Past hour
Lane assist comes on almost every time and will not turn off
I have a VW UP 2023 that has lane assist. I do have a switch for lane assist that defaults to on at every start up. I managed to program the car for it to remember the last position the button was in at the next start up. So if left it off, it stayed off, until I wanted to turn it on again. I used OBDEleven. I don't know if there is an option for it to do it with your car. Thanks. AG Falco
AGFalco started following Lane assist comes on almost every time and will not turn off
Brake lights
Oh, OK, not a mk2 then. I wondered about the mismatch between car in profile versus subforum you posted in. Doesn't matter. In that case check cabin fuse number 2 first, layout image and table in attached file. Access to the brake light switch requires lower dash trim removal on mk1, I think, which is a bit of a faff. Mk1 Fabia Cabin Fuses.pdf
Heated mirrors not working, both sides
Thanks for that, further food for thought! Yes, they're labelled 12V 27W, so should draw 2.25A and R should be 5.33 if the elements are ok.
Brake lights
Hello Breezy_Pete, Thank you for your quick response. Fabia is 2004, estate version. Retired to Ireland ( profile just updated!). Will find some more info on switch on brake pedal. Had a quick look at the bellows wiring - all seemed fine, but will investigate more thoroughly. ( Not required for the MOT I believe). Kind regards, Richard
Hello to all from Austria!
Hello everyone , in 2019, I bought a brand-new Skoda Rapid Spaceback. After nine years, it’s time for a change. 😢 My dear fellow is now making way for a new 1 1/2 years old Skoda Scala. 😁 I am currently having an issue with the Rapid’s infotainment system, which I would like to get fixed before selling the car.
Mike-74 started following Hello to all from Austria!
Ceratec diesel additive to Octavia mk3 2.0 tdi
I don't have any experience of diesel addtives. IMO, as has been mentioned in this thread the correct VAG has been more than adequate for all all of my Diesel Skodas thus far (I've since switched to Petrol).... I guess the bigger questions are how many miles has your vehicle done? and how frequent/consistent has the servicing been up until the point when you purchased? I'm sure that you chose a great example, but if for whatever reason the oil servicing has been patchy then I;m not sure that an aditive wil make up for that. Each to their own though - I hope it works for you.
Blower Motor Not Working
The speed control is what differs. Manual 4-speed cars use a resistor pack, Climatronic an electronic regulator, so match any replacement to your system. Before doing the access work, check the blower fuse and 12V at the motor plug. Dead on all speeds is usually supply or a seized motor.
SteadyDiesel started following Blower Motor Not Working
Today
- Brake lights
New Member
Nearly 10 years on from my first post, I have today parted with my Roomster. Bought in January 2017, I traded it in today for a new Karoq 1.5Tsi Design Edition. 96,688 miles, mostly trouble free. Outlasted three other cars; a Volvo V70, a Discovery Sport and the Kodiaq mentioned in an earlier post. For the last 2 years it had been the everyday car. Thrashed mercilessly between Oxfordshire and Kent regularly and still easily turned in 60mpg. No idea what the future holds for GJ57 HLH, but if someone buys it through the auctions they will get a good little car. I was very sad to see it go and in many ways it has been the best car I have ever owned. Let’s see how I get on with the Karoq. We do still have a Roomster in the family though as my daughter runs a 1.2Tdi Greenline.
GordonHotson started following New Member
MikeTheThinker started following Brake lights
Fabia 2024 SE comfort mpi fault
On 8 October on @Sklinda's original enquiry about her car's behaviour, you asked her whether the car's motor was a TSI or MPI type. You asked again on 13 October and her reply was "It's an MPI". (And. of course, she said "mpi" in this topic's title.) I can't see any persuasive reason to think that @Sklinda's reply might be incorrect. But, if she has any doubts herself and has the vehicle's EC Certificate of Conformity, her car's motor's maximum net power will be shown at 27.1 on the Certificate's 2nd page and, if it has the MPI motor, the entry will read 59.00 at 6300 As the TSI motor has a turbocharger, there are visual differences between that motor and the MPI one - but I can't find any online images of the engine compartment of a Fabia Mk4 that has the MPI motor that could be used for easy identification purposes. Using' logic,' if @Sklinda's Fabia Mk4 has an a DSG automatic transmission or a 6-speed manual gearbox, then it must have a TSI motor. But, if it has a 5-speed manual gearbox, then it could have either a MPI or a TSI motor.
- Brake lights
D1ckieBoy started following Brake lights
D1ckieBoy started following Skoda Fabia Mk2 (2007-2014)
- Cairus's Leon FR
Rear springs...replace?
The upper and lower rear spring seats are the same for lowered ride height, standard ride height, and increased ride height. Rear stop buffers 3C0511359B is the rear 118mm buffer for lowered ride height 3C0511359 is the rear 133mm buffer for standard ride height and increased ride height LLLPARTS has a superb mk2 parts diagram, but their security system can make it difficult to enter. If so, then access the website using "https://www.lllparts.co.uk". Then you may have to press the refresh button. Then enter "https://www.lllparts.co.uk/catalogs". It should be plain sailing from there. The lowered ride height front springs are about 10% to 15% stiffer than the standard ride height front springs, so it might be better to go up two in the hierarchy with the standard ride height rear springs to 3C0511115AF. Sachs 994 364 matches 3C0511115AF standard ride height rear springs. Bear in mind that some owners find the standard ride height rear springs on the Superb MK2 to be on the soft side, especially if a lot of weight is carried in the back.
Cairus's Leon FR
Will find some time and we need to talk 😊
Apple CarPlay adapter recommendations
https://a.aliexpress.com/_EvvwEfk Works like a charm!!!
ile7 started following Apple CarPlay adapter recommendations
Takata Airbag Recalls?
Just got a warning letter for a Seat Altea XL 1.9tdi. Its been sorned for four years and is 2008 plate!! I am supposed to contact Seat for repair. Thats a 18 years old car. Will need to fix brakes,wheel bearing,EML and a list as long as your arm for an MOT so I can take it in to get airbag replaced? By the time I did the above it would cost me more than the cars worth. Only reason I kept it was its the same engine as my old Skoda plus other compatible parts and thought when I have time might fix it. Wonder how long I have got to get a free airbag. At 18 years old I doubt they would go off anyway. Alasdair
Acapop started following Skoda Octavia Mk4 (2020 > )
Acapop joined the community
I expect this is a case of 'the newer the car the more intrusive and unavoidable the safety features get'. You won't like the solution of changing it for an older car, I suppose.
I have 75 reg 1.0 Monte Carlo auto. Almost every time I drive the car the "Lane assist" feature switches on at low speed and cannot be turned off. I thought the lane assist wasn't supposed to kick in until you were driving at 30+ mph and that you could disable this feature if you didn't want it. Mine cannot be switched off and comes on at very low speed. Has anyone else experienced this problem and is there a solution?
I got the same for SWMBO’s CitiGo.
SteveTheElder started following Takata Airbag Recalls?
Elivum joined the community
Bonnet support clip come away
I think that’s the issue, just looked at both parts and the base is very slightly different, I think Skoda main dealer gave me the wrong part, car is a 2015 model, the part I got looks like 2016 onwards model. I’ll have to go back to Skoda.
Bet
Scuttles are clear, it's been suggested that it could be linked to a damaged windscreen wash pipe problem
The blower isn't working on my wife's 2012 Roomster but as its a Fabia in disguise I thought I'd post here. I'm resigned to a bit of work to get access but need to know if there is a difference between the blower on cars with the Climatronic system and those with the basic 4 position rotary switch for blower speed. Thanks for any advice.
Thanks again for your help. I've found a very good deal on two SACHS 994 337 standard-height rear springs (1K0511115DE) and two SACHS 311 346 rear shock absorbers (3C0513049CP), costing £140 altogether. I'm leaning towards this setup now. Do you know whether the GreenLine and standard-height rear suspension use the same upper and lower spring seats, bump stops and shock absorber mounts? Are there any other components I would need to change when converting the rear to standard height whilst retaining the lowered front suspension for the time being?
Timsskoda joined the community
Advise on wheels
Both the Octavia MK2 Scout and Octavia MK3 Scout use oversize tyres, eg. 225/50R17 instead of 225/45R17. So if you use 225/45R17 that the non-Scout versions use, they will be undersize, ie. have an outside diameter that is too small...as shown in the chart below. Outside diameter of tyre 225/45R17 634.3mm (3.4% smaller outside diameter compared to 225/50R17) 225/50R17 656.8mm
Bixenon Headlights auto-adjustment problem
I don’t want to invest the time right now to spend hours searching for and comparing documents—not when the vehicle isn’t right in front of me, or at least virtually connected to my laptop. For AFS to work, the assistant must be enabled in the MIB under "Vehicle Setup > Lighting," and the light switch must be set to "Auto."
