Everything posted by StevesTruck
My car just dropped a piece I dont know what it does
I'd probably go through all the heater settings and look for something not working (hot/cold standard/recirc various output directions).
My guess, and it is a guess would be one of the heater flaps.
Oil sump pictures 1.6tdi
There's a few of the inside of the sump and bottom end on my build thread for my Polo over on clubpolo if that helps? https://www.clubpolo.co.uk/topic/359345-something-modern-6r-16tdi-3dr/?do=findComment&comment=2739562
What cars does the fabia VRS share the wheel hub with
Ibiza, Polo and Fabia share the hubs. Careful though, there's two sorts. Most fabias use the FSIII calipers so have the carriers built in the hub. The VRS uses a bigger caliper and a different hub. If you're getting them off an Ibiza, its a bit of a lottery which have which brakes.
Recovered Stolen car… now it gets hard..
There's various bits of software that can read the immobiliser PIN via the OBD port. On some more modern stuff, they have to take the clocks out and plug them in.
5G Download Speeds - What Can you Get?
Hutchinson telecom? 😁
Which break pads brand are good ?
I tend to just go with an OEM supplier. Febi/ATE/TRW, they always work well and are cheaper than the name brands. I used Brembo a lot about 10-15 years ago, but I found they went off in terms of performance over the years, not sure if they became a Eurocarparts label? I tried Eicher a while ago because they were cheap in ECP, took them back off again and chucked them in the bin.
Overheating on a track day.
Keep it simple - if it's not leaking it, it's burning it. Check for signs of cross contamination, do a sniffer test (the kits are cheap enough). Did anyone mention it was smoking? It is possible that a joint's getting a bit poor and it's only leaking when it's being pushed hard, so it's work having a good look around all the pipework for any leaks. Does it get hot and/or spin it's fans when it's sat idling in the sun, or if sun's in short supply, idling with the bonnet down and it's nose up against a hedge? If you've still got a/c, does the fan spin when you stick it on full cold?
Looking for Low Maintenance Motoring
Pretty much. My daily's have a hard life, my toys get looked after. I'd love to have a preened, polished car that I drive every day, but the reality is they carry tools, materials, do 100 miles most days and get parked in public car parks. That aside, my point is I never heard of a head gasket going on a 1.9TDI or early PD. I've heard it happen on a few of the later ones.
Neither ones perfect, nothing is. I'd avoid the 1.6tdi just because there's no real reason to go for one over a 1.9 or 2.0. The later 1.9's aren't as good as the early ones, my 56 plate had head gasket failure. I still drove it for ages and it died at about 195k. The 2.0's tend to just have a lot of niggly problems. They're a tough old car, but VAG build quality isn't anything like what it was.
Depends a bit what you want from your 2 grand. My personal rule for bangernomics is spend half your budget and keep the other half in reserve for stuff going wrong. Were it me in that price range, I'd probably dodge the VRS and aim for something lower specced. There's nothing in particular wrong with the VRS, they're a nice car, they just tend to lead harder lives, that and the more basic Octavias tend to be owned by old people who are more likely to take stuff to a garage and get everything done that the garage quotes them for. Also, the more basic mk2's are tough old buses that don't mind getting used for things that would probably be more suited to your landrover. I dragged some heavy stuff with mine, carried all kinds of stuff, camped in it, hit some pretty big potholes and even had a couple of fun times doing a bit of fording.
Brake Fluid - I cannot see any fluid at all in the reservoir!
That should self-rectify in about 4 years. 🙃
Or shine a torch down down the neck
DVLA clamping cars & vans in Forfar and probably elsewhere.
I've got 2 of those clamps in the shed 😆
Hydrogen Fuel cells
Hope someone's told them the gas terminal at Theddlethorpe got knocked down 3 years ago.
Parts From A Wrecked Skoda Fabia MK1 Eastate
Window motors are always worth grabbing
£72 to rotate wheels at annual service!
You can normally get a bleeder on from the back of the wheel when the car's up in the air. But yes, that takes the p***
Blue smoke when accelerating
Any sign of oiliness in the intake?
Oil Filter getting dirty/coolent leak
Any signs of oil in the water or vice versa? Heater working ok?
Tyre inflation - air isn't free???!!!
All the little 12v ones are much of a muchness, don't worry too much about the brand. They make a lot of noise and do the job, albeit a bit slowly. Don't bother with the digital ones, it's just stuff to go wrong on something that's been made as cheaply as possible. The only one I found that was any different was one from Lidl, which was a lot quieter.
Removing control arm on automatic - no space?
It's definitely worth avoiding disturbing the subframe if you can help it, particularly if you're working on the ground. They do have a bit of wiggle in their fitment, so you can mess your alignment up fairly easily. Not a great fan of poly bushes on the consoles myself, I've got them on mine and it's a bit harsh for a daily. If I were doing it again I'd go with the solid rubber bushes off an Ibiza cupra.
Front wheel bearing replacement. DIY job?
Or drop an old screwdriver between the plates of the brake disc and let it sit against the caliper to stop the hub turning while you torque it.
Fairly sure that the bearing/hub assembly bolts in on these, so yeah, as long as you've got the right sockets and a decent impact gun, it should be fairly straightforward.
Dog unit
I think the vent has an electric cooler under it, so I'm guessing they wanted that for another car
Buying a MK1 VRs, issues?
The rear calipers do like to seize, so be ready for a battle there. and yeah, the torque is an absolute laugh when you get the hang of keeping it in that narrow power band, just got to remember to look after the clutch. Then you get the flipside that when you don't want that, it's just a 55+mpg diesel hatchback.
