Ottocast issues
i have ottocast, but flat one. sometimes it wont self connect, then i manually tapping on display few times and after few times it connects, in settings i choose to connect when phone is off, so when i enter in the car, start engine, i dont turn of multimedia till 1 minute pass. then it connects itself good, sometimes about 2 of 100 connections fails, then manually reconnection fix problem.
the truth about electric cars
So many new and nearly new and hardly used EV bargains about though. Cars cheap as chips. Cost to Public charge is high or pretty much as fuelling an ICE costs. Home charging is no place near the cost of liquid fuel, but there is a charger to pay for. Unless like me you use a 3 pin plug cable. eg, 350 miles for £8.00 or so while Petrol or Diesel @ £8 a gallon or so might take you 35-60 miles.
Another Oil Consumption Topic
Bad maintenance and high mileage, sport driving style increase wear of piston and rings and engine consumes oil. too much oil in exhaust dpf cant burn and get clogged. EGR also have lifetime, and egr pipes get clogged. i hope you didnt pay car much.
- Activating SmartLink on Swing 3
you553ph started following Activating SmartLink on Swing 3
Ottocast issues
Had the same on our Kodiaq and gave up with it. I replaced it with an AAWireless2 that works flawlessly
Running costs may be cheaper but the cost to change is still very large and takes a long time to recoup. This is what matters to most people. I'm sure you'll mention cheap PCP deals on EVs but they done matter to many people buying through savings or second hand.
I've been trying to rescue a Felicia riddled with cancer
Thought I'd share my video logs of what I started with and how its going. Here's a sample, a 'thank you' for some lads here that already helped me out: https://youtu.be/vMaZPU-n_KE
keywacat started following I've been trying to rescue a Felicia riddled with cancer
What engine for a Skoda fabia estate?
I would avoid a 1.4 TDI with a DQ200 DSG. Some advertised are pretty high mileage. Just a case of finding one well maintained. Hopfully someone here has had one and knows if the fuel efficiency is that good.
Evolution13 started following What engine for a Skoda fabia estate?
I don't even know what this part is called in English, all I know is I need a new one...
Huh. My car does not have that yoke between the manifold ports the yellow arrow is pointing to.
The whole point is that self charging hybrids and plug in hybrids still rely on combustion engines. Self charging only have an very short ev capacity and PHEVs, mostly are not plugged in they used as tax dodgers.
What are they?
imart143 started following What are they?
The reduced Oil Refining facilities in the UK and none in Scotland is not good for Transport Fuel or petrochemicals security in the UK and the reliance on LNG from the US is a risk. The Scottish Dual Fuel Ferry Glen Sannox that has been nothing but trouble & hugely over budget has been running on diesel since July. A major issue that seemingly was not life threatening. We will see..... A valve and sensor issue and lack of shared information from a manufacturer about updates and modifications to the owners / operators/ staff maintaining and sailing the ship.
Hi I’m looking for some advice, Ive just started working a job where I have to commute 50 miles each way down the A1 and I’m looking to replace my current car for a fabia estate (open to suggestions) what would be the most economical fuel wise I am familiar with the 1.2tsi engine but have seen the 1.4tdi is meant to be a lot better for fuel. Does anyone have any real mpg values of each of these? Many thanks
Bjohn2544 started following What engine for a Skoda fabia estate?
The Excise Duty on fuel has been a brilliant tax collecting measure. It is the most efficient tax in relation to what is collected and what is spent collecting. VAT is still 20% on EVs like all cars so is significant revenue stream as is VAT on hydrocarbon fuel. In real terms the level of Excise Duty currently is much less than it was a decade or decade and a half ago. 3p a mile on EVs and 1.5p on hybrids will not fill the Excise hole by my reckoning.
With 30% of new car sales as EV and then plug in and'self charging' hybrids making up over half of new car sales and electric cars on average driving more than ICE the transition is not too bad on course i would say. UK always going to have a problem due to driving on the left and getting new cars 6 months or so later. With fuel prices climbing ever higher, even Trump says oil prices not coming down until at least after the November Mid Terms. Some even better and cheap EVs coming on to UK market in the next few weeks making the differential in running cost even wider suggesting to those who are cost contious rather than stubbornly anti EV pro ICE will see how much money they can save and spend on other things. The very cheap PCPs on some Stellantis cars and the Dacia Spring and small Renaults plus Leapmotor, BYD Dolphin must be tempting to the cost counting drivers.
The Fine Print mentions about the self harm the UK has and is continuing to do it self with the Zero Emission mandate and is a clear example of follow the money principle.
Shop Gone from Infotainment Menu
Hello Like many, I'm currently cursed with near daily OTA updates that don't seem to be doing anything, despite reporting a successful install. One thing I did notice yesterday however was that the shop has been removed from the in-car menu system, meaning there is no longer a way to purchase Cubic Telecom eSIM data plans or renew Care Connect & Infotainment Online via the car itself. Anyone else seeing this?
chrisgreen started following Shop Gone from Infotainment Menu
What are they?
Rubber mounted exhaust support, as far as I can see.
SD cards and the Amundsen infotainment system.
You have to Share the Picture Here which Software train is installed
- Cruise control. Mine stopped working. Eventually I discovered that I had switched off the skid control, by pressing the button,
Ottocast issues
Hi. Is anyone using an ottocast mini cube? I got one recently and it will only work sometimes. Sometimes it will work after a bit but mostly it stays trying to connect with the car. Comes up usb connection failed then trys again and again. Sometimes it will connect straight away. Don't know if it's the car, the ottocast or my phone. Just wondering if anyone had similar issues
seanw started following Ottocast issues
Light Goods and HGV,s will be fuelling up with DERV for many a year. as will many millions of diesel cars, and petrol cars will be getting fuelled up for a decade or 2. As to BEV,s, plenty people that can offroad park and charge off the road are still not buying or leasing BEV,s. The wish and dream of Politicians or Interested parties is just not happening at the pace they would like.
Range Rover Velar D300 V6 to Superb L&K - Guidance, Advice and Opinions
Nice colour!
Oil companies gave such power. They do pay quite a lot of tax and collect huge amounts too. Also can threaten moving their listing from London to elsewhere. Only consumers can really punish oil companies to sell at a fairer price. Dont fill up completely I use to do, just fill up 90% or 75%. When their sales fall they will react and liwet their prices a bit. The extra VAT the government collect on these high prices is very signicant and they will welcome in these crazy times of decades high bonds and gilts which is hiking their borrowing. Diesel and petrol sellers in the UK know they only have a few years of selling significant volumes of diesel and then soon after that selling petrol so making hay when the sun shines. Crocodile tears perhaps from government and in a tough situation so pleased to see big VAT revenue on fuel sales even if increasingly losing out on excise duties which peaked at £25B per annum but no rapidly falling to £20B and a steeping slope downwards due to more BEVs and Hybrids.
If you want to know how we are being ripped off by the authorities, watch the YT channel "The Fine Print"
