Past hour
Bet
Scuttles are clear, it's been suggested that it could be linked to a damaged windscreen wash pipe problem
Merlindriver started following Blower Motor Not Working
The blower isn't working on my wife's 2012 Roomster but as its a Fabia in disguise I thought I'd post here. I'm resigned to a bit of work to get access but need to know if there is a difference between the blower on cars with the Climatronic system and those with the basic 4 position rotary switch for blower speed. Thanks for any advice.
Rear springs...replace?
Thanks again for your help. I've found a very good deal on two SACHS 994 337 standard-height rear springs (1K0511115DE) and two SACHS 311 346 rear shock absorbers (3C0513049CP), costing £140 altogether. I'm leaning towards this setup now. Do you know whether the GreenLine and standard-height rear suspension use the same upper and lower spring seats, bump stops and shock absorber mounts? Are there any other components I would need to change when converting the rear to standard height whilst retaining the lowered front suspension for the time being?
Today
Timsskoda joined the community
Advise on wheels
Both the Octavia MK2 Scout and Octavia MK3 Scout use oversize tyres, eg. 225/50R17 instead of 225/45R17. So if you use 225/45R17 that the non-Scout versions use, they will be undersize, ie. have an outside diameter that is too small...as shown in the chart below. Outside diameter of tyre 225/45R17 634.3mm (3.4% smaller outside diameter compared to 225/50R17) 225/50R17 656.8mm
Carlston started following Advise on wheels
Bixenon Headlights auto-adjustment problem
I don’t want to invest the time right now to spend hours searching for and comparing documents—not when the vehicle isn’t right in front of me, or at least virtually connected to my laptop. For AFS to work, the assistant must be enabled in the MIB under "Vehicle Setup > Lighting," and the light switch must be set to "Auto."
Wheel spin on moderate throttle
☹️ Hi. My 1.5 dsg is prone to wheel spin when trying to accelerate a LITTLE briskly at low speeds. Eg when joining a roundabout from stationary or pulling out from a junction. Never encountered this in over 40 years’ driving. Skid control doesn’t even engage. Any thoughts. Still under warranty Cheers
JoxSkoda started following Wheel spin on moderate throttle
Dixy1266 started following Pluscenter radio
Pluscenter radio
Hello I have purchased a plus centre radio center and I have got to fit it, I’ve disconnected the old screen and found it has a multimedia unit behind. Is there any tips on how to remove the plug so I can plug in the new screen. Thanks
Dixy1266 joined the community
- How to replace "CU convenience" (ref : J519) on a SUPERB II
- Bixenon Headlights auto-adjustment problem
Hello Guys, @Cairus could you take a look at my data??? I am loosing my hope... Today my 4b and 09 controlers were updated via ODIS to the latest version of software and still nothing..... One interesting situation: at LONG CODING "DYNAMIC AFS LIGHTS" are ENABLED, at LIVE DATA :DYNAMIS AFS LIGHTS" are OFF As i mentioned, i am loosing my hope....
Rieger Rear Diffuser?
Thankfully the instruction manual that came with it is more detailed than the one I was sent a few months ago. I was just after some clarification regarding the spacers, but I think my questions have been answered by the manual. I’ll drop you a message if I get stuck - thank you! Should go well with my black spoiler.
Advise on wheels
Yes. 5x112 standard was adopted in the early 00s
OccyVRS started following Advise on wheels
JoxSkoda joined the community
Mine focused primarily on fixing things that were broken or worn due to age and mileage. And then from reading forum posts migrated into what was available cheap from AliExpress. And then morphed into more major projects. All doable in a weekend. Nothing too long term as it is my daily. Certain persons are bad influence on my impulsive nature…. @JR RS @Cairus @Kosin 👀
I agree when it deals with ones 'daily car'. It can be a different goal, when it's about a car for pleasure (not necessarily a youngtimer or a classic car).
Software Update available for Bolero?
It worked great. Engine on. Errors 15 and 35 while installing the last file but it did complete the installation after a couple of retries. Thanks a lot for the help!!
Perplexing braking problem
Many years ago on two different (neither of them VAG) cars I had the following braking issues. Firstly warped discs. When the new discs were fitted I was advised to release the footbrake after braking to a stop - as keeping the pads pressed against the disc was not allowing the discs to cool causing the warp. I live in a city with 70 mph dual carriageways with many roundabouts where it was possible on a rapid 5 mile journey to get the front discs hot enough to induce brake fade. I modified my driving and followed the advice as often as I could and the new discs didn't warp. The other situation was wheel bearing related. The front brakes would randomly require a second press of the pedal as the first press of the pedal did nothing and the second press would then lock the front wheels. It turned out that the front wheel bearings were causing the disc to wobble which pushed the pads back in the calipers - hence needing two orresses of the pedal to get the pads in contact with the disc. There was no front wheel shake o vibration in the steering to suggest a front wheel bearing issue. The reason it appeared to be random was because it depended on how often the brake s were used. Around town in traffic it never happened but on a motorway or A road it could be somewhat alarming.
thamestrader started following Perplexing braking problem
anto11 started following How to replace "CU convenience" (ref : J519) on a SUPERB II
Selling my Amundsen 5Q0035874B + 5E0919605J upgraded with CarPlay / Android Auto - will it work in another car?
Hi All, I've recently sold my Octavia Mk3 2015 estate. I had an Amundsen MY17 unit (5Q0035874B) plus 6.5" screen (5E0919605J) which I sent to @pab567 to enable Android Auto / Apple CarPlay. As I no longer have a use for it, if I re-sell this to someone else, will it work in their Octavia out of the box? I understand that if they put it in a none estate, the picture of the car would be wrong, but I wasn't sure if other functionality wouldn't work, or whether the component protection stuff would kick it, meaning it would need reworking. Can anyone shed any light on this? Cheers!
Keyless start not working
@oyskin did you find what the problem was?
PCV testing
Lots about the PCV system in my Rescue Roomster thread, including a 'secret' valve in the intake manifold. Includes official diagrams and descriptions as well as my pics of various parts. If it's not using too much oil I wouldn't be overly worried about investigating.
PiratModrovous joined the community
PCV testing
Been looking at how to test the working of the PCV valve by getting engine hot, removing the oil filler cap and feel a sucking motion I tried it but found a blowing motion instead. Don't know how reliable these online videos are. I have owned the engine since new, engine is steady at idle and only a cup-full of oil consumed between services. Engine is on 75k miles.
- Hi All from England
AmeliaParker started following Hi All from England
Vladislav77 joined the community
Has anyone experienced a squeaking noise coming from underneath when accelerating on wet roads with the new Skoda Superb?
hi, I am having the same issue, I am in Romania and 2 garages are telling me there is no issue.. which garage fixed your issue, if you can tell me please?
Cristi87 joined the community
Front wiper blades on 2026 SEL
Bosch wipers fitted as recommended by you guys and are working perfectly and quietly. Skoda should be fitting these from new really.
