  2. What follows is the result of a AI Overview based on a GOOGLE image-search using the image in this topic's original enquiry. The Volkswagen T-Roc Forum and Skoda Kamiq Forum references come from these links https://www.trocforums.co.uk/threads/number-indicator-at-top-of-infotainment-screen.3387/?utm_source=google&utm_medium=organic https://www.kamiqforums.co.uk/viewtopic.php?t=149 (As my religion prohibits me from using a smartphone in a car, I've no idea if the above information is correct.)
  3. I'd love to know what that means. I have my doubts that they'll even have opened it. Who checked the chain timing and how? There are two aspects to investigate; crank to cam, and cam to cam. Cam to cam can be readily checked DIY from above, crank to cam is a bit trickier.
  4. Our Karoq 1.5l petrol 2018 60000 miles went for a service this week. The report said "Vacuum hose off inlet manifold has damage to connector and will not clip into place. Advise this is replaced". Car seemed to drive as per normal with this 'failed' part after service The part has now been replaced - separate visit - part details off the bag are "5Q0 612 041 BM Brake booster vacuum hose with a non-return (check and pressure sensor". So I am wondering how often this part fails and requires replacement? Perhaps this connection tab suffered from plastic ageing? Does this part require disconnection as part of a normal service which included the spark plugs so the plastic top engine cover has to come off, etc.? Photos below/attached: old part on the drive which shows is wiggly shape - yellow arrow indicating failed connector offside of engine bay with hose identified in red nearside of engine bay with hose identified in red. Yellow arrow indicates failed connector failed connector, shown with red line - the 'push' tab seems to have broken and is missing non failed connector with green showing the bit of the tab that has come off
  5. That's the bit i'm after - the 4 digit code for the key blade - if it's stored somewhere I must be able to request it right?
  6. Good luck Dave, hope you'll not disappear completely from here. 🙂
  7. After 27 years of Audi/Skoda ownership I've deserted to Toyota and a new RAV4 GR Sport.
  8. Latest info looks like this one "1.0l petrol engine with start/stop system , DKLD,DKRC,(7L6) From November 2019" Only difference is in cars with adaptive cruise control where the green/yellow wire goes somewhere else: * For models with no adaptive cruise control (ACC) *2 For models with adaptive cruise control (ACC) Not totally clear to me whether that extra connection is instead of the one to the BCM or as well as; the former I think. J533 defined as - J533 Data bus diagnostic interface. Does your car have ACC?
  9. Put octavia mk1 breaking into ebay and came up with a few. Not sure on 9102 colour but theres a 1.8 vrs on there with what looks like good passenger wing in silver https://www.ebay.co.uk/itm/116190808688?_skw=skoda+octavia+mk1+breaking&itmmeta=01M7ZE485CMYGCK3NGT778AVY9&hash=item1b0d830a70:g:~yMAAOSwLppmTc24&itmprp=enc%3AAQALAAABACHNgUiiE%2FjQhlDTaMiAde%2FME5jbBWz7MU%2BzjpBQSDwKFqcEKz7KvJMpF4w9SKFTcEy4enazCzUrEgrcOScYP9nyuI9O2hv3O57u%2FF5%2BswkaCzE2DbYLDfxt5c9LZ6GZUU%2Bciz2Ax88hX430uJ9u24F6zSAFq8bkuqsFP9vi7GspmWU7w7xiRQnuiEf0SJv%2BrEzSdv7QQgxZqm%2BTZ0RFSzLOHq6ntsIXDR9GDVPfa3fUqKLcGHRdBtY8ZK0OLrdyI1R%2FdYz1mszXTqQnKh6d5Y6s0zq7qXTisizMqAuCSwBPku%2FKVP4Vk8I5g33mzkeqGhCgcTmQ3TEh4j5hSJJBiv4%3D%7Ctkp%3ABk9SR4SDke6_aA A few others but nothing in silver. Alasdair
  10. Today
  11. Which engine? Htp 6 valve, 12 valve or something else?
  12. Hi, thanks! Do you know if updating to SW 0742 fixes the Android Auto connection issues with the Samsung S23+? Also, can you confirm that 0741/0742 is compatible with HW 033?
  13. this is a known issue on kamiq/scala/Fabia 4 with the clutch master cylinder make sure you get the latest part number wich is 2Q0721405C . if you go with OEM, you also need the plastic pin 6R0721152 and the seal 6R0721410 If you choose the SACHS M6284600775 , the part has already all the hardware needed
  14. Where can I find my latest software info update on my 1. 5 tsi infotainment system and what should it be. I have done a search but can't find it. Cheers Andy
  15. they will say that if the clutch pack needs adjusting, it is because of a drive fault. The clutch pack pressure plates have a mechanism to self -adjust to wear and keeping the clutch cylinder at a constant travel. That mechanism can sometimes get shocks and get out of sync.... Many people say that the gearbox is automatic , but the reality is that DQ200 is pretty much a manual gearbox with electronic control and does not handle very well some driving conditions...
  16. why don't you take the safe route? and go with SW 0741+0742
  17. Just out with the dog. Will have another look at circuits in a bit, I only looked at earliest version from 2014.
  18. Car is my2020 Nov Battery is 2 weeks old
  19. My 2014 Skoda Fabia will sometimes just crank and not start. If I stop and try again, it usually fires up straight away on the second attempt. It's showing fault code P034100 - Camshaft Position Sensor Circuit Range/Performance, but the timing chain is fine. I've replaced both the camshaft and crankshaft position sensors multiple times, yet the fault keeps returning. The car has also just come back from an auto electrician, who checked all the wiring and confirmed everything is ok and they also they repaired the ecu. Given that the timing chain, sensors, wiring, and ECU have all been checked or replaced, does anyone have any ideas what could be causing the intermittent no-start issue where it only cranks on the first attempt but starts immediately on the second?
  20. Nothing in stock there at the moment but good place to know. Thanks.
  21. Came accross this breaker a while back. They may have something. https://www.trents.co.uk/?gad_source=1&gad_campaignid=23663397992&gbraid=0AAAAADtNLyIBdjzSxEPPw_nyaFnMk4zS_&gclid=CjwKCAiAn4XYBhA-EiwA8176FXmpIF9eo9ch8sgMYKxKD_Cu4lzjo2wrPGh_ejXJBhGGbGl270oeBRoCLdEQAvD_BwE#/ Few on ebay but Europe mainly. Alasdair
  22. Hi everyone, I have a Škoda Octavia 3 1.6 TDI with MIB2 Standard (Bolero, SD card update) and I would like to update the infotainment to the latest official firmware, MST2_EU_SK_ZR_P0369T. Unfortunately mibsolution.one is down and I can't find the package anywhere. My unit details: Part number: 5Q0035840B Hardware: H30 Software train: MST2_EU_SK_ZR_P0363T MU version: 0363 Software version: H28.28.185_STD2Plus_EU Media codec: 3141.0.0.1 I'm looking for the original firmware package (not a patch), to install via SD card with the standard update procedure. Could someone please share a download link, or send it by PM? I'd also appreciate any advice on whether going from 0363 to 0369 directly is fine on this hardware. Thanks a lot in advance!
  23. SimoneG joined the community
  24. I kept editing my above post as my thoughts developed, may be worth another look.
  25. Thanks both Mmm so i have a couple of possibilities in bcm or led. I don’t have an obd device to do a lamp output test. Is there another way to test if the led actually works?
  26. Possibly, yes.; but I'd imagine that the BCM is the LIN master device, and the alternator and battery monitor control unit both slave devices. Where the voltage is measured to trigger the warning light I don't know. In 'dumb' alternators it is definitely within the BCM, but it could be within the alternator with smart charging capabilities, or most logically perhaps, within the battery monitor control unit. What year is the car and how old is the current battery? LEDs used as indicators (very low power), as opposed to illuminators (higher power), very rarely fail.
  27. Funnily enough, an advertisement for a 7kw diesel generator for about A$1100 about a week before the disaster caught my eye and thinking it could be a useful sort of thing to have around. As it is I have a small 2.4kw gen for the freezer if power goes down for any length of time. Only used it twice in 5 years but it only cost $200.
