Everything posted by Dean
1.8t octavia vrs upgraded fuel pump
If you buy a complete whole new unit from Skoda yes, but the pumps themselves are not expensive and they are not race pumps. But, have a look around and see others opinions and experiences. Search on Google: mk1 octavia vrs sytec site:www.briskoda.net
You’ll need to remove the whole unit, as you need to swap the pumps over. Be sure to be careful when removing the in tank pipe feed from the unit as it gets brittle.
The standard OEM unit should be fine up to stage 2. But, you can upgrade to the Sytec unit that a lot of us use on the forum. I too personally use this model for 240ish bhp. Sytec Hi In-Tank Fuel Injection Pump 36mm In 8mm Out P3031.1 https://www.motorsport-tools.com/sytec-hi-in-tank-fuel-injection-pump-36mm-in-8mm-out-p3031-1.html A lot of others also use the Walbro.
Mk1 Octavia VRS Estate
Welcome to our yobo world! I'm such a child, but I can't help hearing the Wohhhhtshhhhh! And, to be fair, they have lasted 15+ years. And new OEM ones will last that again.
Clean up the sensor if it's working ok, clean the CTS housing too, and buy a new oring and clip from Skoda. Worse case is that it may be cracked so a new housing is needed. Easily purchased and can be had from Just German Parts on eBay.
When you're bored of the R-Tech heat shield, I'll take it off your hands. 😄👍
R32 clutch. Is it enough?
I'd recommend the Darkside kit and get the uprated clutch which can handle more than 300lbft.
Enjoy fitting that! Let us know if you notice any improvements.
Electrics trip and reset mk1 Vrs
Let us know how you get on.
The black cable opposite the green fuses went hot within seconds of starting the car. Do I need to buy a new alternator harness or just get some new cable and crimp it? A new cable and crimp it. Others have cut it. But, personally, I would have a new one. It also looks like in the past, the black cable next to the 4 red cables has been changed. You can see the burn mark on the plastic cover, so that's obviously built up resistance and someone had it changed.
I’d look at that door loom first. Take it completely out or get a multi meter on it and check for any breaks in the wires.
Map sensor
It’ll be on the drivers side usually just off the bend going up to the intake. At least that’s is where mine is as the wire is not long enough. Inner arch out, and wheel off to get to it. Or to make life easy, take the bumper off and take a few photos for reference in case you need anything else at a later date.
Intercoolers.. again.
Only pic I've got at the moment. It's a full THS setup. Slight modification to the slam panel (inside) so the pipes site in place. It can't be seen at all once the bumper is on. I have a bracket that supports the weight of the FMIC neatly, and it bolts to the slam panel. Unlike a lot of other people who attach it to their front panel.
You have second hand kits on the other groups on FB, I’m sure. People are always breaking their cars. So I’d join a few groups and see if anything comes up. I run a FMIC but it’s a twin pass, so all the connections are in the drivers side, so it keeps it all OEM. If you’re going to run the normal FMIC, I think upgrading to the 225 Bam inlet looks better and gives a better flow. I’d still expect to spend between £300-£400 for a full kit, even second hand.
- CookieMonsterVRS
MK1 Octavia (VRS) with Factory Maxidot + Satnav (list)
Currently, the 7th car in my above list is for sale. If someone is wanting/looking for a very HIGH SPEC MK1 Octavia vRS. It's very similar to MY Corrida Red Spec (Minus the Parking Sensors and Heated Seats). Spec: MAXI DOT DISPLAY (WITH GPS AERIAL, FACTORY) DX SATNAV (You'll need to confirm this as I cannot see it in the photo) XENONS CRUISE CONTROL CORRIDA RED While the spec is nice, the condition isn't the best, and it needs some love. The inside I think needs ripping out! Also, it's worth noting that if you plan to run an intercooler with Xenons, you will have some trouble as the extra space is taken up by the xenon levellers. Best of luck should anyone want to go get it... If I had the space, I'd honestly would've bought it last week.
Hello from Surrey, UK
Welcome aboard!
- Saving a MK1 Octavia VRS Police Car, FJ54 WYP
Comfort indicator wiring??
- Comfort indicator wiring??
All mine are doing it too. It's bound to happen to our older cars now. But best to try and find the leak. Although, I left my window open yesterday... Wasn't fun this morning.- Comfort indicator wiring??
I have a picture in my thread. As I run one (two soon).- Given up: Water in drivers footwell
Last couple of ideas; door card with no membrane and the door seals. I wonder if the underlay is probably so wet and rotten now, that it keeps making the carpet wet. When I fully stripped out the Estate, mine were falling apart. Get the right tools to make your life easy (plastic interior tools). Work from the top of the a/b/c pillars and remove them first so no clips break.- MK1 Octavia (VRS) with Factory Maxidot + Satnav (list)
Updated.- Vrs rear door panel removal advice please
Take loads of pictures! Always worth making a project thread too, then we can keep up with your progress and it can also help others? https://www.briskoda.net/forums/forum/207-octavia-projects/- Vrs rear door panel removal advice please
