pab567
FREEDOMTech
Everything posted by pab567
  1. I understand that pushing on/off button does not poer the unit up?
  2. @georgebx not possible with your unit, you have to replace infotainment reader with 5Q0035842x (x - A, B or C) or 565035843 or, if you also want to have OEM sat nav, 5Q0035874x (x - A, B or C) or 565035874. Replacement unit must be patched to disable component protection and enable all new features.
  3. You need service tools (e.g. SetConfig) and EU radio board (US radio board is not compatible with EU firmware).
  4. This is the only possibility I know... Unfortunately I don't have firmware for US version...
  5. If still in the same car then no code should be required - unless CAN module inside Columbus is broken as then there is no communication with the car over CAN so Columbus cannot read data from the insruments cluser. In such case it may also discharge battery.
  6. Sorry guys, I have not realized this is thread, not PM. Looks like broken maniboard.
  7. Po polsku nie mówisz? Bo w profilu masz, że jesteś z naszego pięknego kraju... Nie, uszkodzona jest płyta główna.
  8. This is non-EU version (probably US), has it been reworked into EU version? Because EU soft will NOT work in non-EU unit unless it has been reworked...
  9. Niestety, to usterka sprzętowa, a schematów brak...
  10. All I have is MEN2_EU_SKGPx_P0080L_8755 firmware, I sent you link in PM
  11. Yes, this are probably dry joints on PowerPic chip. Torx T8 (upper case) and Torx T10 (for removing front panel).
  12. No idea, I'm in Poland...
  13. Hm, I would start with software reflash but in such case it can be done only in emergency update mode which requires UART and PC. Unit mut be rather on bench than in the car as it must be open.
  14. I'm sorry but what is th emessage you see?
  15. Your unit (5Q0035819B) does not support SmartLink (even if it is visible in menu), you must have infotainment reader replaced, e.g. with 5Q0035840B. New unit must be patched to enable all the options and disable CP i HMI. Pls contact me in PM if you are interested.
  16. Keep in mind it works ONLY with Amundsen units, it does NOT work with Bolero!
  17. @laurent2b pls post part number and SW version of your unit, you can check it in SETTINGS then SYSTEM INFORMATION
  18. This is English forum, pls use English
  19. You can't, to use 5E0919605M you must have your glove box unit replaced as well.
  20. Just take a knife and cut off the pink plug the excessive plastic trim that doesn not allow it to put into grey socket in 3V0035020B. Same to be done with blue plug that must be put into black socket of 5E0919606. Pls share VIN in PM so I can check your configuration (required to answer your question abouth USB).
  21. Może, ale nie musi, być problem z ekranme. Na pewno nie z ustawieniami.
