  2. It was only a very short time — just a few seconds. Between step 2 and 3, I turned the ignition off, opened and closed the driver's door, and then immediately turned the ignition back on to run the scan. I will definitely try your suggestion of leaving a full 60 seconds (or more) with the ignition off before turning it back on... Yesterday, I replace the N522 valve once again, just to 100% rule out the possibility that the first new valve installed by the dealership was defective. When I replaced the valve, the engine was fully warm. After installing the new valve and clearing the code, I ran multiple tests and the fault code did not return. However, after letting the car sit for 3 hours to cool down, I turned the ignition back on and the P25AB00 code immediately returned. The issue seames to never occurs when the engine/oil is warm. It only triggers when the system undergoes a true "cold boot" with cold engine/oil parameters. During my lunch break, once the engine has completely cooled down again, I will repeat the full test sequence on a cold engine, including leaving 60+ second gaps between ignition cycles as suggested earlier. I will post the cold-start results as soon as I complete the tests!
  3. I was thinking the same, there's still plenty of them in the US, loads of BESSs over there. So I guess the media have largely given up and waiting for something significant to happen?
  4. How is it going with EV,s on fire in the UK as the numbers on the road or in storage have been growing. There seems to be very little media coverage on this recently. Is it just less of a story or less scaremongering from the usual suspects in the printed press?
  5. Insurance quotes are so different from the various providers. Those advertising Special EV insurance like Admiral can be a ridiculous price. As to Comparison sites. Compare the market, showed me better prices than either Confused.con or Supermarket. Com. This year Ageas has provided me good over at a great price.
  6. Today
  7. As all the owners manuals say for all VW group engines. ' may use more oil in the first 5,000 km'. This can be true with some engines, especially the 1.5 tsi,s.
  8. Checked the level on the digital readout on the screen yes, the car tells you when it needs some, just comparing this car to others ive had over the years, none of which have needed oil between services until the miles have got towards 100,000. As it will be being serviced every 18 weeks or so its regularly being changed anyway.
  9. Mirrko joined the community
  10. FYI, there is a for sale section 😂
  11. Yesterday
  12. I found both liftgate grommets broken on my Octavia and suspect them of causing small corrosion on the tailgate and a previous issue with the brake light (water got inside). I want to replace the grommets and assume I first need to remove the interior trim from the tailgate. Since I have zero experience with such work, I would appreciate some advice, or perhaps someone can share official instructions. Thanks in advance.
  13. @Gaz it is time to celebrate 🎉; I actually remembered, and a bit of planning… Up the A34, but I took the B430 just short of the M40 so I had more chance of being able to stop at the right time. About 100 yds before a lay-by the car clicked over to… 😀
  14. Couple of shots from today. Revisited a railway bridge previously snapped and went up to the firth of fourth.
  15. @Rory when stopped in traffic queues or traffic lights a light tap on the throttle released the auto hold. Then I read a post, either in this forum or the Facebook Karoq Owners group, where the poster would manually apply the parking brake having come to a halt at traffic lights with autohold. They did this so rear brake lights were then off. The action to pull away is the same simply press the throttle but I think the parking brake releases slightly quicker and smoother than the auto hold release. Returning to your question about releasing autohold I find the lightest of taps is sufficient to set the car rolling. Maybe it differs slightly between 1.5 and 2.0 TSI engines.
  16. https://www.ebay.co.uk/itm/137640553115
  17. That's exactly what I do.....but, I have auto-hold turned off. Surely if you have it on, the car won't release its brakes and start to move until you touch the accelerator? I turn it off because my previous TC auto didn't have it so got used to driving without it, and in the Tiguan we had before the Karoq, it released the auto brakes with a bit of "thunk" - it was far nicer to let the car creep before getting on the gas.
  18. Yeah, we don't really use them much in the UK. They're far more important on the continent. Right now, the paper CoC (they're watermarked), is the definitive legal document, but they're going digital. What you'll get, will be a PDF of the real thing. The data will all be correct, and useful, but it won't be a legal document. That said, you shouldn't ever need it in the UK. This is what Side 1 of ours looks like. There's lots of nerdy goodness in them! You can see the date on which your car was built, for example, so you know how long it was sat in a field before it was registered. Also which version of Euro 6 emissions it was, and exactly what you can tow with it.
  19. Well I've had a good look at two different versions of the 85 model. One was an SE L, the other was 85 Edition, neither were outstanding, but I had a look inside a Sportline one and that looked better, now will try getting Lookers to remove the MDP & GardX (£1100) from the quotes they've sent me. I can reallocate that to pay for the EV charger, getting that done could be fun my house being a Grade II* listed building! I've been offered the 2,9% PCP with a £3k deposit as a returning customer bonus or 0% loan, the PCP is easier & cheaper to do and I can repay it easily. Or should I do a 100% cash deal, where I'd need to find £20000 (which is more or less what my RS cost me when I did that deal) + another £2k. Just need to get some insurance quotes together to see how much it'll cost me.
  20. @SkodaLada @CnrNGCJ i am facing the same issue. Did you manage to solve the problem? I changed the battery already, even a new ECU was put on the car and the same issue as you described is happening. Thank you
  21. Heber started following CAN-BUS glitchiness
  22. whoa getting my combi valve out was like fighting with a gorilla; Bowders didn't mention the bunch of hardlines and other stuff screwed into the back of the combi valve plate. Maybe his was different but it was tough and I expect I've gouged some bits I shouldn't have. Tomorrow I'll put the plate on, and the coolant assembly; then get chopping out the hoses in the N249 area. I made progress today; if the OCC install is this tricky... ...I'll die...
  23. I've read that primer over rust converted rust is a bad idea, unstable surface , but probably better than not doing anything. Hycote diamond silver is a good match but the power red 50b for my astra was nota match. I went to paint shop. The base primer is coloured and gives depth to colour. I've got epoxy primer and going to seal it tomorrow. Should I rub down rest of sill to metal, I'm thinking not because the rust I found is creeping from direction of wheels towards centre of sill. I've found not rusted metal a little further in. Probably best not to disturb
  24. It is regularly washed. I've had rear bumper off 2 years ago to rust proof hidden areas and wheel arches have been off numerous times. No rust. This rust was hidden under the factory paint and stone chip protection. As the sill protection is bubbly in appearance there was no tell tale signs. Discovered entirely accidentally when prepping sill. I bought a couple of Bolt Hamber products recently - Underbody and the clear stuff. 80 hydrate for chassis voids.
  25. What I also noticed, but didn't give a second thought about. When I inspected my pullies, the engine plastic top cover was loose, so I clipped it back down into place. Obviously the main dealer hadn't attached it down properly when it was previously serviced by them, prior to me buying the car. Since then, the noise has not occurred, again. My fingers are crossed.
  26. Hopefully someone has in depth knowledge of the CRLB engine. The problem is oil leaking around the injector seals. Is being pushed through the seals under pressure and onto the top of the camera cover. It seems to me the crankcase is pressuring and forcing oil past the seals in the cam cover. The breather system is rather baffling, with what looks like a breather built into the cam cover. We are asking if any internal breathers can be cleaned or does it require a replacement camera cover. This might sound a bit amateur, but my mechanic is very experienced and he suggested there could be someone here with a better understanding of the system than us. Thanking you all on advance for your time.
  27. There were differences in 2013 as in likely no e-brake or autohold and just a Parking Brake & 'Hill hold assist' or no Hillhold assist. 2 seconds of being held on a slope if the brake pedal is pressed hard enough. The good thing is, what ever you have you can practise with it. What others do is their thing. A Light touch is 'simply clever' but delays need not to happen.
  28. all done, not the sensor just the o ring/ seal
  29. @Ianhar Had you never checked the oil in 11,500 mile? Did you not check it from collecting it to see where the put the car out from the PDI as far as oil level? Many have had to top up long before the miles you have done. Maybe if you had earlier it would not have used so much oil.
  30. Hi all My Superb often makes a loud electrical buzzing noise after driving. I switch it off and start walking away, only for it to start buzzing. I go back to the car and switch it on and back off, and this usually rectifies it straight away. It's definitely not the usual cooling fan noise. This is something else altogether. A few days back I thought I'd risk it and leave it for a few minutes. This caused an awful burning small and much panic. Couldn't find any damage though. I've uploaded a short video of the sound. PXL_20260819_183430602.TS~2.mp4
