Fault code
Could be as simple as dust or a spider obstructing the ultrasonics. Give them a quick clean, clear the code and see if it returns.
How to enable both rear fog lights on OCTAVIA 1.4tsi hatchback 2017 Split head light (LED front and back)
If you can post an adaption map, I can take a look. No idea how you get an adaption map out of OBD11 though...
MIB2 - Amundsen 5Q0 035 874
Pretty sure the pink is for the display...
BT module upgrade
Track info and skipping is also down to the headunit. For instance, when I had an Amundsen (RNS-310) and a 3C8035730D BT module, skip worked but there was no track info. When I switched to a Columbus (RNS-510) track info was also shown At a guess, you might get skip but not track info. Might be worth trying to find someone with the same headunit/BT module to share their experience. I've never owned a Bolero or 7L6 BT module so I can't be sure...
BT module upgrade
I would expect so, you may have phonebook issues depending on your Bolero version. Check the adaption channels, is the name important? Depends completely on the donor vehicle, I would suggest you at least check the coding. No. I think all BT modules have 'MFSW support', in as much as the volume will change and the phone button works?
Build code for tow bar electrics
Yup, I wouldn't expect any wiring fitted for 1D0. Few others that may help: 1D0 = Without trailer hitch 1D1 = Trailer hitch 1D2 = Trailer hitch removable and lockable 1D3 = Trailer hitch 1D4 = Trailer hitch manually swiveling 1D5 = Trailer hitch (pintle hitch) 1D6 = Trailer hitch 1D7 = Trailer hitch preparation 1D8 = Trailer hitch preparation 1D9 = Trailer hitch electrically folding
Fault code vcds octavia 3 vrs tdi
Any genuine interface should work perfectly with the English version of VCDS which is freely available from Rosstech: https://www.ross-tech.com/vcds/download/current.php However, the non-English VCDS versions are translated by distributors so they only work with a interface purchased from that distributor. If you contact the French distributor, they may sell you a licence but I've no idea of the cost... In your case, you were misled but the OP can install the English version alongside French one they already have
Daylight driving lights
There is an option via the infotainment on my 2018 Octavia vRS to turn DRL on/off, it's even mentioned in the owners manual... At a guess, try setting 'Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich' to 'active' in the BCM I tend to turn them off if I'm doing some involved coding etc to save battery life. Also useful at a drive-in cinema to keep the car unlit if you need to start it
VCDS Rod file missing (SK37)
Maybe find someone local with a genuine cable and see if that works? If it does, consider buying a genuine one
It might help if you install the latest English version of VCDS and post an autoscan
2016 Skoda Superb Headunit removal
Try this, it should be pretty much identical for the MK3 Superb
ELECTRIC COOLING FAN
There are passive, active and service regens. - Passive regens will happen 'naturally' if there is sufficient heat to burn the soot off. - Active regens are when the ECU injects extra fuel to get the DPF warm enough to burn the soot off. - Service regens are triggered by diagnostic equipment. Typically only high load driving will get the DPF hot enough to cause a passive regen. Motorway driving, towing or steep terrain can help. Some claim they never happen but I certainly saw them on my CR140. In your case, I expect the ECU had triggered an active regen due to soot levels, these are normal and most of the time you won't notice them if it happens during a drive. You might have a slightly higher idle and increased fuel use so nothing super obvious whilst on the move. They happen every ~100-400 miles depending on driving style and if the car has had the emissions fix. If the regen hadn't completed when you turned the engine off, the fans stay on to help dump the extra heat in the DPF from the active regen. It's quite possible it still hadn't completed after your second drive. However, after your third drive it had either completed or dropped the soot to an acceptable level It wouldn't surprise me if a car wants to perform an active regen, it can tweak the fuelling to get the engine to warm up more quickly too.
Probably a DPF regen It's completely normal for the fan to run on if you turn the car off mid-regen. It's nothing to be concerned about unless it starts happening on a frequent basis
Going for remap, 170 Cr TDI, leave egr and dpf in or or both out??
Pretty simple in my mind, given the MOT is tightening up on DPF/EGR removal, I'd suggest you leave them fitted The car might be happier without them but is it worth the risk?
Adjust speedo accuracy using OBDeleven?
Typically, if the adjustment is anywhere, it'll be somewhere in the instrument cluster coding/adaptions so I'd start there. I'm not aware of being able to display GPS speed at all. I tend to have Waze via Android Auto showing my GPS speed although in my Octavia it almost perfectly matches the speedometer.
Changing DRL bulb in halogen headlights to LED
Can you post an autoscan and adaption map for 09?
Bonnet Struts/Dampers size and make
I think most use Febi 27709 which should be a direct replacement for: 6K6 827 550.
Virtual Cockpit Retrofit with Columbus and Canton
Probably worth posting an autoscan and an adaption map from 5F
XDS, or EDL, or XDL+ electronic differential lock - is it supplied at all in the UK?
It's in the Nov 2017 brochure where the S was the base model: And the Nov 2019 brochure where the SE Drive was the base model: Don't let me dissuade you from your quest! I'd love to hear a confirmation from Skoda that these technologies are fitted across the range I'm just highly cynical of the knowledge of some VAG group staff when it comes down to spec. Even more so when VAG seem to deliberately use misleading or confusing terminology that can change between brands or models. If nothing else, hopefully by explaining what some of these technologies are, you'll have a better chance of getting an answer rather than just being fobbed of with misleading or incorrect info
Emissions update checker!
Erm, I think you've misread or mistyped your VIN. At a guess, the second 2 is actually a Z...
You asked the dealer a question and got the following answer: It's not clear what 'it' was in your question. At a guess, you asked which models get the E-LSD (aka VAQ or mechanical diff) in which case yes, I'd agree that only the 245ps has it fitted. EDL and XDS are separate and distinct functions, please stop using them interchangeably as it's only confusing matters. To recap from earlier in this thread: - EDL uses the brakes to transfer power to wheels with grip (brakes the spinning wheel to transfer power to the non-spinning wheel) - XDS (torque vectoring) is an extension of the EDL+ESP systems, it'll use the inside brakes while turning to reduce wheel spin and maximise control/drive through and out of the corner It is showing both the haldex and EDL in action. - The haldex is responsible for moving power to the rear diff, it does not and can not transfer power left/right. - The front and rear diffs are open so EDL is responsible for transferring power left/right across each axle by braking the spinning wheel. When only the rear left wheel has traction (46 seconds), the haldex is moving power to the rear but as it's an open diff, the power takes the path of least resistance to the rear right wheel and the car doesn't move. When the offroad mode is selected, this makes EDL kick in more aggressively, braking the rear right wheel to transfer power to the rear left (62 seconds) and the car moves. Sorry for the long post, but I feel it's important to understand what these systems are as it'll help you find the right question, and hopefully answer. I think your question should be, do the MK4's (specifically the 4x4) get XDS, bearing in mind that: - XDS is just software on the ABS module - by the end of the MK3 production, it was standard on all models - the Polish site states all MK4 models have XDS - there is no mention of ABS or ESP in the UK brochure but both are fitted I would be amazed if the entire range doesn't have XDS, especially those with a haldex fitted
Just to help settle your mind. Here is a Polish website showing the base model gets ESP with ABS, EBD, MSR, ASR, EDL, HBA, DSR, RBS, ESBS, TSA, XDS+ as standard: https://www.wyborkierowcow.pl/nowa-skoda-octavia-2020-opis-wersji-i-cennik/ Example video showing the EDL in action on a MK4 Scout:
Sorry, can you clarify exactly what's only fitted to the 245ps petrol? As I mentioned previously, I would expect the 245ps to get the E-LSD but all models should have EDL+XDS as it's part of the ABS system. Exactly the same as the MK3's...
possible cam belt problem at 20k miles :(
You can get a full list of TSB/TPI's against your VIN from Skoda: https://erwin.skoda-auto.cz/ An hour and a 'print to pdf' function should be enough to get most the data for your car. There are also workshop manuals, wiring diagrams etc too
A 2012 CR170 is definitely effected The most reliable way to confirm if the update has been done is to check the software version of the ECU using VCDS or similar. You can also check the boot well for a 23R7 sticker as that'll show the fix has been done.
