  2. BCM dont Support? BCM Change need odis online, because BCM have CP
  3. Jamiek joined the community
  4. Watch this video from 13min 10 seconds onwards (speed limit response) - although the whole video is full of useful information.
  5. I have a Mk3 Fabia, picture of my fuseboard attached. The cigarette Lighter output is on fuse 44 - it's that Blue 15 amp one on the lower row (between the yellow and red ones). The problem is that whilst there is UNswitched voltage on the top pins of all the top fuses, and bottom pins of all the bottom fuses, the only SWITCHED volts are on the bottom pins of those smaller fuses in the middle on the right.... which are a max of only 10 amps. (interestingly: all unused fuse positions ONLY had the 'incoming power' 'fuse pin' fitted, leaving the upper blade of any potential fuse dangling into nothingness - I guess it saves £££!) In the end, having considered maybe using a relay, I took the decision that 10 amps (or actually 7.5 amps, as that was the fuse I had) was enough for the camera and phone charger. So, thanks for giving us the original idea!
  6. Today
  7. AI response "Hi John, Unfortunately, Škoda doesn't let you set the predictive ACC to only drop speed while ignoring higher limits—it’s an all-or-nothing feature. However, if you want ACC to act like a strict ceiling (for example, holding 60 mph when towing a trailer, slowing down for traffic ahead, and never creeping above 60 mph even when you pass a 70 mph sign), you just need to turn off the automatic sign reading in the infotainment menu: Go to Menu / Car icon > Assist Systems > Adaptive Cruise Control (ACC) Untick Reaction to permissible speed (might be worded slightly differently depending on your software version, such as "Speed limit response"). Once that's unticked, the car will ignore all speed limit signs—both higher and lower—and simply treat whatever speed you set on the stalk as your maximum ceiling, while still using the radar to slow down and speed back up with traffic ahead. (You can also untick Reaction to road layout in the same menu if you don't want it slowing down for roundabouts and bends). If you do want to keep the automatic slowing-down feature switched on for lower limits, the only workaround is to give the ACC stalk a quick tap down (SET / -) the second it sees a higher sign and starts accelerating—that will immediately cancel the speed increase and hold your current speed." I have just been offered the option of activating ACC in my skoda, everything for it to work is fitted but the software has to be bought, for a black friday £180 ish i think it was a third off. But i prefer to drive my car myself i use std cruise control and flick the speed up and down as needed.
  8. Stonekeeper started following ACC control
  9. phemala joined the community
  10. ffowahueusr joined the community
  11. Posted now on YouTube is. Part 7 of the Escargot -RV camper car transporter conversion.
  12. Have you looked at the throttle body area, in case it's running down from up there? Do you mean the one way valve that connects via a hose to the airbox area? If it's not broken/detached I'd say there's no point in changing that. The oil separator is not a nice job. I think I already pointed you to my thread where I describe it, but in a nutshell it needs to be done from below, and the offside driveshaft needs to be removed first for access. Best done on a lift, indoors, after ruling out all other sources of the leakage. Not sure what a garage would quote, ask one.
  13. If the wheels are spinning at moderate acceleration it could be as said tyres or greasy road conditions especially at roundabouts/slip lanes. If no traction control warning shows it could be that in certain driving modes its disabled but worth getting it scanned to see if anything has failed and caused it to be disabled. On all my skodas the traction warning light comes on even if its a minor wheel spin. There all manual so not sure re DSG. Alasdair
  14. Hi All I use Acc a lot on my 24 plate Superb, can anybody tell me if there is a way of stopping the system speeding up when it sees a new (higher) speed limit sign? Its great lowering the speed, but not when increasing. Any thoughts? thanks in advance, John
  15. johndavid158 started following ACC control
  16. Hi all. I am about to tackle this subject again now that I am well enough. I have an 'oil leak' from the rear of the block midwayish but sump plug end. This appears to come from the oil seperator / diverter and one way valve area but as with a lot of leaks difficult to pin down. I am going to change the one way valve myself and would like to do the diverter myself too. Has anyone on here either done this on their car or if not has had it done by a mechanic and if so how much. Any tips/info on doing either job will be very welcome.Pic shows the diverter I am talking about. Thanks in advance. Graham
  17. Just wanted to share more widely something which @Cedwing found and posted on this thread: you can now download PDF versions of owners manuals for recent Skodas. This used to be true for older Skodas, but for more recent ones they started using HTML manuals which you couldn't download as PDFs... until recently. Just go to https://www.skoda.co.uk/apps/manuals , pick the car model/ production period etc that you want, then use the download link to the right of where the text starts: Or you can apparently use the My Skoda app (not tried this myself)
  18. There's an Audi service bulletin for this exact code and symptom number, B107B with 13959168. It says the newer ultrasonic sensors flag dirt, ice or other outside interference with that code. If it only comes and goes, it says to leave it, and that changing the module or sensors without a clear finding won't fix it. If it's there all the time, like yours, it points at one of the sensors, its mounting or the wiring. The checks it lists are dirt, ice, stickers or anything stuck on the bumper, the number plate being fitted properly, any knock damage to the bumper or underside, stone chips on the sensor faces, and whether the sensors and the trim around them are seated properly. If all of that looks fine, look at the measured values in the parking aid module. There's a settling time value for each rear sender. Watch them while someone walks up to the back of the car. The good ones should change as they get closer, and one that stays stuck or behaves differently from the rest is your suspect. Unplugging each one only proves the wiring to it, not that the sensor itself is reading properly.
  19. Yes - the instruction manual probably trumps my 'pre-2020' memories of fitting it. Though I remember spraying it up in matt black IN my flat at the time, within a makeshift 'paint booth' I setup in the hallway using hanging plastic sheeting... whilst my other half was away for a girls' weekend - and managing to get away with it, minus the lingering (but delicious) smell of solvents 😅. It was initially a bit fiddly to fit, but been fine ever since. Even the DIY paint job is still mint, probs due to many layers of primer, black, and clearcoat in my frenzied painting weekend... 😉. Yes, give us a shout if any Qs.
  20. lagerzok joined the community
  21. Plenty have made the same comments over the years on this forum as the op but usually in the Karoq section. And the questions @Warrior193 asked are the common ones to ask.
  22. Jonboy984 changed their profile photo
  23. I am still missing the "headlight range adjustment" adaptation in control unit 09, the BCM.
  24. Hi, My wife and I have experienced similar issues with driver profiles and personalised settings on our Elroq RS MY2027 running software 6.0.1. As many owners across Europe are reporting various software issues, I've launched an international petition asking Škoda to provide timely fixes, a reliable update schedule and better customer communication. There is also a separate owner survey to document the issues statistically. Petition: https://www.petitions.com/koda_elroq_my27_owners_for_reliable_software Owner survey: https://forms.cloud.microsoft/r/x6T3xR3yJb The survey results will be submitted to Škoda together with the petition. Please feel free to participate and share the links with other MY2027 Elroq owners. Thank you! Erik
  25. Loupblanc joined the community
  26. Due to some reduced power issues I am having, my garage, says they have done a smoke test and there is a leak in the metal turbo intake pipe. The garage says it's not a standard pipe but I disagree. I've got the 2007, vRS SE, 1.9PD TDi BLT engine fitted with a GTB2260 turbo. I fitted the turbo and FMIC some 10 years ago and on the inlet, the only additional part I got was an intake pipe coupler, for the larger diameter inlet on the turbo. Does anyone have a part number for the standard/OEM vRS turbo inlet pipe. (Like the one in the picture). Any help appreciated.
  27. Don't get that on my 1.5DSG. It is a powerful FWD though so if you are expecting to simply stamp on the throttle you will get some wheelspin, just like in any FWD car.
  28. @TerryGP When you say yours cannot be switched off how are you trying to do so? Should be able to tap the button on the steering wheel to bring up the various options and untick the Lane Assist option. Can still do that on our Karoq bought new in March.
  29. Yesterday
  30. I don't think you need the app - I just went (on my laptop) to: https://www.skoda.co.uk/apps/manuals ...and picked a Skoda model, and the PDF download link is there too.
  31. Your ABS Wheel speed sensors could be dirty and or broken. Your tires made of harder rubber depending on make and type. Tyres over inflated for the weight of the car. Driving skills? And I don't mean this rudely. If you know the car is powerful enough to spin off the line. Learn to get off the line and immediately short shift to second. Or get accustomed to pulling away cautiously. Does the car do it in the dry, or the wet? Do you have the habit of stamping on the throttle. The car can't change what it does. But the driver can adapt to make sure the car behaves. Its all about experience.
  32. Yes, I have a rear camera and it is clean and working normally.
  33. Graemed15 joined the community
  34. Hello, this is my first post :) I write question about pre-facelift fabia. Is it possible to fit original monte carlo parts to stock fabia? I saw that diffuser fit, but I can't find any information about rest of parts.
