Gabbo
Everything posted by Gabbo
  1. I found this feature useful on other vehicles (didn't try it on the Skoda yet). It means I could track the progress of my wife's car using the app if she was coming back from her travels/work etc or if she was out somewhere late at night. I guess it's also needed for the "find my car" parking option
  2. I was informed by SkodaParts on Friday that my missing item should arrive in stock next week so fingers crossed by the weekend I can give an update on the new arm
  3. I ordered the genuine part as my car is less than 1 year old. But I guess for this kind of component a cheap after market part would be enough. I will keep the original arm and hopefully when the aftermarket parts become available, I may switch back to the newer part. I guess Skoda will use it on other models so eventually Bosch etc will make any adapter for it. The could even support it easily with the A403H if they just provided a plastic adapter in the box like they do with other blades.
  4. I also cannot find any info or stock for the A405H blade either 😞 in Germany or Switzerland
  5. I've ordered it from Skoda-Parts but my order is delayed until next week because something else I ordered is not in stock & on back order. I will post an update hopefully next week when it arrives with some pictures. Gabbo
  6. "allowed" is probably wrong more like "not checked for"... An air leak after the turbo would cause loss of power & smoke. You would have a sudden drop of boost pressure & less air means less fuel before the combustion because Smokey. Small leaks are often difficult to check for because at low/medium air flow there isn't the pressure to force the leak open & as pressure builds the gap will open.
  7. +1 for this, I'd check for air leaks after the maf sensor to the inlet manifold. Intercooler perhaps?
  8. My car is only 12 months old and had the latest OTA update for the infotainment. Id be surprised if they took this away as it's quite important particularly for cars sold in the UK to be able to display kph Maybe try posting in the general VCDS forum to see if anyone knows if a setting to enable this option that you could change ?
  9. There's must be a way to do this even on different levels of infotainment unit. Does you virtual cluster display only mph or is there already kph overlayed on it?
  10. Here is some information regarding the different wiper arm attachments between the old & new part. The original part from my car is on top in the photo & the bottom is a Bosch A403H. The Skoda part sits flush to the arm without the end cap of the Bosch part but you can see from the photo they are not compatible. I tried to remove the locking cover/adapter to see if I could just swap this part to the Bosch blade & keep the old fitting but its not possible. The holes line-up but the spigots are much thinner on the Bosch part so it doesn't sit tight on the Bosch blade. (see adapter in the photo below) I'm still waiting for the new wiper arm to arrive, so it the meantime, I have "reversed" the original blade by cutting of the small tag in the middle of the adapter & refitting it in the other direction. The small tag in the middle of the photo below next to the text >POM< ensure the adapter is always fitted the same direction on the blade. After a couple of days the wiper has been silent (but its not rained here so its difficult to tell). This will do until the replacement part arrives hopefully next week.
  11. Are you sure it's not just the warning that you have left the car with the ignition still on? It's quite easy to trigger this if Stop start causes the engine to stop when you get to your destination & just open the door?
  12. On mine is here between Time & Date and service.
  13. I don't know this sensor so much from VW but typically it is a self learning sensor so shouldn't need any coding. The ECU reads the sensor when the ignition is first turned on. It takes this reading as 0bar delta pressure because there should be no difference in pressure when there is no air flow. Afterwards it measures the pressure difference before and after the DPF to determine how full it is.
  14. I would argue with the garage they they should do it for free so that Skoda will earn the annual payments from the services you pay for. On my car it was only needed for them to do something on the computer and then the account was activated. It was the same with our last company car from Mercedes, you couldn't do anything yourself without the account being activated by the garage. It took them 2s and then the app & the connection to the car worked immediately.
  15. Try here to find the electrician connector part number: https://www.skoda-parts.com/catalog/octavia-4/spare-parts/electrical-equipment/wiring-harness-terminals/terminals-744.html If you can find any Audi, VW, Seat, Skoda with the 2L engine I'd imagine the connectors will be the same...
  16. This site is very useful for part numbers and diagrams... This looks like the same parts (but check its the correct engine as yours): https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/2/253/253064
  17. Sorry, I'm jumping between forums too much 😕 I was confused between the Octavia MK4 & superb mk4 which had only been available 3 or 4 months. 4.5 years old is not long for a battery but it's feasible it could be the cause especially if you've had it tested...
  18. If you are happy buying Bezos yachts, Amazon do a bulk pack of 10 from Varta/Energizer etc which usually have their shelf life printed on the packaging. I've been slowly going through these four my 5 Skoda keys
  19. Actually for Columbus MIB1 its the same story but 4 years later.... In the comments from this thread its confirmed that the map files are no longer provided for MIB1 only for MIB2 and the downloads dont work. Shame.... 😞
  20. I cant really tell where that is on the engine from the picture but the whole area looks very very sooty... Do you have a leak from the exhaust manifold that is passing hot sooty air into this area which could have caused the plastic parts to melt?
  21. +1 for PetrolDaves comment.... As you have a Mk4 you'd be unlucky if the problem was a low/bad battery... Do you have something plugged into the 12V socket like a dashcam that could be draining it?
  22. That thread seems to be for Amundsen & I have the Columbus MIB1. There were still official map updates last year for the Columbus & the last version I have is 2024 CW25 the same as the download link.... I will try to find an equivalent VW download as I've used those in the past when there were delays putting the same version on the Skoda download site.
  23. The temperature dial is not linear or accurate, between 70-110 it will just stay at 90°. You can add Coolant Temperature in the maxidot display which will give you a more representative value. When you have the beginnings of the water pump problem, it will occur shortly after starting the engine after the when the temperature gauge reaches 90. You will suddenly see the temperature gauge moving towards the red & you will get a warning "coolant temperature high" in the maxi dot. In my case it was just a warning and before the temperature exceeded 130deg and entered the red, the water pump would pop open and the warning would disappear. Reading the DTCs will give you a water pump position control error. The water pump sleeve operates once in a engine cycle so as long as the engine stays hot, it won't open or stick again. For me it only happened when I started from cold, drove a few Kms & stopped at the nursery for 10 minutes to drop off the kids. When I returned to the car, drove into the highway then I would get sometimes the temperature warning. If I started from cold and drove directly on the highway I didn't have the problems. There was no coolant leaking or coolant loss it was purely a mechanical error with the sleeve. I drove my car like this for ~4 months because of part availablity and the error occurred once or twice a month but getting slightly more often the longer it went on. I've driven 150k km with the new part without any issues.
  24. Passat/superb is a nice step up in terms of comfort compared with they Octy. I've recently upgraded to a Superb and it's very good. Aside from the lower power TDi (with smaller injectors that will limit what you'll get out of it) the other thing you might consider is the ride and handling of the Passat. The VRS Suspension is very firm on the Octy. If the Passat is similar to the Superb then it will be like driving in a bouncy castle over speed bumps in comparison. It's very comfortable when driving leisurely with the family but not really great if you take a speed hump faster than a crawl. Gabbo
  25. It's around the right age & mileage (mine was 2014) and my water pump went around 100k km just over 3 years old Given your mileage it's unlikely the timing belt or water pump has been changed. Iirc it's 100k miles recommended interval (I'm sure someone else can confirm). There's a big thread here concerning this problem. Gabbo
