Everything posted by Kenny R
Access to Kamiq fusebox
Dashcam piggybacked off fuse 43 rear wiper, which according to consensus on here is the one to use and I have done on 2 Yetis and 2 Kodiaq’s previously.
As above it’s fuse 54 your looking for. My fuse box is same layout as yours and handbook diagram, and as mentioned slightly more populated.
Driving Score on the Skoda app
I have used the driving score previously but earlier in the year it was removed from the app, and posts on here confirmed the same. Have you got the driving score on a current version of MY Škoda as it certainly hasn’t re appeared on mine.
Footwell Colour
My 2024 Monte Carlo is the same.
Battery Change 202 Kamiq SEl
i would find a battery supplier that actually knows what they’re doing and get your battery tested and if a new battery is required , fitted and coded as is required.
Spare wheel purchasing (confirmation)
As mentioned not sure what tyre is fitted to that wheel on eBay and no guarantee on it’s integrity after obviously having been in an accident. Also you would need to buy the foam insert, jack tools etc. You can buy the complete set from a dealer, the part no in following link… https://www.caffynscarparts.com/skoda-kamiq-spare-wheel-kit-1850-p.asp
Rear vents - no air flow
Kamiq Monte Carlo trim available throughout Europe, Australia and New Zealand as well as UK.
changed steering wheel 3 spoke to 2 spoke, lost button function
No expert, but would have thought the similar new style 3 spoke would be have been a straight swap, whereas fitting the older style might need coding or different buttons fitted.
Well my 2024 Monte Carlo rear vents certainly aren’t just for decoration and work faultlessly without other vents being closed or fan on max. Climate control on mine always set to auto, ac on and temp set to 20°C all day every day summer and winter.
Echo problem
The Kodiaq had a system that amplified drivers voice and relayed it to the rear speakers for rear passengers, this gave the same echoes as your experiencing so perhaps the superb has the same system. It could be turned off in the infotainment unit under voice enhancement.
Car Renewal Advice – Considering a Skoda Karoq (Lighting Question)
Matrix lights are LED and the light beam adjusts and blanks out cars approaching and cars in front and in my opinion are great and 100 times better than old xenon lights.
Monte Carlo 2024 Pain from side bolsters on seats
Here’s what mine looks like, but you’d better better setting seat to suit you. This guide is good .. https://www.physiomed.co.uk/uploads/guide/file/21/Physiomed_Sitting_Guide_-_Driving_Digital.pdf
I’m 5’10 and 100kg and have the same seats and find them comfortable and no pains or niggles. I have the seat set quite high and don’t use the lumbar support.
- Two-cylinder mode
- Odometer reading not showing - only trip mileage
Komiq spare wheel
My spare wheel/ tyre for Monte Carlo with 18” wheels has 205x55x16 tyre so 60 profile could be wrong, also tyre fitted on that shown is a directional Crossclimate so could only be used on one side of car.
Quick oil question
There should be a sticker on the bonnet slam panel with what oil to use. Mine says VW508.00/ VW509.00 OW-20. 1.5 Tsi.
Komiq spare wheel
My 24 Monte Carlo with 215x45 18” wheels has a factory fit spare wheel that is 205x55 16”.
Battery Coding question
- My Skoda app
You can plan a journey on the app map then send it to your car.- 3rd Row Headrest
- Car tax on 2025 2.0 sportline
If the retail price is over £40k then yes you’ll pay the higher tax.- New Tyres
Going up load rating is fine. Can recommend Michelin Crossclimate, I have them on mine albeit in a different size. https://www.camskill.co.uk/m140b0s8838p208583/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_205_55_R17_95V_XL_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_B_NoiseClass%3A_A_Noise%3A_69dB- Scala Alloy Upgrade
There’s a few second hand on eBay or if you want new try dealer or Skoda- parts.com - My Skoda app
