Do I need view button when retrofitting VC?
Not sure there is a 'best'? I'd probably use eBay or a breakers but obviously a dealer/TPS should also sell them
Not quite. You can't access this menu to change what's shown in the two middle circles: You can do this via the headunit, it's just much less convenient as it's quite a few button presses via the headunit rather than holding the view button. This menu won't be shown either which enables/disables display modes: AFAIK, there is no other way of changing this, you need to have the correct buttons.
It's slightly nicer with the view button installed: - Pressing view switches the display style (classic, advanced, modern, basic, sporty). - Holding view lets you turn display styles on/off. - It stops the right roller from switching views, I'm sure I had issues with accidentally changing display... The only negative is the lack of phone button. Personally, I'd say yes assuming you can find some inexpensive buttons as It finishes the retrofit off perfectly. edit: I think it also lets you change which 'preset' (auto, classic view1/2/3) the side panels display rather than going through the headunit to change them.
Eco mode
As far as I know, the only way to change mode is using the button which makes the 'drive mode selection' screen appear: Oh actually, I think you have a 1.0 TSi in which case, I don't think they get drive mode selection: In which case, I'm not sure how you get out of eco mode... It could just be a gearbox thing, I don't have much experience with a DSG, maybe put it in sport mode?
Reversing Camera Retrofit
Oh if only everyone had common sense It's pretty easy to avoid the airbags on the A-pillars as everything is obvious once the cover is removed. Never had to deal with curtain airbags but I imagine that's harder to do properly unless you drop the headlining to see what's going on... On my MK3 I used the bottom route as it followed the bulk of the existing wires. I used both routes on my MK2 depending what I was fitting.
updating to folding mirror.
Each of the front doors has an electronic control module, these are the door controllers Only the 'highline' versions have the two pins fitted for the folding mirror motors. I've no idea how expensive they are. I think it's relatively easy if the door mirrors came from a similar Octavia, if not, they may need re-parametrizing with ODIS/VCP. Just as an example, my 2018 vRS with folding mirrors has these controllers but I'm not sure if they'll be correct for a 2016 car. Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B Component: TSG FS 011 0032 Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B Component: TSG BFS 011 0032
I think you'll need a pair of foldable mirrors, two new door controllers that support finding and a replacement mirror switch. After that it's just coding 👍 I'm sure @SashaGrace will be along soon to confirm.
Random dashboard question
It is on a MK2 which is a fare comment given where the question has been posted. However, that picture is of a MK3... In which case, if the car has Canton then it's the centre speaker under a grill. If the car doesn't have Canton, I think it's just a grill and probably OK to cover...
Eco mode
Do you have a drive mode button in front of the gearstick?
Daylight Driving Lights
It's odd that you have the DRL option in the maxidot but they don't work and there is no bulb warning.... Anyway, it should be pretty obvious if the bubs are fitted on a 2010 Superb. Take a look at the fog/DRL units in the front bumper. If you can only see one bulb per side, you only have fogs, if you have two bulbs per side, it should be possible to enable DRL Have you got any diagnostic equipment like VCDS? If not, I might be able to help as I'm in Cambridge most weeks.
No "Station logos:" button in Bolero
Excellent, you should be able to save that logo and add it to your headunit
What goes here? (dashboard question)
At a guess, it'll be a headlight range adjustment for lower spec cars with halogen headlights. It won't do anything on a car with xenon or LED headlights
Octavia ABS Control Module Issue
1K0 907 379 P looks to be a MK70 series ABS pump so it's coding is pretty simple. If you can't retrieve it's coding, you can reuse the coding from another similar vehicle as there is nothing VIN specific included. VCDS probably has a helper too 1K0 907 379 K looks to be a MK60 series ABS pump so it's not a direct swap. You'll need to change the mounting bracket, connector, parts of the wiring and come up with a suitable coding to get it working...
- VCDS Adaptations. How do I ..........
Parts For Sale: MDI module and BT/MDI wiring kit (inc mic)
View Advert MDI module and BT/MDI wiring kit (inc mic) Removed from a '61 plate (MY12) Octavia, everything in the picture is included: - MDI module - MDI bracket and plastic nuts - MDI wiring to MDI connector - 2x MDI adaptors, one USB, one 'apple 30pin' - Plug and play wiring loom for both BT and MDI - Microphone and wiring - Slightly damaged BT module cover The BT module cover has been used with both a 3C8035730D and 3C8035730E module, I'm not sure which others are the correct size. The microphone can be connected in two places depending if you have a Columbus with voice control or not. Initially, it was just a BT loom, I added the extra wiring and connecter needed for the MDI module Advertiser langers2k Date 18/04/21 Price £40 Category Parts for Sale Shipping Estimate £10
Facelift problems with rear view camera installation
They will have needed to There's a guide here that might help show what's involved:
Do I have a fake?
Functionally? Probably not much, Morally? Massively... Carista, OBDeleven, Ross-tech and VCP are creating, updating and supporting their own product. It takes money and resource to keep these things working as VAG change protocols/modules. When buying a genuine version of any of these tools, you're effectively helping that company survive, profit and continue supporting/developing their product in to the future. When genuine, I don't mind which interface people use, they all have pros/cons. A cloned version is someone stealing the hard-work and investment that one of these companies have made, reproducing and then selling it for their own profit. That's where the difference lies. Even more so when they claim their cloned version is genuine as they did with you Ross-tech and others have certainly have done lots of reverse engineering to understand the VAG protocols, I'm not sure if they have any insider knowledge or have purchased an official dealer tool to figure it out. I expect the latter as they tend to play catch up and the next VCDS version will add support for newer vehicles. I certainly wouldn't class it as a 'hacker' product. I believe that some 3rd party diagnostic companies have used Ross-techs label files in the past which is why they are now encrypted. I'm not sure if Carista, OBDeleven or VCP have ever been accused of this but I expect there will always be a degree of copying and reverse engineering between these companies. It's always easier to copy... You also need to remember that VCDS is primarily a diagnostic tool, the fact we can change coding and adaptions which makes enabling various hidden features or retrofits possible is pure luck As you may have seen, VAG are introducing ways to prevent any none-dealer tool from changing things with SFD tokens. Hopefully Ross-tech can come up with a solution to this, I know other companies are although they are of questionable legality and my be short lived. That I agree with completely The one touch functions are terrible in my opinion and destined to mess up many cars given the lack of checks! A well written set of instructions are much better, if nothing else, it should be clear when something isn't matching which is a sign to stop
Start/stop too quick to activate.
Not on a MK3 Octavia, the BCM is very different and there are no numbered adaption channels so 34 won't exist
Do I have a fake?
That's 100% a fake, it's one of the 'better' fakes but it's definitely not genuine This is what my genuine looks like: And mine appears identical to another genuine one shown here:
Do I have a fake?
As far as I'm aware, it's not currently possible to bypass the VIN restriction on genuine cables. It's only possible on non-genuine cables If you really want to know, grab a T10 screwdriver and open it up. Add a picture of the PCB from both sides and I'll dig my genuine one out to compare it to
Do I have a fake?
If its been sold as a genuine interface and Rosstech say it isn't, I'd send it back. The laptop looks like a Dell Latitude E4200 which is about 10-13 years old now and probably only worth £30-40. Given you've paid a decent chunk of money, I'd expect to get what you actually paid for rather than a knock-off. It doesn't really matter if it's a fake or if it's a interface that's been messed with, you expected and paid for a genuine legit interface with future upgradability and that's not what you've been sent. It might work for the moment but future releases of VCDS might not work. Unfortunately for Rosstech, the clones are getting much harder to spot these days.
Nope 😉 Adaptation channels are adjustable using VCDS, ODIS, VCP and OBDeleven. It's down to the module software and coding to what adaptation channels are available. The dataset/parameters are not 'adjustable'. ODIS or VCP are directly changing a section of EEPROM in the module. The XML or ZDC file contain the data, where it needs to be written, checksums to verify the data and any security codes to unlock the module to write it. They are distinct and separate from each other 👍 If Rosstech wanted, they could add the ability to write datasets. I doubt they will as the only 'true' source for them is the VAG servers via ODIS with a subscription etc... Edit: If you want to get an idea how some datasets are constructed, take a look at: - https://skodapilot.com/rdkseditor/?lang=en - https://github.com/jilleb/MQB-FPA The first link is for direct TPMS modules, they are quite well understood so custom datasets are possible. This means that you can create a dataset containing the correct tyre sizes/pressures for any vehicle rather than relaying on VAG datasets. If you create a few datasets then compare them in a hexeditor, you'll soon see how these datasets work. The second links is an ongoing project to reverse engineer the CAN-gateway dataset. Although some parts are now understood, plenty isn't. As I already had the dataset for my CAN gateway, I used the info to make the 'vRS' button only light up in 'sport' rather than all modes apart from 'normal' Other modules will have different formats which are likely to be unique to the module and software version...
Instrument Cluster
It's all in the owners manual. Go to the 'display main menu': - for a MFSW, press and hold the right most buttons - for a wiper stalk, press and hold either end button Find 'driving data': - for a MFSW, turn the right thumbwheel up/down, then press the thumb wheel to select - for a wiper stalk, press the end up button up/down, then press the button underneath to select Find the MPG: - for a MFSW, turn the right thumbwheel up/down - for a wiper stalk, press the end up button up/down Simples Couple of snippets from the manual:
