gumdrop
Everything posted by gumdrop
  1. Thank you, I found Manual change today and I know I have normal and sports ratios but I don't seem to be blessed with eco or hill descent. Shame really but I do have a lot of fun with the Kamiq.
  2. I assume that driven carefully in DSG, 'S' mode the higher ratios would make the car more economic?
  3. https://www.newnex.com/usb-connector-type-guide.php
  4. gumdrop replied to eton@30900's topic in Skoda Karoq
    Nextbase for me also. OBD cable
  5. I have just had another sos message thats three now, two in the same location, it must be catching.
  6. I think that led life is taken as the led being switched on and left on for the stated period. Being switched on and off shortens the life.
  7. A friend of mine had similar problems, his workshop went straight to the fuel line filter as the most likely cause and the cheapest starting point, problem solved.
  8. Lucky it was not this https://www.youtube.com/watch?v=AXY9yi2RzS4
  9. My Monte has aircon this is a button next to the heater knob and the fan speed knob.
  10. I was watching this Top Gear video, for once fairly serious; https://www.youtube.com/watch?v=5kIS4J0XUO0
  11. That sort of cap can be used to cap pipes on new units pre-installation.
  12. Surely if it starts but does not run its electrics or fuel
  13. My last towbar for a Fabia was well over £1k, never again. Why not look into the roof rack options.
  14. I just noticed that on the linkage above it there is a what appears to be a hole for a split pin, without a split pin.
  15. I have an older Ring RAC, digital display, inflator was about £23 It is the best inflator I have ever used and has been going for many years now. I have used it on two Yeti, a Fabia and at least two other Ford cars and caravans. I think it is over 85 watts
  16. I quite like the Nissan Canto(?) it sings! There was an article by a couple with a new Nissan Leaf on the MSN page and really their only gripe was recharging. They planned their routes to include charging points then arrived to find many out of action or queues of the local electric cars doing their normal recharging. Aside from the huge initial price that is my main worry, the constant niggle at the back of your mind that you may not be able to recharge. One driver freely admitted having a petrol car for longer journeys.
  17. Putting an index finger on the key blade helps to guide the ignition key, remembering whether the keyslot is horizontal or vertical helps as well. I have even seen stick on hook velcro used as a guide.
  18. Welcome Justbob, I have had two Yeti, best car on the road, look after it and it will look after you 😀
  19. Prestone or VW screenwash, I do sometimes use Halfords concentrate. *Tablets I found they sometimes crumbled rather than dissolved this caused blockages so you still needed to carry water* https://www.autoexpress.co.uk/product-reviews/65265/best-car-screen-wash-2021
  20. I did start with "I was told" I had this happen to me at a caravan park at Braunton it was pouring with rain, it worked.
  21. I was told, Run your windows fully down then back up fully to "reset" the system, or the computer won't know where the windows are.
