Everything posted by pab567
Octavia 2014 Infortaiment unit upgrade
I'm sorry I don;t have any such message in my message folder 😞
Your VIN?
Glove box unit is MIB1 Amundsen and diaply unit is MIB2 - deifferent resolution,will not work.
- Bolero MIB1 Update Help Please!
Columbus head unit issues.
No need to replace, try to reflash it. What is the current software version?
CANTON sound system... ?
Nope
I need Bolero Update :-)
@Slink check your PM @donny_tsi you have the lates SW version @Pikolo follow below scheme: 1. format SD under FAT32 2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder) 3. insert SD card into the slot 4. enter Service Menu (long press MENU button)
Emergency start procedure
There is no emergency start procedure.
Swing radio code
Contact Skoda dealer
Head unit difference between Canton and normal stereo?
Yes
Yes, it is
yes
Amundsen MIB2 Firmware Update
Activated adaptation channels with word "google" and "apple"
It drives the ouptut level down to 5V to match external aftermarkjet amplifier input.
Microphone on CarPlay
Have you tried to make a full reset of your stereo?
Best Amundsen+ replacement?
MIB STD2 PQ unit, no matter with or without OEM sat nav built-in
2014 Skoda Tour de France, key set question please:
Do you have VCDS or any other diagnostics tool?
Infotainment Screen upgrade and Reverse camera retrofit guidance.
3V0919606 is for Superb, not for Octavia, and it will NOT work with your MIB1 Amundsen. if you want bigger display you have to replace both glove box and display units. Your current modules do NOT support high camera at all, several of them must have SW upgraded or be retrofitted to work with high camera. If you are interested in retrofitting infotainment system pls contact me on PM.
Parked Fabia taking over phone calls
Weird - Bluetooth should be active only when ignition is ON. What's the part number and SW version of this Swing?
Infotaiment suggestions
Infotainment reader (glove box unit) must be replaced, if you are interested pls contact me via PM.
All check you PMs.
Smartlink Carplay on 6VO 035 871H model with MENZ_EU_SKGPX_P7381L version?
Try another Skoda dealer?
They should get for you part number 000 054 830A and use it for online activation. Should be possible as well
MiB1 Bolero to MiB2 Columbus upgrade Octavia MK3 Vrs
You are welcome
@octa_user what are the new features you are looking for: 1. Android Auto 2. Apple CarPlay 3. Video playback from DVD, USB, SD 4. CD playback 5. OEM navigation 6. displaying OEM maps in Virtual Cluster (Active Info Display).
