Everything posted by Gabbo
AFS Cornering Light Error - C1034-15 Left Front Level Control Sensor
Short update for anyone that find this post in the future. I changed the sensor & the fault has gone. The sensor itself was completely seized & I'm surprised it hadn't snapped already. The job is really easy to do (1 nut, 1 bolt & the electrical connector which was actually the hardest part to remove 😁) I saved myself around 400CHF for 30minutes work & 85CHF from Skoda-parts so I am quite happy.... The New Part The Part that I ordered was supposed to be the "OEM aftermarket" part. The packaging had no indication of manufacturer but it does have the VW logo & part number stamped on it. Changing the Part: Changing the part was very easy. I removed the wheel for easy access but if you have a ramp you probably don't need to do this. There is a 10mm hex bolt fixing the lower part of the sensor & a 10mm hex screw to fit the upper part to the body. Access to them is very easy. New Part Installed & Electrical Connector To remove the electrical connector, push the small tag at the top inwards (you can hear a small click). I found that pushing hard down on the sensor before giving it a good tug upwards allowed the plastic lock to release. The internals of the connector were clean but around the outer exterior parts there was lots of dust/salt/dirt which drops out when you lift it up so its best to give it a good "blow" before refitting the new sensor to avoid anything dropping inside the new part when installing it.
Any current/former BMW 3-series owners?
I had a 320D for 15 months as a company car (my wifes actually). She hated driving it so I used it as a motorway grinder until she could give it back.... Quality wise, the BMW is obviously a bit better built & the interior materials were better. However, from a driving point of view the Octavia was much nicer particularly around town & felt much more nimble than the heavy BMW. Practicality for a family they are both the same but servicing costs for the BMW were double the Octavia (both taken to official dealers but I didnt actually pay for the BMW). One thing I disliked about the BMW (it was from 2014 similar to my Octavia at the time) was that you could not update the navigation maps for free. You needed to buy a DVD for €400 a pop for the BMW... I guess you can probably buy from "amazon" much cheaper & more modern versions will have OTA updates I guess. I was very happy to give back to BMW & get back into my Octavia. You sound like "performance" is more your interest though & I cant really comment on this much. The vRS TDi is more than quick enough for me & although not immensely exciting to drive it is very comfortable for cruising on the highway & munching through the miles.
Elm327 Bluetooth reader
I dont think leaving it plugged in will cause any problems, it will obviously have a small drain on the battery but it will be mininal as it is only a bluetooth device. As long as you dont leave you car for weeks without use, I cant see it will be a problem. In switzerland the large dealership franchise AMAG provides a bluetooth adapter free for your car when you use them for servicing. I have had one in my Superb for the last 15months. It transmits data on mileage, faultcodes, GPS position, driving style,.... so that with their app you can book a service or "find my parking place", pay for parking or charging etc etc.
Glow plug light starts flashing, stops if engine restarted, no OBD error code
A flashing glowplug light does not necessarily mean a faulty glowplug & broken glowplugs should give error codes to indicate which one. (I just replaced one at 256k km) The glowplug is often used to highlight an "engine fault" which is not emissions related (so does not need to set the MIL lamp)... Glowplugs are "mostly" only used when the engine is cold, with the exception of regen, so if it happens while drive & the engine is hot I wouldnt rush to change the glowplugs unless you can confirm a fault with a DTC. How are you reading the error codes because if the car is really in limp-home mode or a limitation is being applied there should usually be a DTC to say why?
Spare Parts - Where to buy from?
I ordered the other part I needed from them this morning. Front Left headlight level sensor. They automatically adjusted 20% tax from the order & i had a FedEx tracking number from them 1 hour later... Great service from them so far 🤘
This is the part I ordered: Headlamp Level Sensor Europen Union - OE producer 5Q0412521C As Switzerland is outside the EU, it is only €84 + 8% = ~€90 Will post an update on the manufacturer & fitted when it arrives...
Adblue indication continually showing 6500 miles left
My Superb with AdBlue also counts in 500kms so Id give it a few hundred/thousand miles to see if it works. You're given a warning when you have a few thousand miles left on AdBlue if I remember correctly.
My Octavia 2014 vRS TDi 184PS has been throwing a warning for a while for AFS cornering light error. Scanning the codes I have C1034-15 Left Front Level Control Sensor Open Circuit or SC-Battery I have found the sensor on the front wheel assembly & was looking to replace it. I believe the part number is: 5Q0 412 521 C I've found the part on Skoda-Parts.com & there are 3 versions: Skoda Genuine €200 OE Producer (EU) €103 EU After-markert €43 I'm guessing there's no point to buy the Skoda part over the OE part as they are identical except for branding. What are peoples thoughts on the "AfterMarket" part vs OE Producer part ? As they are from "Europe" Id assume its not a chinese part but manfacturered in europe as an aftermarket part. I will take a quick check of the electrical connector before I order the part. Are there any things I should look out for when changing this part ? It seems pretty easy to do with the wheel off -> 3 bolts & the electrical connector.. Id hope I don't need to reprogram or relearn anything after replacement as its automatic at every ignition-on.
Does levelling cause the AFS error?
@toodeep Do you know the part number for the front sensor which you replaced?
If it was this price I would have left the stress to the garage no problem... Skoda here wanted 60chf (£55) for one glow plug excluding labour... I was also happy after investigation that my engine seems to have 4 normal cheap glowplugs. There isn't the expensive glowplug pressure sensor...
Superb 2.0TDi fans running after engine off - possible DPF issue??
I guess so. I have a dongle from Carista but didn't pay for the subscription. I can use the device with other free OBD apps and it shows in them as a ELM something... I'll take a screenshot from home tonight to show you.
Do you have a Bluetooth OBD device to be able to read information from the ECU? The VagDPF app is very useful for visualising the system (pressures, soot mass etc). It would help understand if a sensor is not working properly & may help localise the problem. It's not unusual for the fans to run when you stop the car but there is clearly a problem in your car if you have the DPF error. My journeys are 65km twice a day. Despite mostly motorway mileage, my car likes to start a regen when I reach the sliproad at the end of my journey so often doesn't complete before I reach home ~4km later. As a guess I would say the DeltaP sensor is blocked/not working correctly. This is the main reading used to determine if the DPF is empty or full. If the garage said the DPF was not blocked, this would be what I looked at next.
Short Update... I managed to source a glowplug while I was back in the UK for Xmas for £12 incl postage. B&B Components – B&B Components if anyone is interested... They have an eBay & Amazon store front also. I went for the Bosch (GLP194 Duratherm)... Fitting went smoothly & actually the difficult part was popping off the electrical connector. Luckily cylinder 4 is the easiest to access & it came off after being a bit more brave & hard tugging with a pair of pliers. The glowplug itself came out with around 20Nm and a short "crack" on a hot engine. The thread itself & shaft were completely clean which I assume helps. New one greased & installed with 13Nm torque. DTCs cleared & MIL light is now gone & no more fault codes... Will keep an eye on it for a few weeks but I am quite pleased with the outcome.... £25 for glowplug & a big tube of ceramic grease as apposed to 60CHF (~£55) just for the part from Skoda.... I'd guess the fitting would be hundreds. A real Happy start to the New Year for me, Gabbo I found this video also quite useful: (Note: the plugs are exactly the same size although the new one looks a lot bigger in the photo)
Columbus Map Update problem
That would make sense because the file structure is different than than MIB1/MIB2 downloads. There's usually 2 root folders & 1 file. - MIB1 - MIB2 .Textfile (can't remember the name)
Try to format the USB stick as FAT32 & then copy the 2 folders from the zip file to it... If that doesn't work, try to format it as NTFS and try again. I can't remember which one worked with my MIB1
Can you post an image of the file structure on the USB drive? If it can't find the update it's usually not copied to the usb drive in the correct way or the usb drive is formatted in the wrong way. My old Octavia MIB1 would only accept FAT32 drives. I remember reading somewhere that there was a corrupt download on the Skoda website (15Gb instead of 24Gb)... I usually use a usb harddrive instead of the usb key as it's a bit faster that way...
tyre repair kit
Is this something you can really do at the roadside in pouring rain & get you motoring again? Finding the cause of the puncture isn't so easy in the dark, nor is removing a nail or a splinter key alone getting access to the tyre from the right angle.. I'd much prefer to have a full-size space saver knowing it would at least get me home without too much hassle/stress
What options for a corrupted infotainment screen?
In the Octavia MK3 forum there used to be a guy who repaired VAG Systems. Not sure if he's still around but have a search for "Columbus repair" in the Octavia side.
- Front Assist not working, but no error messages appear.
tyre repair kit
Manufacturers only provide these kits to save weight of the "base model" to reduced the weight of the car for emissions classifications.
tyre repair kit
I've used the compressor & foam on one tyre. It didn't really fix the puncture & made an absolute mess of the inside of the wheel/tyre. The only other time I needed one, I'd lost the valve from the tyre so no kind of kit would help I always spec a spare wheel since...
Keyfob issue after changing battery (red light not coming on when button pressed)...any suggestions?
Double check the battery doesn't have a child protection sticker on it. I changed my key battery last month & it didn't work. After 10 minutes swearing at the keyfob, I was about to replace the new battery with another one. When I took it out I saw a small circular sticker on the top side which was preventing it from making a connection. Seems like it is something that tastes nasty to stop babies swallowing it.
Any way of disabling this auto braking?
Just my 2 pennies worth but in the specific condition described in the OP, the car in front is slowing to almost a standstill and turning into a side street. Front assist does not anticipate the behaviour of the car in front, it only looks at the information presented to it, the car in front is stopping & you are driving towards it. In the UK it's quite common to brush past the back of the car Infront when it's turning because you as the driver know it will continue to turn. In Europe a driver turning into a side street does not have right of way over a pedestrian and can often stop before entering the junction. You must think of the system with this kind of manoeuvre in mind. Also, from a manufacturer point of view, there is nothing dangerous about braking sharply in any conditions. It's the driver behind who is at fault if they hit you because they must maintain a safe stopping distance from the car in front in the event of such an emergency stop. Whilst in real life this will obviously cause problems e.g. on a motorway or busy road, the manufacturers are covered by the road regulations given to them & for them it would be more serious if they hit a pedestrian rather than someone else his the back of you.
Start Stop Stall
Does it happen also when starting the car for the first time or only during stop/start events? One easy thing to check is the battery terminals are tight and don't show signs of oxidation around the inside. If the terminals are loose they can cause problems starting but this would normal occur for any kind of starting not just stop/start
Thanks for all the replies and positive feedback for Skoda-parts 👍 I have already watched the videos in both linked threads before deciding to give it a go myself until I got stuck for where to buy the glow plugs. (Plus read the recommendations of several people with respect to the maximum torque/lubrication/hot engine/tighten-then- loosen etc... The cars has done 235k km so it's fair to change a few parts like this. I will change only 1 for now & see how it goes does. If it's easy, I will consider the others, however, the pressure sensing glowplug for £150 will stay until it's broken for sure Thanks again all 😍 Gabbo
