releasing power [EPC light comes on]. I would then be put into what I assume is a type of limp mode, where I couldn’t do any real acceleration at all. Turning the car on and off again reset the issue (ie; no light, and system check saying no errors with start/stop), but accelerate hard again and it all reoccurs Cinch are taking the car to be code read and repaired imminently, but have assured me that I can exercise my right to return the car free of charge. I did my due diligence prior to purchasing from cinch, and was aware that this could happen as a customer - I just didn’t think it would happen to me, fatal mistake ! So MY QUESTION… Am I an absolute fool for considering keeping this car after the EPC issue has been diagnosed and fixed? I got a lovely spec, and thoroughly enjoyed driving it (albeit, for 30 minutes…), and part of me doesn’t want to go through the stress of waiting again for another to come up for sale in the spec I want. But the sensible side of me is completely aghast that I’d even consider keeping a car that has literally broken down within hours of taking delivery. So my question is, please can I get some advice (the harsher the better) as to whether I should be 100% taking this back, or whether I should wait to see what they diagnose the EPC error as before making any decisions. Thanks all, from one disheartened, but otherwise impressed, recent ŠKODA owner!
