pab567
FREEDOMTech
Everything posted by pab567
  1. I suspect EMMC is corrupted. To have it confirmed pls change th elanguage to any other than English and then restart the unit - if after restart language is English then it means EMMC is corrupted. Unfortunately in such state software update will not work - unit must be open end EMMC must be formatted manually.
  2. Unfortunately there are no fresh maps for these units. Go to Skoda Update Portal enter your VIN and you shoul dbe able to get latest available maps for your MIB1 Columbus.
  3. @SkodaJosh pls post your unit part number and SW version
  4. Link to RNS510-6276-Update-VIM+Tm_60_35_5 sent in PM
  5. Link to download MSTD_EU_SK_P6230 (0490) sent in PM
  6. Every OEM radio will require coding and component protection removal.
  7. IMHO it's rather HW issue, not SW
  8. @dejvic when the unit works, are you able to modify sound level from steering wheel? Are the buttons illuminated when you turn the lights on? @olnime you have download link in PM
  9. Send VIN in PM and list of part numbers you need
  10. Unfortunately I have no firmware for MEN3 units :(
  11. What exactly do you need from me? Just link to download 0490?
  12. Probably SKODA delaer has just removed Component Protection but has not recovered FEC/SWaP codes. Go to service menu (long press MENU button, then go to FEC/SWaP codes and installed codes. Check if there are any that are Valid.
  13. But this is just a restart without reseting to factory settings...
  14. Try to reset the unit to factory settings.
  15. You need to check the error code with some OBD diagnostics tool (VCDS, Vag Can Pro, OBD Eleven, ODIS, VC Tool etc.) to understand the problem, make sure the root casuse is fixed and then clear the error code.
