Everything posted by Gabbo
Car failed MOT brakes - question
I would take my chances & drive it from the dealer to the garage of your choice. If the brakes were working fine when you drove it there, they will be working fine for 2km more. Pads worn to the indicators still have material on them. There is a risk you'll scratch the disks if you don't replace sooner then later but again 2km won't destroy them.
Superb 'think' it is different speed limits
You can also use a usb hard drive to download the maps or use a USB-C to USB-A adapter with any existing usb sticks you have
The "online maps" is a subscription service if I understand correctly. You get 3 years free from a new car & then must pay for to continue the "over the air" updates. You can always perform the update yourself manually by downloading the files from the Skoda Update portal and using a memory stick to install it in the car. Enter your VIN number here to get the list of available downloads: https://updateportal.skoda-auto.com/en-GB
Frequent dpf regens
You can also name it the dP sensor but be careful talking about it in hearing of your wife.
And it's logical if you turn off the TSR that the displayed limits should come from the navigation system.
Updating the maps is the first thing I would try.... The online version might be right now but you don't know what version was integrated by VW in 2020... My 2014 Octavia isn't connected but you can download map updates from VW for free. After one update they had added the speed limits for some temporary roadworks into the map system. It was 2 or 3 updates before the limits were corrected even though the work only lasted 2 or 3 month max.
Superb Mk4
New Sportline trim announced https://www.skoda-storyboard.com/en/skoda-world/meet-the-new-superb-sportline/
Frequent dpf regens
Which Carista adapter do you have? I bought one for €13 from Amazon a few months ago but don't want to pay for the subscription. I was going to sell it but if I could use it as a Bluetooth OBD adapter this would be cool...
Frequent dpf regens
Sensors can fail & give in range values although it's less common than an electrical faulty like short to battery or open circuit. The DeltaP sensor is connected by pipes to the entry and exit of the DPF to measure how the air is flowing through it. This pressure will vary at different engine speed, injection quantity & DPF soot level. If there was a blockage in one of the pipes it could allow the pressure to increase but not decay as quickly as expected. This could then be interpreted by the ECU as a "full filter" because the pressure is higher than expected. Gabbo
Frequent dpf regens
Yes but the sensor is used as a comparison with the calculation to adjust the calculation to the "real" soot load... Is assume, If the DeltaP sensor suddenly jumps to a much higher but plausible value, the system will think the DPF is full & trigger a regeneration regardless of the calculation or time since the last regen...
Frequent dpf regens
Soot is normally modelled based on how the engine operates & corrected by the Delta Pressure Sensor... As previously mentioned I'd start with the DeltaP sensor. Maybe also checks the EGR valve is able to close correctly ??? In the long run it may well be worth to pay a dealer to run a diagnostic of the aftertreatmemt system to help pinpoint the cause.
GPS Issue - is it Aerial, Amp or connection? Superb Mk3 2017 Estate/Combi
The default location for the VW Satnav is usually Wolfsburg Germany where the head quarters of VW are located. I saw this several times after upsetting my Octavia MK3 Columbus maps but the correct location came back after the GPS locked onto a signal.
Virtual pedal “Simply Unclever”
I've have a 2023 model and can say I've done this a few times too. Typically it was when we were skiing and the kids sit on the boot lip to put on/off their boots. If I stand too close when helping them the boot lid has started to close on them. It's funny because I had those one the Volvo XC90 & Merc GLE and couldn't get it to work reliably on either. The Skoda is the opposite. It's easy to use but sometimes a bit too trigger happy
Protective film for the rear bumper
Here is the actual product link. It seems my link before shows only pictures... https://www.amazon.de/-/en/gp/aw/d/B097YSVM59 Do you have a link to what you bought?
They do the same in transparent. Also the aluminium protector from Skoda doesn't cover the "lip" of the bumper so the film offers a small benefit over this..
I have this on my Octavia and Superb: https://www.amazon.de/portal/customer-reviews/media-gallery/ref=cm_cr_dp_mb_crsl_img_sm?ie=UTF8&asin=B097YSVM59&mediaType=image If you look in the reviews with images you can see my Dragon skin Superb with the carbon look vinyl cover... They are great for light use, loading shopping, pets, light DIY items etc. If you were to drag a heavy furniture over it, then it will likely scratch or tear. You can see from the photo the thickness of the strip. I considered the official aluminium protector strip but that is more than 5x the price so I decided to try this first. I've no complaints so far
Charge and Petrol Flaps
Does the Octavia have a feature to "purge" the vapour from the petrol system before it will allow you to open the charging cap? On our last Mercedes, When you pull the release of the charging flap, you would need to wait 10-20s until it will release the flap.
Frequent dpf regens
I had a month with my car which was similar. My wife was using it and only doing short journeys & it seemed like there was a constant attempt to regen. At the end of the month I had the warning "DPF see manual". I took the car on a run up the motorway and after 10 minutes the warning has cleared. We've not had any issues since... The car is currently at 225k km & I've never used additive or cleaner.
Lumpy tick over
I'm not really a mechanical guy but I'd also imagine a stretched timing chain would constantly affect the engine not just sometimes... What else have they checked? What is P0011 ?
GPS settings - TimeZone, Speed display, Light Adjustment
Just completed my first trip from Europe to the UK in the Superb MK3 2024. Was a bit disappointed when crossing the channel that the Speed Display & Time didn't automatically update when it detected I was in the UK. Had to change both manually in the settings. In my MK3 Octavia there was a popup asking if you wanted to change the light settings to RHD instead of LHD. There was nothing in the Superb... Do I need to change my lighting configuration as well?? On the plus side, I was very impressed with the fuel economy during the trip. 200PS 4x4 DSG7. 5.9l/100km at French speeds 135kph (800km) 4.9l/100km at UK speeds 65mph (105kph) average (400km)... How can you guys live with the state of the roads in the UK though? Almost 50% of my journey from Dover to Manchester was through roadworks with 50mph limit... The road surface is terrible & the lane disciple in the UK is appalling... 5 lane highways and everyone sticks to lanes 4 or 5 even when there's nothing in the first 3 lanes... 1 week of autobahn lessons in Germany should be made compulsory..!!
Skoda clutch advice
A diesel manual should be almost impossible to stall even if your are hard with the clutch. There is plenty of torque even at pull away & you should be able to drive completely from standstill just using the clutch (without touching the accelerator pedal). The idle controller is very strong in a diesel. I would say that your clutch is completely shot or you have problems with the DMF (flywheel). You can test the flywheel by driving in gear. Accelerate, no accelerator, accelerate no accelerator & if you hear a clanking each time the engine engages/disengages this is also a problem. Did you buy the car from a garage or private sale? I'd recommend taking it back to the garage if you can.
Cornering Light AFS Fault
I signed up for the free trial of Carista to read the fault codes. Mine suggests an error from the front levelling sensor: 5256213- Left front level control system sensor: Open circuit/short circuit to B+ I assume this is the sensor fitted to the steering/ front drive system in the left wheel arch as shown in the image? Does anyone know the part number and how simple it is to change?
Seat Organiser/Tablet Holder Recommendations for Sportline seats
Thanks, that looks like it would exactly do the trick without looking too terrible when fitted. I'm back in the UK next week so might order one of these from Amazon to see what they're like. 👍
+1 bump for this thread. My Octavia just threw the same error... Any suggestions of things to check would be appreciated before I take it to the garage in November for the service
When I ordered my Superb Sportline last year, we only saw the L&K version. The L&K had these great headrest tablet holders which the kids loved which obviously cant be fitted to the Superline. (doh) We are making our first roadtrip next month & the kids are now complaining that dont have anywhere to organise their things. Does anyone have any recommendations for rear seat organisers for the Sportline seats? All of the ones on Amazon have an adjustable strap around the seat which is guess is my only possibility but look pretty terrible with the bucket style seats
